Drives: Car
Fiberglass Air Bubbles Subwoofer Enclosure
I couldn't find any information on the internet about what the effects of small air bubbles in fiberglass would be other than making it not as strong as it can be.
Would they create a terrible sound for a subwoofer? Any information and suggestion is greatly appreciated. Thanks |
#2 |
Drives: 2013 Hot Lava FRS
Pictures would help. How big are these bubbles? Where are they?
#3 | |
Drives: Car
But its a series of small bubbles and one huge one I plan to sand down on the bottom of the fiberglass plug.. It's my first time working with fiberglass and I havent used a roller... just a chip brush in a stab/dabbing motion. I am already 5 layers in and was wondering what would be the best plan of action |
#4 |
Drives: Car
![]() Its the lighter shaded area Sent from my iPhone using Tapatalk |
#5 |
Drives: 2015 Scion FR-S
I did a real crap job on a fiberglass enclosure when I was like 16 and never noticed any rattles from air pockets or anything. Started by creating a shape with a fleece blanket and fiberglassing that, then just layered on this extra thick mat my buddy managed to scavenge from somewhere. Fairly certain there were tons of air pockets larger than what you are showing if I remember right. I had a JL 10W6 with like 500w or so. I had the volume of my enclosure waaaaay off so it sounded like crap because of that but I don't think those air pockets would create a problem unless you're putting out major wattage.
#6 |
Country Boy 4 Life
http://stason.org/TULARC/entertainme...binet-wit.html
The fiberglass looks fine to me. If it can flex too, much it will change how it sounds. Speaker box fill can change the sound of a sub Depending on how much you add. By adding or subtracting fill you can "dial" in your sub. Of course this is providing that you have given the sub the correct dimension box.
I LIKE TIRES! |
#7 |
Drives: Car
thanks for the input you guys, now i dont feel as bad as i did about it before.. looks like im ready to continue with my subbox for my car
#8 |
Hard to tell from the pic but it looks to me like you need to about double the amount of resin you are putting on each layer. The bubbles are not a big deal since you aren't building a boat but not enough resin will end up with a very weak box. The layer of resin should be equal to or thicker than the layer of fiberglass.
#9 | |
Drives: Car
so far I have a sturdy rigid base compared to the walls. thanks for the advice |
| FR-S / BRZ / GT 86 - Fiberglass Subwoofer Enclosure Prototyping by Integrity Concepts | Integrity Concepts | Electronics | Audio | NAV | Infotainment | 302 | 11-16-2018 11:47 PM |
| FS: Custom fiberglass spare tire well enclosure w/ 2 Alpine 12" Type Rs - READY TO GO | rmjjensen | Audio/Visual, Electronics, Infotainment, NAV | 4 | 12-19-2016 11:43 AM |
| 12" Fiberglass Sub enclosure build thread | ハチロク | Electronics | Audio | NAV | Infotainment | 25 | 10-02-2015 11:17 AM |
| Subwoofer Enclosure | TB | Electronics | Audio | NAV | Infotainment | 8 | 09-23-2014 11:30 PM |
