Old 11-02-2017, 02:51 PM   #1
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Retune needed for pulley change?
Currently running a JR C30 supercharger with the higher boost 100mm pulley and flex fuel tune. Going to replace the 100mm pulley with the 90mm version they now offer. Other than lowering the rev limiter to avoid over spinning the compressor, does the tune itself need to be modified?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-02-2017, 03:22 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You're going to be pushing more boost so.....
Old 11-02-2017, 04:12 PM   #3
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
yes
pgranberg11 is offline   Reply With Quote
Old 11-02-2017, 04:21 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Any significant changes to the induction or exhaust require a proper tune to function CORRECTLY. Plenty of people toss on a header 'due to because subaru sounds' without tuning, and wonder why they have a CEL and their car isn't any faster.
But since you're asking questions like this, and you've managed to already install a supercharger kit and flex fuel, I suggest starting here: http://www.ft86club.com/forums/showthread.php?t=81493
It's a good read to remind yourself of some of the basics that can be easy to forget once you're past a few of the 'honeymoon mods'.
JazzleSAURUS is offline   Reply With Quote
Old 11-02-2017, 06:38 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Depends on whether the tune is done with the headroom for more airflow. It may need one, it may not.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-03-2017, 07:55 AM   #6
Deep Six
Deep Six's Avatar
Spoke with James yesterday and it's just some minor alterations needed. We will do some street tuning together once I have the new pulley installed. helps that we live in the same town.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
CSG Mike (11-03-2017)
Old 11-03-2017, 09:39 AM   #7
JazzleSAURUS
Perfect, that's the correct course of action!
Most tuners will make minor map adjustments for very little. Some even free depending on the changes and your requirements.
Borla EL header exhaust leak/Will I need a retune TelMinz Engine, Exhaust, Transmission 9 06-12-2016 06:10 PM
FS: Dell Venue Pro 8 with Win. 8.1 Full. Tune, log, retune, FAST Flashes Sportsguy83 Engine, Exhaust, Bolt-Ons 5 06-02-2014 06:27 PM
stg1 custom tune add intake retune =??? StormTrooper Engine, Exhaust, Transmission 11 12-23-2013 05:59 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
