Old 10-16-2017, 04:25 PM   #4201
bem75
Round 3 Racing
bem75's Avatar
Drives: Scion FR-S race car
Yes, I searched. If it is here, I didn't find it.
I need a dyno comparison between the standard JRSC pulley on gas (98 or 100 preferred, but 93 okay) and the high boost JRSC pulley. Same fuel requirements. No E85.
If you don't want to post, please consider sending to me via PM or I can give you my email address. This is for confidential discussions with SCCA to consider allowing the high boost pulley in my class. The dyno info will not be released. It will be used by the rules committee at SCCA which is bound by a confidentiality agreement.
It doesn't even need to be an overlay comparison. What I really need is the dyno chart for the high boost pulley (C38 preferred) on gas.
bem75 is offline   Reply With Quote
Old 10-17-2017, 10:07 AM   #4202
bem75
Round 3 Racing
bem75's Avatar
I found this and it seems to match what I have been told verbally.
http://blog.vittuned.com/tag/frs/
The Following User Says Thank You to bem75 For This Useful Post:
CSG Mike (10-17-2017)
Old 10-17-2017, 01:54 PM   #4203
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
http://blog.vittuned.com/jackson-rac...ft-86-fr-sbrz/
This is my car and is your best bet
Jmonty is offline   Reply With Quote
The Following 3 Users Say Thank You to Jmonty For This Useful Post:
bem75 (10-17-2017), CSG Mike (10-17-2017), sachu (10-17-2017)
Old 10-17-2017, 02:37 PM   #4204
CSG Mike
CSG Mike's Avatar
Don't forget this car also has supporting mods in addition to the C38 kit.
Jmonty (10-17-2017)
Old 10-17-2017, 04:00 PM   #4205
southside iraq
Drives: 2017 86
anyone have any experience with the C38 with RS pully, in term of power gains?
southside iraq is offline   Reply With Quote
Old 10-17-2017, 05:59 PM   #4206
BayBRZ
Drives: Subaru BRZ
Tried searching thread but not yielding results
Those of you on a carb tune on 91 CA gas- how much whp are you pushing?
'16 SWP BRZ
BayBRZ is offline   Reply With Quote
Old 10-17-2017, 06:15 PM   #4207
CSG Mike
CSG Mike's Avatar
245 is pretty typical.
BayBRZ (10-17-2017)
Old 10-17-2017, 06:31 PM   #4208
BayBRZ
Drives: Subaru BRZ
Thanks Mike
Paired up with a FlexFuel kit, E85 and a proper flash/tune, would there be a significant change in reliability? I've heard E85 runs cooler, but an increase in power should negate that?
Looking to go this route in near future, will def shoot you a PM when ready
'16 SWP BRZ
Old 10-17-2017, 06:38 PM   #4209
CSG Mike
CSG Mike's Avatar
Thanks Mike
There is always a risk to increasing output. E85 will bump your output a solid 35-40whp, even with no other powertrain changes. For general street use and light spirited use, JRSC + E85 has been proven to be pretty reliable.
You will need a clutch, MAP sensor, injectors and fuel pump to go with the E85.
Old 10-17-2017, 11:43 PM   #4210
Jmonty
Looking like in the next few months I could tell you
The Following 2 Users Say Thank You to Jmonty For This Useful Post:
rns294 (10-18-2017), southside iraq (10-18-2017)
Old 10-19-2017, 10:11 AM   #4211
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
If this is a straight up comparison of the 110 pulley vs the 100 then I would really like to source a compatible 90mm pulley and lower the redline.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 10-19-2017, 10:25 AM   #4212
CSG Mike
CSG Mike's Avatar
http://counterspacegarage.com/produc...r-rs-gt86.html
Jmonty (10-19-2017)
Old 10-19-2017, 03:26 PM   #4213
Deep Six
Deep Six's Avatar
Unfortunately I have a C30 at the moment. Is that a 90mm pulley by chance?
[SIGPIC][/SIGPIC]
Old 10-20-2017, 01:14 AM   #4214
CSG Mike
CSG Mike's Avatar
It is! I'd recommend a 6500 RPM redline with it on a C30.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
