Old 11-06-2017, 07:30 PM   #99
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
To clarify, I'm mandated to have a cat for the stuff I compete in, so I have to maximize my gain.
The catback wasn't put on my car because... it's designed to keep the car quiet with a presence, but like every other catback, doesn't provide gains. No need to spend money when I'm on a limited budget like everyone else; I'd rather put it toward ceramic on the header.
Thanks for the clarification on the cat, I should have realized your car is set up for the club series you guys have since I've watched the videos. Understood about the exhaust not providing gains, I included it because my car's a daily that's on track 6-8 times per year. Clearly the ACE header with ceramic coating and flex fuel is the shortest, most direct line to max gains.
JSube is offline   Reply With Quote
Old 11-06-2017, 07:48 PM   #100
CSG Mike
CSG Mike's Avatar
Originally Posted by Grady View Post
Impressive numbers! However I have a couple of questions. Correct me if my math is incorrect.
https://www.delicioustuning.com/Stoc..._Breaks_200whp
Stock 200hp crank BRZ making 201hp at the wheels on E85.
I know you are on E70 but E85 should not be much different on a NA engine.
Yours stock was 205hp at the crank.
With interpretation stock 2017 should be 206hp at the wheels on E85.
This means the header added 1.5HP.
I would expect the 2017 to do better than that with a header and on E85?
I need to dyno mine to see what the Delicious E85 tune has done!
Could the stock 2017 header be almost as good as the aftermarket headers?
Are we hittting the engine efficiency wall?
Votlon (11-10-2017)
Old 11-06-2017, 08:19 PM   #101
cjd
cjd's Avatar
Drives: 2017 BRZ
You can't compare dynos/days that easily. Go look again, there were impressive gains on 91. Also, I've never seen 200 on just e85... Though I haven't looked very hard, since I can't use it (yay rules)
Old 11-06-2017, 08:23 PM   #102
cjd
cjd's Avatar
Drives: 2017 BRZ
Bench Dyno and magic unicorn numbers. You should add that cai, I hear 30hp...
More seriously, would a 2.5" aftermarket for with high flow cat help a little? I see the ace fp is 3"... Curious what it will take to make the most of the rules now that I have to rebuild... And the header was destroyed, so I need a new one.
The Following User Says Thank You to cjd For This Useful Post:
GeorgeJFrick (12-31-2017)
Old 11-06-2017, 09:47 PM   #103
Grady
Grady's Avatar
Delicious tuning claims to make a stock 200HP BRZ get 201hp at the wheels with their E85 tune.
I posted the link directly to their website.
Did Delicious do your tuning?
Old 11-06-2017, 09:58 PM   #104
Grady
Grady's Avatar
Don’t get me wrong, the numbers are great! I know dyno numbers vary even tho they are suppose to be normalized to a standard day at sea level. Delicious did the tune on the 2013 maybe is was not their dyno and it was one that like to give the unicorn numbers? Marketing guys like to use unicorn numbers.
Old 11-06-2017, 10:01 PM   #105
CSG Mike
CSG Mike's Avatar
Yes, Delicious did my tuning.
Old 11-06-2017, 10:15 PM   #106
Grady
Grady's Avatar
And they did mine also. No complaints about how it runs. Just when they claim to be able to get 201 at the wheels of a stock 2013, I would expect more than 207 at the wheels of a 2017 with a good header.
Probably just different dyno different day.
Old 11-06-2017, 10:26 PM   #107
cjd
cjd's Avatar
Drives: 2017 BRZ
That's all I was saying - it's probable that was an odd case out however you look at it; looking at the results Mike posted, the gains are significant from baseline in as controlled an environment (and the best case for comparison) as you can typically find. Forget comparing peak numbers across sessions.
CSG Mike (11-06-2017)
Old 11-06-2017, 11:55 PM   #108
gtengr
Drives: 2017 BRZ
Seeing as how one graph says dynojet and the other says dyno dynamics, I would agree.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
Old 11-07-2017, 02:12 AM   #109
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder how do manufacturers dyno/rate their engines "officially" though. Just at crank at some test-bench, without any transmission at all?
Votlon (11-10-2017)
Old 11-07-2017, 02:44 AM   #110
Kodename47
Kodename47's Avatar
Drives: UK GT86
Engine dyno.... Like Cosworth did on their FA20 stuff.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-10-2017, 07:00 PM   #111
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
mikes reaction is always priceless
Votlon is offline   Reply With Quote
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-09-2019 11:03 PM
CSG x MXP Catback + Ace A350 - Review & Video Majic86 Engine, Exhaust, Transmission 14 08-06-2018 01:01 AM
Do dynos lie? nikitopo Engine, Exhaust, Transmission 21 05-10-2017 08:32 AM
CSG Mike's 2017 Baseline dynos CSG Mike Engine, Exhaust, Transmission 40 01-21-2017 09:20 PM
Perrin CAI - Any dynos? griffinnn Engine, Exhaust, Transmission 0 03-14-2014 04:56 AM
