Old 09-12-2016, 11:35 AM   #253
nickg
Drives: 2014 Whiteout FR-S Manual
So with being lowered on coilovers and -2 degrees of camber, will it rub anywhere? Because tirerack stocks +45 and they mount for free, there's about a $200 price difference between these and +35.
nickg is offline   Reply With Quote
Old 09-13-2016, 05:14 PM   #254
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
The +45's shouldn't rub the spring perch with coilovers. However, they will still probably rub the tie rod at full lock. I think some people use a 3mm spacer to fix that though.
If you're interested in +35's, you could check Oakos. They usually have a good selection at pretty reasonable prices. I think they offer a discount if you PM them on here too.
smg1138 is offline   Reply With Quote
Old 09-15-2016, 12:32 PM   #255
ModBargains.com
ModBargains.com's Avatar
Enkei really nailed it with the RPF1, it is such a diverse wheel and looks right on so many platforms
ModBargains.com is offline   Reply With Quote
Old 09-15-2016, 01:03 PM   #256
churchx
churchx's Avatar
Drives: 2014 GT86
I wouldn't care much about looks of RPF1, as far as wheel is not uber ugly, it's good enough. In my eyes main strength of RPF1 is not looks, but relatively light weight & reasonably low price. Many lighter then that = forged & expensive. Average cast ones = heavier.
Old 09-15-2016, 04:42 PM   #257
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I guess it depends how low. I didn't rub when I was 1.5" or 1" lower and -2 camber.
Mad_Mike is offline   Reply With Quote
Old 10-10-2016, 12:12 AM   #258
Bobster
Drives: GT86 GTS
Anyone having any issues with these wheels rubbing on the front anti-roll bar
Bobster is offline   Reply With Quote
Old 10-16-2017, 10:39 PM   #259
Anthonyc77
Drives: 2017 Toyota 86 Halo
Currently have these on stock suspension, rubs the tie rod pretty noticeably at close to full lock. Does anyone know if for sure a 3mm spacer will solve the tie rod issue, or does it require 5-10mm.
Anthonyc77 is offline   Reply With Quote
Old 11-04-2017, 09:27 AM   #260
dattran86
Driver
Drives: 2013 Whiteout FRS
17x9 45
255 40
OEM struts with lowering spring.
DSC_4167 by Apex 86, on Flickr
DSC_4176 by Apex 86, on Flickr
DSC_4164 by Apex 86, on Flickr
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
The Following 2 Users Say Thank You to dattran86 For This Useful Post:
KMA KiCKz (02-14-2018), Surok (01-05-2018)
Old 01-02-2018, 04:25 PM   #261
dattran86
Driver
Anyone running coilovers with 245s? I just want to see how much sunken in the wheel look.
IG: aimforapex
Old 01-02-2018, 04:49 PM   #262
DarkSideFRS
Drives: 2013 pearl white FR-S
Originally Posted by dattran86 View Post
17x9 45
255 40
damn... 255 with springs and 45 offset? do u hit the spring perch?
edit: how much camber do u run?
DarkSideFRS is offline   Reply With Quote
Old 01-02-2018, 05:15 PM   #263
dattran86
Driver
It wasn't black magic, I had 10mm spacer with ARP extended studs
IG: aimforapex
Old 01-02-2018, 05:43 PM   #264
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i find that 17x9 +45 works really well, but i think that +35 does look slightly better, and increases track by 20mm.
i run a 245/40 AD08R, and its really nice, lowered as much as possible to maintain nice geometry , with -4.3 degree of camber on the front and -3 in the rear. lots of toe out on the front too. with coilovers of course.
Surok is offline   Reply With Quote
Old 04-11-2018, 06:57 AM   #265
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
Originally Posted by FT-86 SpeedFactory View Post
17x9 +35 will clear stock suspension perfectly and not rub. It's the offset we recommend plus it clears most BBK set ups. +45 is just not ideal on a 17x9 . We also stock the 17x9 +35 in silver and black.
i am on the stock suspension
after all the researching, here is my answer
front enkei rpf1 17x8 +45 245x40 17
rear enkei rpf1 17x9 +45 245x40 17
the reason i want keep it +45 off set is this
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
it will create a positive camber in front if i use 17x9 +35
so if i keep 17x9 +45 at front it will against the suspension
finally i put 17x8 +45 , everything is right!
but i dont know is there any BBK issues?
if i am going to put a
BREMBO GT FRONT 4 PISTON SLOTTED OR DRILLED BRAKE KIT
from your website
hope someone can help me out !!!
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 06-04-2024, 11:13 AM   #266
BioRebel
Drives: Mini Cooper S
Anyone here know of a brake kit that fits under these things?
BioRebel is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 04:18 PM
