Drives: .
SRS airbag code help
Hey guys so I'm trying to repair my cars SRS system.
The back story The passenger side roof airbag and the passenger side seat air bag deployed, also the passenger side seat belt locked up after an accident. What I've done so far I have replaced the passenger seat, passenger roof airbag, and have gotten the seat belt repaired by a seat belt repair shop. But now when I scan for the SRS codes via Autolink L619 SRS scan tool I'm getting 8 current codes, these codes are as follows. -B16f1 -B11f6 -B1901 -B1821 -B1831 -B1693 -B1650 -B1655 Some of these codes are driver side errors even though the driver side was untouched and no airbags deployed on the driver side. Does anyone have any ideas what I should be replacing? |
#3 |
Drives: .
#4 |
Drives: Subaru BRZ '13 WRB
After accident error codes are "hard-coded" into airbag computer (it's behind HVAC controls) and cannot be removed via OBD. Officially SRS computer needs to be replaced by a new one (or one that was not involved in an accident). It is possible to reflash it, but it needs to be removed and brought to airbag shop that has tools to reflash firmware in it.
| The Following User Says Thank You to P3tras For This Useful Post: | wrxdrifter (07-05-2016) |
#5 | |
Drives: .
#6 |
Same as in BRZ, behind air conditioning control panel. To remove it you need to remove central console, all plastic parts around air conditioning controls and then control panel itself. Behind it you will see SRS control module with big yellow connector (it is held with few nuts).
#7 |
Just send it in to get reflashed. Cost me $50 from srsmodule.com(pretty sure)
| The Following User Says Thank You to Ashikabi For This Useful Post: | wrxdrifter (07-05-2016) |
#8 | |
Drives: .
frs(1) by steven papania, on Flickr
#9 | |
#10 |
Drives: .
Okay just re-installed the module after getting it reset and the result is no SRS light! Thanks for the info guys!
#11 |
Np
#12 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#13 |
I used srsmodule.com, turn around was a couple weeks I think. Car" should" run without it but IMO, you're playing with fire. I guess racecars pull it out though
#14 |
I wonder if the dealership could do it for me if I took it out and brought it in. Insurance is paying for it so I don't care what it costs. Did you try a dealership before deciding on srsmodule?
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| WTB: 86 Airbag cover, no airbag needed | stevesnj | Australia Classifieds | 0 | 02-18-2016 09:17 PM |
| WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module | 14_GT86 | Want-To-Buy Requests | 3 | 04-01-2015 12:26 AM |
| WTB Passenger Curtain Airbag + Wheel Airbag | markkisl | Want-To-Buy Requests | 4 | 08-26-2014 01:16 AM |
| FS: JDM 86 Airbag horn cover with airbag | turbos86 | Interior Parts (Incl. Lighting) | 5 | 11-20-2013 01:17 AM |
