Drives: 2017 Ice Silver BRZ Limited
SARD ITB (4 Throttle) News!
Just saw this posted by SARD on FB:
http://www.sard.co.jp/pdf/1710_4Throttle.pdf https://www.facebook.com/SARD.Customize/ Seems to be an updated, final production version that is actually available. Anyone want to translate the Japanese for us? |
| The Following 3 Users Say Thank You to Williampreza For This Useful Post: |
#2 |
Drives: Track preped NA FRS
So they are putting it out at about the same time as the Greedy version. Two ITB kits at the same time, I wonder if we are about to see some interesting changes in NA tuning for our cars.
#3 | |
Drives: 15 BRZ LTD, 05 FXT
I'm imagining an E85 full bolt on ACE powered car would be preeeetty righteous.
#4 |
Inb4 no gains.
| The Following User Says Thank You to Tokay444 For This Useful Post: | R2RO (11-18-2017) |
#5 |
Most likely minimal, if any gains seen on a dyno sheet, with substantial gains felt from the drivers seat, and small gains seen in lap times.
| The Following User Says Thank You to JazzleSAURUS For This Useful Post: | Cole (11-08-2017) |
#6 |
Good ol' placebo effect never disappoints.
| The Following User Says Thank You to Tokay444 For This Useful Post: | Tcoat (11-09-2017) |
#7 |
Huge E85 fan!
Drives: 2016 Scion FRS
4x the potential problems. I don't understand the benefits. The MAF is in the stock position even.
#8 |
Drives: none
ITB's don't improve throttle response by reducing the distance between your air metering device and the throttle body, the idea is to reduce the distance between the throttle body and the combustion chamber. In the strictest sense MAF placement doesn't really impact throttle response as much as you might think. To increase throttle response you want to reduce the delay between opening the throttle and an increase in charge air pressure. Now, of course you need to add more fuel to match the added air and if you relied only on the signal from your MAF then the fuel would lag behind the increased air pressure. However, pretty much all modern engine management systems provide numerous adjustments to handle tip-in enrichment. This is specifically due to the delay between the increased fuel demand and the MAF signal. This delay is present on pretty much ALL MAF systems, even our stock system. ITBs cause other difficulties in tuning but handling lag in MAF signal is not a big deal.
Heck... full-out race systems will often use Alpha-N tuning which bases fuel purely on TPS and RPM. Horrible for a street setup but it is a very simple system for cars that operate at high load most of the time and don't have to worry about stop and go traffic or other moderate load scenarios that trip up Alpha-N. |
| The Following 5 Users Say Thank You to armstrom For This Useful Post: | Cole (11-09-2017), CSG Mike (11-11-2017), GoJoshGo (04-04-2018), JazzleSAURUS (11-09-2017), wparsons (11-15-2017) |
#9 |
Drives: 2005 Toyota Camry
#10 |
| The Following User Says Thank You to Grady For This Useful Post: | Tokay444 (11-09-2017) |
#11 | |
Señor Member
Both brands have a fairly abrupt angle of runner just about the throttles.
1974 TA22 Celica
2013 86 GT |
| The Following 2 Users Say Thank You to Turdinator For This Useful Post: | nikitopo (11-09-2017), Williampreza (11-08-2017) |
#12 |
#13 |
Drives: 2013 Firestorm FR-S
Curious what this or the Greddy achieves. If slight gains, then maybe some great sounds?
#14 |
Drives: '15 BRZ RA
It says ...
· Each cylinder intake is longer and the throttle area is enlarged. There is an improvement in responsiveness and intermediate power · Φ 45 Throttle × 4 / Surge tank / piping etc. required for installation · Genuine injector can be installed An ECU setting is needed. |
| The Following 3 Users Say Thank You to nikitopo For This Useful Post: |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 01:20 PM |
| SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp | Trojan_SC | Engine, Exhaust, Bolt-Ons | 19 | 03-28-2018 08:52 PM |
| Bad news good news | ls1ac | BRZ First-Gen (2012+) — General Topics | 2 | 10-01-2016 10:11 PM |
| SARD 86 GT1 Body Kit + SARD LSR Wing | nigel-jdmparts | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-27-2015 01:41 PM |
