Old 06-28-2016, 08:16 PM   #1
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Ordering Bump Stops for TRD Lowering Springs PTR07-18130
I'm trying to order the accessory package that comes with the TRD Lowering Springs for the FR-S (PTR07-18130), that includes bump stops and locking nuts. Is there a separate part number for the package that comes with the springs, or do you need to order them all separate? I tried ordering them thru a Toyota dealership but they can't help you unless you know the part #s. Any help would be great. Thanks!
MJones_RB is offline   Reply With Quote
Old 06-30-2016, 02:05 PM   #2
Vital
Drives: 2015 BRZ
https://www.amazon.com/Genuine-Toyot...rd+springs+frs
just get it from Amazon it will be cheaper than getting it from the Dealership and this should include everything you need
Old 10-19-2017, 10:11 PM   #3
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Anyone able to find a part number for the bump stops?
I'm mainly looking for the rears. Maybe I could just cut the stock rear bump stops?
ApexEight is offline   Reply With Quote
Old 10-19-2017, 11:14 PM   #4
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
Just cut the rear bump stops. I bought my TRD springs used and I just cut my stock bump stops in half. Never had a problem since. 20k mi on the springs.
Jollibee86 is offline   Reply With Quote
Old 10-19-2017, 11:52 PM   #5
DAEMANO
Time Traveller
Better to buy replacements than go this route.
The bump stops (jounce bumpers) as designed in this car are considered an active part of this car's suspension system (meaning it's meant to actually ride on the progressive tip of the bump stop during times when the factory springs is compressed (even by just centimeters.) They do much more than just prevent the suspension from bottoming out metal on metal. Cutting them alters the way the car handles at the limit and is not recommended.
Old 10-20-2017, 08:22 AM   #6
ApexEight
Which replacments do you recommend that I get? @DAEMANO ?
The guy I bought the TRD springs from claims that they only came with new front bump stops and also did not include the new nuts. He said he's been running them with the stock rear bump stops with no issue. They were too good of a deal to pass up so I bought them. If I can't find a part number or good replacement, I'm not sure what would be better: running the stock stops or cutting them.
@Racecomp Engineering I know this is kind of a competing product but perhaps you could chime in with your expertise?
Old 10-20-2017, 11:11 AM   #7
I would check with Eibach USA. If that doesn't work, let me know.
- Andrew
Old 10-20-2017, 11:58 AM   #8
ApexEight
- Andrew
Just gave them a call and they said each bump stop would cost me $21 lol. No way I'm doing that.
He did say the rears are 35mm long and I could possibly just trim mine down. Thoughts?
Old 10-20-2017, 12:56 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Experiment, put them in without cutting, if you're happy leave em, if the rear rides rough cut a section out, rinse, repeat, make clean cuts and you can put a section back in playing with combinations of the three different sections to get the comfort or handling balance you want.
ineedyourdiddly
Old 11-10-2017, 12:20 AM   #10
JoeyBareBones
Drives: 2017 BRZ Sport Tech
I had a local shop install TRD springs on my BRZ. They didn't use any of the hardware that came in the box. They simply replaced the springs and used all OEM hardware including the stock bumpstops. Should I be concerned?
JoeyBareBones is offline   Reply With Quote
Old 11-10-2017, 07:56 AM   #11
ApexEight
You're probably fine. Have you felt the suspension bottoming out on the bump stops?
Why is it so important to cut the bump stops when lowering my frs? corvino26 Scion FR-S / Toyota 86 GT86 General Forum 5 12-17-2014 11:47 AM
FS: Like new Tein S-Tech lowering springs -1.4" Drop w/ Custom Bump Stops STS-V Brakes, Suspension, Chassis 6 07-31-2014 07:43 AM
SWIFT Spec R Springs - Bump stops project d Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-03-2014 08:25 PM
Lowering springs and bump stops survey solidONE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-27-2013 11:23 PM
Swift Springs: Cut OEM Bump Stops? BillY2KFRC Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-22-2013 01:45 PM
