Old 10-31-2017, 04:10 AM   #1
mulekr1
mulekr1's Avatar
Drives: 15' Limited BRZ
Cracked fuse box housing
Hi I have a 2015 limited Subaru BRZ, the fuse box was cracked when I bought the car and all it has is the cover with no lower portion to mount onto the chassis so it just sits there collecting heat. I see I can purchase a 2013 Scion FR-S automatic fuse box I don’t need the actual fuses or the box just the plastic housing the shape and dimensions of the box is the same right?
mulekr1 is offline   Reply With Quote
Old 10-31-2017, 09:55 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you just need box, then it should be same. manual/automatic has same location of fuse box
Old 11-01-2017, 01:24 AM   #3
mulekr1
mulekr1's Avatar
Hey thanks for the reply my big question is does it have the same shape and dimensions and size as a BRZ (Subaru) 2015 (one I’m buying is 2013) manual (one I’m buying is automatic) fuse box and does it have the same kind of fuses in the same places
Old 11-01-2017, 08:16 AM   #4
Did a quick look and couldn't find a part number but from the drawings they are all exactly the same. Make, year and model shouldn't matter. The fuses and relays can vary slightly but you can just make sure you match what you have when you put them in. All the spaces are there.
PTE 6466, 1.0 divided A/R, polished comp housing, black ceramic turbine housing slicktop Engine, Exhaust, Bolt-Ons 6 10-17-2015 11:53 PM
Cracked Housing? OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 7 02-02-2014 08:43 AM
Cracked Oil Pan?! Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 11-21-2013 03:28 PM
Has anyone cracked the OEM rotor yet? ayau Tracking / Autocross / HPDE / Drifting 10 04-22-2013 05:41 PM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 02:30 PM
