#43 |
BoostedBRZ
Drives: Turbo BRZ
Here's the video of when my car let go. Feel free to skip to 1:30.
[ame="https://www.youtube.com/watch?v=-6y3dWz6p8s"]https://www.youtube.com/watch?v=-6y3dWz6p8s[/ame]
#44 |
BoostedBRZ
Drives: Turbo BRZ
for any one interested, I'm doing a partial part out. I've already sold my header. The supercharger kit and the injectors are up for grabs:
http://www.ft86club.com/forums/showthread.php?t=121711
#45 |
BoostedBRZ
Drives: Turbo BRZ
Before my engine blew up. Had the best track time chasing a REALLY good driver in an RSX.
[ame="https://www.youtube.com/watch?v=hYEjqdlkJlg&t="]https://www.youtube.com/watch?v=hYEjqdlkJlg&t=[/ame]
#46 |
BoostedBRZ
Drives: Turbo BRZ
another update, started to pull everything apart since the engine was coming out. took off the manifold, port and direct injector rails, and coolant bypass pipe? not sure what it is, but it was also damaged on the underside when the piston snapped..
![]() a few chunks I found in the bay with this bent bolt.... lol ![]() ![]() [ame="https://www.youtube.com/watch?v=CNOyZfiDGaQ"]https://www.youtube.com/watch?v=CNOyZfiDGaQ[/ame]
#47 |
Drives: Asphalt frs
Are you going to build the motor now?
Sent from my SM-N950U using Tapatalk |
#48 |
BoostedBRZ
Drives: Turbo BRZ
I decided against going with a built motor. I sold my kraftwerks kit and I will be purchasing a JDL turbo kit soon and use a different tuner and see how my luck turns out this time around. end goal would to be to get this car running, and while it's on it's second block; save up some money for a build when the time comes again, possibly during next winter because they suck here in Chicago.
#49 |
Drives: 13 BRZ Limited WRB
Why take the motor apart before you have it out?
What kind of tune were you running on the car when it blew? My vortech just ate my 2nd engine, so i'm in the same boat. Although I didn't have catastrophic failure like you, I most likely have a ring issue. Last motor was bent rod, but I caught it quickly. As of last night i'm ready to yank it. Thankfully this motor is a breeze to pull out. You don't have to remove the rad / condenser, but i also was dealing with a minor coolant leak so I pulled it all anyways.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#50 | |
BoostedBRZ
Drives: Turbo BRZ
I am still perplexed to this day how/why i had catastrophic engine failure upon deceleration. PS if you still haven't pulled your motor; don't be like me and forget the two ground wires underneath the engine screwed into the frame on both sides towards the front. I forgot to unbolt those and they got ripped when I pulled my engine. Good luck with future build!
#51 |
BoostedBRZ
Drives: Turbo BRZ
Update!!! Picked up the motor yesterday. Time to give the brz it's second life.
![]() ![]() Sent from my PH-1 using Tapatalk
#52 |
That another used motor then?
#53 |
BoostedBRZ
Drives: Turbo BRZ
correct. just going to run it as is and hope for the best. if the second one blows then I'll either have to LS swap or K swap unfortunately. To be honest, I don't really feel like building an FA20.
#54 | |
It was May when my first engine went, and I just wanted to get back on the road. So far, building the FA hasn't been bad. Spent about $4k so far on parts, but hopefully I won't have to do anything but rebuild heads in 50k or so.
#55 |
BoostedBRZ
Drives: Turbo BRZ
Sneak peak...
[IMG]https://uploads.tapatalk-cdn.com/20180104/42ed511333b22a***ad4fbb7cf862f62.jpg[/IMG] ![]() Sent from my PH-1 using Tapatalk
#56 |
Killed Scion
Drives: 2013 FR-S Whiteout
Will you be running their Ver.2 kit?
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| Team BRG build - 8R6 FRS | 8R6 | Member's Car Journals | 92 | 08-09-2017 07:33 PM |
| GridLife 2015 | Shark_Bait88 | Great Lakes | 0 | 05-11-2015 03:07 PM |
| Pete's Perrin Vortech build thread | Pete | Member's Car Journals | 91 | 06-04-2013 01:38 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
