Old 10-20-2017, 09:49 AM   #2955
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
So, after 4 years it looks like my stock battery is starting to die. Seems like a good time to replace it with a lightweight battery. What's a good lightweight battery that can still be used in winter? My FRS is garaged, so temps don't usually drop below 40F in there during the winter. I was considering the Shorai LFX36L3-BS12, but wanted to see if there's a better option.
smg1138 is offline   Reply With Quote
Old 10-20-2017, 10:37 AM   #2956
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I was afraid of roasting a $200+ battery with my DD short commute, put in an Odyssey PC680 a few weeks back, may be a bit overkill, but at ~15 lbs it's still 15 lbs lighter than stock and only a little over $100. Been good so far but was going to wait a month or so just to be sure.
ineedyourdiddly
smg1138 (10-20-2017)
Old 10-20-2017, 03:11 PM   #2957
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I have used this one for the past 2 years LFX24L3-BS12. Survived the Denver winters just fine. Which might not be saying much 'cause it doesn't get super cold here that often. I have a PC680 too (in my BMW), the Shorai requires much less maintenance charging.
justinco is offline   Reply With Quote
The Following 2 Users Say Thank You to justinco For This Useful Post:
smg1138 (10-20-2017), strat61caster (10-20-2017)
Old 10-20-2017, 06:16 PM   #2958
cjd
cjd's Avatar
Drives: 2017 BRZ
I have a Shorai and keep it on a tender any time I'm parked at home. While I don't really drive in the winter, I have done so where the car sits for ~10hrs in a field in the cold, and no troubles starting.
I've never had it fail to start up quickly, but if I'm out on a very short trip (especially if I leave the cameras on while parked) - the battery voltage evidently dips below what the tender likes to see and freaks me out with the "recovery" mode... but it always happily goes to maintenance mode if I go make it happen after a few hours... and when I've forgotten, does so days later too. Battery still handles over-nights and multiple days off the tender (including a road-trip where I went at least 60 hrs without driving the car).
I'm sure some day it will decide "ENOUGH!" and leave me stranded somewhere, but that's true of most batteries.
C
Old 10-20-2017, 06:42 PM   #2959
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I never put mine on a tender unless I'm gone for over a week. I've even let the car sit for a week and the Shorai still cranks it right over. It died on me once, but I think I left an interior light on or door didn't shut all the way. Otherwise it has been maintenance free.
Old 10-22-2017, 08:35 PM   #2960
smg1138
smg1138's Avatar
Dang, I'm just as confused now as I was before. I drive my car pretty much every day, so I think the Shorai will be ok. And since my car is garaged at home and work, I don't think the temps will be an issue this winter. If Colorado temps don't present an problem, I doubt Nashville temps will.
The Following User Says Thank You to smg1138 For This Useful Post:
strat61caster (10-26-2017)
Old 10-26-2017, 11:47 AM   #2961
smg1138
smg1138's Avatar
I was actually able to recharge my OEM battery by adding distilled water to the cells. Didn't even know you could do that before. The slow starts have gone away for now. Will probably get a Shorai battery next spring for weight savings though.
Old 10-26-2017, 04:59 PM   #2962
strat61caster
I regret my decision now
Oh well, saved $100 in the near term and can play with mounting options with the shorai in mind for the future.
ineedyourdiddly
Old 10-26-2017, 05:23 PM   #2963
M0nk3y
I’ve been running a Battery Tender battery this whole season, largest size available (5.x lbs battery and mount combined). I’ll throw it on the charger if the car sits for 3-4+ days, but other than that I’ve been DDing it everyday. Sat at Nats throughout the week after the Pro Finale and started up with no issues.
Kyle H. - #89 STX
Old 10-30-2017, 11:01 AM   #2964
cjd
cjd's Avatar
Drives: 2017 BRZ
So... shit being what it is...
Is the fancy factory BBK on the BRZ PP worth anything at all if I have the AP Sprint off the old car? Obviously the wheels and shocks aren't of particular value to me at this point since almost everything I already have is also going to move to the new chassis. Header (Nameless) is probably not worth the risk given impact was right in the middle front and it definitely was pushed into the dipstick (can't tell yet if it hit the pulleys at all), and the GS intake box is a bit crushed...
Pondering what else is worth doing differently the second time around as well.
C
Old 10-30-2017, 11:08 AM   #2965
Racecomp Engineering
C
I'd assume the AP sprint BBK is a good bit lighter than the OEM Brembos, so there's that.
EDIT: And sorry to hear about the car.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
cjd (10-30-2017), G_Ride (10-30-2017), Shark_Bait88 (10-30-2017), strat61caster (10-30-2017)
Old 10-30-2017, 11:17 AM   #2966
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
- Andrew
There was a thread/reply on the forums here somewhere, that covered the Sprint kit benefits over the new PP Brembos.
I can't seem to find it atm, but basically the AP Sprint kit is a much better setup.
The Following User Says Thank You to justinco For This Useful Post:
cjd (10-30-2017)
Old 10-30-2017, 12:42 PM   #2967
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ooh, I found it @cjd
http://www.ft86club.com/forums/showp...7&postcount=18
cjd (10-30-2017)
Old 10-30-2017, 12:57 PM   #2968
ryan t
Drives: frs
now that its getting cold, is the ECS still the best tire for sub 50 degrees?
ryan t is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
