#1961 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Haven't had any reliability issues at all! I'd attribute most of that to the tuning from HRI, but the kit is super solid and the components are all very high quality. My GTX2860R Gen2 spools at 3000 RPMs and pulls hard all the way to redline!
#1962 | |
Drives: 2013 Scion FRS
Also 2 quick questions: 1. When starting up the engine/turbo from a cold start (in the morning or whenever), do you have to let the engine idle and (turbo) warm up or could I just drive off and baby the car? 2. Say I get to my destination, would I have to sit idle and let the turbo cool down before I turn it off? As |
#1963 | |
Absolutely! The base kit comes with a Precision 4831 billet wheel turbo and upgrades are available for dual ball bearing Garrett GT and GTX turbos!
That's not really necessary with modern day turbos which have oil restrictors and the Garretts have water cooling so you don't have to worry about oil coking in the bearings from being shut down while hot. If you are coming off of a spirited run or a track session, its a good idea to do a cool-down anyways before shutting the engine off. |
#1964 |
Drives: 2017 Toyota 86 M6
I havent read the whole thread but i was wondering how are the torque solution engine mount? Debating on this or the Cuscos but havent seen a review of them yet!
#1965 |
The install was easier than expected. They fit perfectly. The results were less additional NVH than expected. I really like them for the price.
| The Following User Says Thank You to ATL BRZ For This Useful Post: | Qc86 (11-10-2017) |
#1966 |
Getting some baseline numbers on a Mustang Dyno.
[ame="https://www.youtube.com/watch?v=TsevkF0EOts"]JDL Turbo Subaru BRZ baseline dyno - YouTube[/ame] ![]() 304whp / 255wtq on just the 9.4psi spring and E67 in the tank. Pretty much what I expected! This turbo isn't even trying. EBCS and more boost soon!
| The Following 9 Users Say Thank You to ATL BRZ For This Useful Post: | ApexEight (11-14-2017), cbryant514 (11-14-2017), CkOne (11-19-2017), dattran86 (11-15-2017), Detroiter (11-14-2017), Hicklinc (02-09-2018), pgranberg11 (11-14-2017), stoked_on_spool (11-14-2017), Teseo (11-14-2017) |
#1967 |
Drives: 2007 sti
I spent some time reading through your build, great build!
I've been looking at turbo kits and just had a few questions. Any reason for choosing jdl over say full blown? How has cooling/temps been on the track with a front mount turbo kit? I would like to focus my build around street/track, so reliability and heat management are some areas of consideration for me. |
#1968 | |
Thanks!
In my opinion, JDL has superior quality manifolds and hot parts to many of the current options, including Full Blown. JDL also offer more customization options for their kits, including a bunch of different Precision/Garrett turbos, coatings, housing and flange options, the sky is the limit, really. I really love the UEL rumble and the JDL turbo manifold delivers that superbly. JDL's customer service and support is also excellent so that should be enough reasoning. ![]() Quote:
There's more I can do to help, like getting the hot parts wrapped with inconel alloy shielding but it's very expensive. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | DocWalt (11-17-2017) |
#1969 | |
Drives: 2007 sti
Anything you'd do differently/recommendations in terms of airflow or cooling (with a similar turbo setup)? |
#1970 | |
#1971 |
Drives: 2007 sti
That's reassuring. I was looking into ptunnings kit due to placement, but wasn't a fan of all the charge piping. Jdl and full blown kits seem to have a pretty good record and seem to be quality offerings. I was j ust worried about heat management with a front mount turbo. Thanks for your feed back!
| The Following User Says Thank You to woasuby For This Useful Post: | ATL BRZ (11-15-2017) |
#1972 |
Killed Scion
Drives: 2013 FR-S Whiteout
Do you have any updated thoughts on the IRP short shifter? How is it when the trans is cold? Too notchy?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#1973 | |
I still only recommend it for a track application. |
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | DocWalt (11-17-2017), MisterSheep (11-18-2017) |
#1974 |
Drives: 2013 Subaru BRZ
Was curious, what's the advantage of the drift/crash bar? Also, didn't see it on your list of mods.
Sent from my Pixel 2 XL using Tapatalk |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
