Old 10-26-2017, 05:08 PM   #379
xcuz31
Drives: white frs
Originally Posted by whataboutbob View Post
I have the Stark Performance kit, but it is not currently installed. We are working on devising a new mounting solution that will work with the Edlebrock SC. The standard mounting point is occupied by the electric pump for the SC inter cooler system.
Im planning to install a universal trans cooler but i dont have any idea how to and ive been researching and couldnt find any . Im curious if you need to add more trans oil after the install . And ive read that okce you add you need to reset or short the trans ecu if not the transmission will be on limp mode
xcuz31 is offline   Reply With Quote
Old 11-14-2017, 09:19 PM   #380
whataboutbob
AutoX-10/10ths every run
There's documentation on how to properly fill the transmission, see here: http://www.ft86club.com/forums/showp...41&postcount=9
I'd suspect that you will need more than the original amount of fluid as you're adding lines and a cooler to the system, how much I'm not sure.
I've done 2 fluid changes on my car and I did not need to reset the ECU.
Build thread:Here
Old 11-14-2017, 09:34 PM   #381
whataboutbob
So a little over 3 months ago I had the Direct Injector on Cyl 3 go bad. I didn't catch it until the damage was done, broken piston, scored bore. I sent out the DIs and PIs for testing after the fact and found that the DI on Cyl 3 stopped flowing fuel once it hit 225F.
I'm now working with Blue Moon Performance http://bluemoonperformance.com/ to rebuild.
Here's a few photos of the carnage and new parts.
Rough specs of motor are as follows:
- Brand new Direct Injectors, lol
- Over bored to 86.5mm
- 11.75/1 compression
- Custom Blue Moon Spec Carrillo rods and pistons
- Reimax oil pump gear
- Piper stg 1 cams
- Blue Moon oil baffle
- Stiffer valve springs
- +1mm on exhaust valves
- Polished intake and exhaust ports
- WPC treatment http://www.wpctreatment.com/about.htm on all moving parts
- non 2013 valve train components
- and other Blue Moon specific tweaks to the build...
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
ichitaka05 (11-24-2018)
Old 11-29-2017, 07:42 PM   #382
whataboutbob
Buttonwillow in March of this year.
Build thread:Here
Old 12-04-2017, 02:44 PM   #383
whataboutbob
The car is going to be back up and running soon thanks Bluemoon Performance (http://bluemoonperformance.com/) for the support!
Build thread:Here
Old 12-24-2017, 03:09 PM   #384
whataboutbob
Getting close.
Build thread:Here
Old 06-25-2018, 06:30 PM   #385
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
What is the effect of the Piper cams? More top end?
Sleepless is offline   Reply With Quote
Old 07-01-2018, 04:19 AM   #386
whataboutbob
Pete,
Look here for more info: https://pipercamsusa.com/products/su...ft-set-stage-1
Build thread:Here
Old 07-01-2018, 04:19 AM   #387
whataboutbob
So much win going on with the car building right now.
Build thread:Here
Old 11-02-2018, 01:27 PM   #388
GrabTheWheel
Drives: 16' BRZ
You ever get back up and running?
GrabTheWheel is offline   Reply With Quote
The Following 2 Users Say Thank You to GrabTheWheel For This Useful Post:
whataboutbob (11-02-2018), ZionsWrath (11-02-2018)
Old 11-02-2018, 11:37 PM   #389
whataboutbob
It's been a long process, but I should have it running this weekend. I've been working on a number of other supporting modifications, including an Accusump.
I'll post some photos in the near future.
You can see some of what I've been up to here: https://www.instagram.com/robert_stangarone/
Build thread:Here
ichitaka05 (11-08-2018)
Old 11-19-2018, 12:20 AM   #390
whataboutbob
Car is running again now.
Build thread:Here
The Following 4 Users Say Thank You to whataboutbob For This Useful Post:
ichitaka05 (11-24-2018), mixxxx (11-19-2018), Racecomp Engineering (11-19-2018), TeutonicShift89 (11-26-2018)
Old 11-26-2018, 01:43 AM   #391
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
Wow! Has it really been down for almost a year? Glad you got it running again!
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
The Following User Says Thank You to TeutonicShift89 For This Useful Post:
whataboutbob (11-26-2018)
Old 01-05-2019, 02:32 AM   #392
whataboutbob
Check out the latest updates here:
https://www.facebook.com/RobertStangaroneMotorsports/
Build thread:Here
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
Showstoppers Firestorm FR-S Build ShowstoppersUSA FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 10-09-2014 06:26 PM
Firestorm/black project build deedz Member's Car Journals 47 11-19-2012 05:06 PM
Firestorm FR-S Available mattyboy311 Mid-Atlantic 1 09-26-2012 11:36 AM
Firestorm Frs DAFRS88 Southern California 0 08-03-2012 05:11 AM
