Old 11-01-2017, 11:30 AM   #29
stevesnj
stevesnj's Avatar
Clean DRY lug nut and stud threads tightened by hand, no impact gun should be used for removal or tightening. Debris, grease, oil, etc. in the lug not and/or the stud WILL affect torque values. The stock rim value is 89 not 90. Could 1ft pound make a difference? Who knows. I use a battery terminal brush and it works fine.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
JohnJuan (11-01-2017), TMF (11-01-2017)
Old 11-01-2017, 11:54 AM   #30
ka-t_240
Originally Posted by TMF View Post
Thanks for the info man! Glad to hear the Muteki's are still working for you. I think I might try the 949's though since I no longer have a full set of Muteki's and I don't think you can buy singles.
And ARP does have 3 different lengths for studs now. I might just go with the longest ones so I have flexibility to run spacers if needed in the future.
Best make sure the longer studs are SSC legal
ka-t_240 is offline   Reply With Quote
Old 11-01-2017, 12:28 PM   #31
TMF
TMF's Avatar
Drives: '14 FRS TT5
They are
"Wheel lug studs (e.g., length) and lug nuts may be changed."
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 11-01-2017, 01:20 PM   #32
TrqlessWonder
Drives: 2014 FR-S
We'll have to disagree, I think, but 200 ft-lbs *is* a hulk smash setting. My 1/2" Dewalt won't drive them to final torque, and that's a good thing in my book. We aren't doing green flag pitstops, so the extra 1 minute that using a breaker bar takes can't be the end of the world.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 11-01-2017, 02:26 PM   #33
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
How does anybody feel about using ARP's studs meant for the Evo, since they're 12x1.5 thread instead of 12.1.25? Would they be tougher?
They are super long, though. They're almost 1/2" longer than the long FR-S studs.
Studs: https://www.summitracing.com/parts/arp-100-7717
Specs from the catalog, for comparison:
JohnJuan is offline   Reply With Quote
Old 11-01-2017, 02:51 PM   #34
TMF
TMF's Avatar
Drives: '14 FRS TT5
They are all rated at 190,000 psi tensile strength, so I'm going to go out on a limb and say, it won't make a bit of difference.
And if they are even longer, that means more threads and more opportunity for you to mess up threads when putting the wheel on.
I'd say stick with the 12x1.25.
The Following User Says Thank You to TMF For This Useful Post:
strat61caster (11-02-2017)
Old 11-01-2017, 03:05 PM   #35
dutchman1
Drives: 2017 86 6-Speed
Fine thread fasteners are actually stronger than course thread of the same diameter. They can hold more tension without stripping because they have more thread surface area, and they have greater shear strength because the actual diameter of the bolt is larger (the threads are shallower).
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
The Following 2 Users Say Thank You to dutchman1 For This Useful Post:
JohnJuan (11-01-2017), strat61caster (11-02-2017)
Old 11-01-2017, 03:20 PM   #36
JohnJuan
JohnJuan's Avatar
I thought our issue wasn't that the lugs shear off, but that the threads get worn out or cross-threaded. It seems like the coarser threads would help with that problem.
Old 11-01-2017, 03:33 PM   #37
dutchman1
I suppose coarse thread might help if there was a contamination issue, but you're still less likely to strip or cross thread a lug with fine thread. There are more threads, so each individual thread sees less stress, and they're shallower and thus less likely to roll over.
I know it seems counterintuitive because smaller threads seem more fragile, but that's not the case.
The Following User Says Thank You to dutchman1 For This Useful Post:
Old 11-01-2017, 04:42 PM   #38
JohnJuan
JohnJuan's Avatar
Thanks!
Old 11-01-2017, 05:11 PM   #39
ka-t_240
Are you buzzing them on with an impact, and not had starting?
What lugs?
Seems to me, cross threading is an install issue vs a parts issue(unless you have shitty parts).
Old 11-01-2017, 06:58 PM   #40
DaWorstPlaya
Drives: 2016 FR-S
I use anti-seize, never snapped a lug after that. Knock on wood.
DaWorstPlaya is offline   Reply With Quote
Old 11-01-2017, 10:38 PM   #41
stevesnj
stevesnj's Avatar
Worst thing to use is anti seize.
Old 11-02-2017, 10:31 AM   #42
snoxracer183
Drives: 2014 FR-S SSC
Well it fits his username
JK DaWorst
snoxracer183 is offline   Reply With Quote
The Following User Says Thank You to snoxracer183 For This Useful Post:
stevesnj (11-02-2017)
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Brakes, Suspension, Chassis 1 10-05-2016 01:48 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Wheels and Tires 0 10-01-2016 10:50 PM
Wheel stud shop installations recommendations BRZkitty Northern California 9 12-23-2014 03:12 PM
Replacement Lug Stud/Wheel Hub swift996 Issues | Warranty | Recalls / TSB 3 08-30-2013 02:58 PM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
