Old 10-28-2017, 10:18 PM   #2577
CSG Mike
CSG Mike's Avatar
Originally Posted by shr133 View Post
Who make a good base map that's not locked??
I have my NA tune working great but would take a lot of work to convert my map over.
I will be doing the final tuning but I need a good base map to start with.
I know Edelbrock's map is locked.
Does any sell a good base map that's not locked???
Nobody does. Tuners don't give away their work!
Old 10-29-2017, 04:31 AM   #2578
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
@shr133 just interested to know why you want to tune yourself... isn’t this 1 of those things best left to those with experience?
Don’t know anything about you of course, so just asking.
I like driving!
86 South Africa is offline   Reply With Quote
Old 10-29-2017, 05:17 PM   #2579
shr133
shr133's Avatar
Drives: 2013 FRS
I know how to tune and it's my hobby tweaking and tuning my rides and I used to tune race cars back in the day.
The only problem is building a map from scratch will be very time consuming.
Plus each tuner has his own philosophy and they don't spend much time on the whole map and tune extra safe...
Plus I don't want to pay for every tweak... Like if I want to adjust my torque maps, set up a traction control map, set up some custom maps and map switching...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 10-29-2017, 05:26 PM   #2580
shr133
shr133's Avatar
Drives: 2013 FRS
That's what I figured, hoping someone had just a base safe map to start with..
That's one of the reasons I'm going supercharged, should be much easier to set up. I'll have to call some local tuners, but looks like I'm on my own..
Well I have all winter to work on it... I'm too hands on to have a caned map that's locked..
Old 10-30-2017, 03:03 AM   #2581
CSG Mike
CSG Mike's Avatar
Have you ever tuned an engine that features cam phasing or direct injection?
Old 10-30-2017, 10:45 AM   #2582
86 South Africa
Ok - fair enough - you have the experience to do so yourself
I like driving!
Old 10-31-2017, 12:50 AM   #2583
shr133
shr133's Avatar
Drives: 2013 FRS
This has been the first time, but for NA it was easy to figure out. I used to build race engines, run the dyno, flow bench, ect so I have a very good understanding of engines. What's great is you can change the tune over RPM and load to maximize performance at all levels. I have been tuning my car for 2 years now and it is really running good, I love it, never had a car run this good.
So now it's time to go to the next level, although I'm still debating if I should convert to E85 first than add the supercharger or just go for it during my winter up grades.
Old 11-01-2017, 10:46 PM   #2584
CSG Mike
CSG Mike's Avatar
That's actually awesome!
I'd recommend doing the E85/flex tune while NA to reduce risk and also learn how ethanol affects everything, as well as getting your cold starts down, before going FI. In some ways, it's similar to tuning methanol, and when you have to make compensations that work across a range of gasoline and ethanol, it gets a bit more complicated
Old 11-02-2017, 10:17 PM   #2585
Im_SPEED
Drives: FRS hot lava
Any one have problem with belt squeal at start up? I have a conti belt.(only 2k on it) Just started after I put in my built engine. All the pulleys seem lined up correctly belt seems a little loose between the a.c. and water pump (longest run). Also it was on the car when last motor blew.
Im_SPEED is offline   Reply With Quote
Old 11-02-2017, 10:58 PM   #2586
shr133
shr133's Avatar
Drives: 2013 FRS
Thanks, that's what I thought. Easier and safer to tune while NA.. I know the flex fuel kit allows you to change the fuel back and forth but seams like you would have to pick your mix that you want to use and optimize the tune for it...
Old 12-21-2017, 01:42 PM   #2587
gahooligan
Drives: 2017 BRZ Premium
Any news and questions...
Any news on th 2017 kit?
Is the jackson racing combo radiator the best cooling option? Works well with stock fans and lower temp tstat?
Is a clutch needed for daily+spirited+trackdays?
Cant wait for the kit to be released!!!
gahooligan is offline   Reply With Quote
Old 12-21-2017, 04:49 PM   #2588
CSG Mike
CSG Mike's Avatar
Still waiting.
A clutch is not needed, unless you're going to also run E85 with the kit.
The JacksoN Racing DROC is the easiest and cost effective solution. Anything else will cost more.
I recommend you PM and get your kit ordered so you can get in on the first batch the day it's released.
Old 12-25-2017, 01:54 AM   #2589
gahooligan
Sent you a PM Mike. Hope to order soon.
Old 12-27-2017, 12:55 PM   #2590
TOLM
Drives: Brz
Good thread.. I am currently on page 50.. slowly reading through the whole thing
Anyone knows if the kit would work on 2017 BRZ? (I am in Canada)
Thanks
TOLM is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
