Old 10-17-2017, 02:55 PM   #15
funwheeldrive
Originally Posted by Detroiter View Post
I agree with all of these statements but one thing to keep in mind when thinking about the 718's flat 4 turbo is potential with just a tune.
I haven't looked into what tuning there is for them but generally a factory turbo car will make pretty impressive gains with just a tune and even more with exhaust components whereas a NA car will struggle to get very much from it.
Meh, I'll take a healthy NA 6 cylinder over a high-strung 4 cylinder any day.
The Following 3 Users Say Thank You to funwheeldrive For This Useful Post:
Ganthrithor (11-21-2017), strat61caster (10-18-2017), WolfpackS2k (10-18-2017)
Old 10-18-2017, 12:30 PM   #16
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Unlike a Subaru, Porsche replacement engines and transmissions are obscenely expensive. $15-20k for an engine, $10k for a transmission - roughly speaking. Sure they're strong, but personally I wouldn't crank up the boost like it's some inexpensive (relative) Japanese manufacturer engine.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
Old 10-18-2017, 02:07 PM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Have you ever owned a car with the boost cranked up?
imho it's not all it's cracked up to be, yeah the dyno numbers look impressive but the lack of responsiveness is underwhelming to me. Riding the 'boost wave of torque/power' is certainly fun but that's not what I enjoy out of a car and certainly not what I would buy a Porsche for (despite the 930's reputation).
If I ever own a turbo car I probably won't do more than a catback exhaust, which on some cars opens up a noticeable amount of power.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
nikitopo (10-19-2017), WolfpackS2k (10-19-2017)
Old 10-18-2017, 06:49 PM   #18
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Yes I have, Prior to owning my FRS I had a Audi A4 with the 1.8t. Stock the car is sluggish as hell and no fun to drive at all. and with 170chp 170ctq how could it be. But with just a tune on a otherwise stock car it bumped it to 215chp and 250ctq. And the actual gains were under the curve. The car now made peak torque around 2.5k rpms and held it all the way to 5k. It was 1000 times better than the stock car and was by far a much greater difference than my FRS going from stock to e85 header tune with full exhuast.
That wasn't even the end of it as just by putting in a cat delete, bigger injectors, and an e85 tune the tuner quoted it as making 250chp and over 300ctq now if a 80hp and 130tq bump from very simple bolt ons and tune aren't impressive I don't know what you will think is.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
funwheeldrive (10-18-2017)
Old 10-18-2017, 06:52 PM   #19
Detroiter
Detroiter's Avatar
I completely understand this. That is why you don't go crazy putting a big turbo on one. A reflash tune from a reputable and top of the line tuner will not cause any issues. It's the same as with any car. The tuner has tested the limits of stock equipment and will dial it back for a safe and enjoyable upgrade.
Raven
Old 10-18-2017, 06:59 PM   #20
strat61caster
I don't doubt the gainz bro
I doubt how rewarding and fun it is to drive around a corner when you've got monster lag to get back to maximum power.
ineedyourdiddly
Old 10-18-2017, 08:46 PM   #21
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If it's the stock turbo, there's no more lag with an aggressive tune than there was when everything was 100% stock. In fact, there may be less. There may be more perception of lag simply because running more boost results in higher peak power, but there's no reason running more pressure from the same compressor would somehow result in more lag.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 10-18-2017, 09:04 PM   #22
strat61caster
Yes, that is what I mean, I don't find that an enjoyable experience, while I know many seem happy with that kind of setup it doesn't please me and I know there are a few who agree.
There's no lag to the original boost/power levels, but you've likely upgraded the grip available as well which means that no-lag to stock boost/power is irrelevant, it's now the lag to the increased power that's of concern. It takes longer to spool to the new maximum boost than the old maximum boost, you can't break the laws of physics no matter how good the tune is.
Edit: A different driving style makes this not a problem, early back to the gas, left foot braking while still on the gas to keep the boost up, whatever, I just don't really like it. Some do, that's fine, but I bought into the hype of 'just crank up the boost, it's great!' until I tried to drive fast with a car tuned like that. I just didn't really like it and I think it's worth asking when someone starts beating that drum. It's one of the reasons I'm very happy with my FR-S.
ineedyourdiddly
Old 10-18-2017, 10:36 PM   #23
new2subaru
Weight Weenie
Drives: 15 FR-S
I think, I've finally decided to boost the Fr-s and you post this...
Old 10-18-2017, 11:23 PM   #24
strat61caster
Well my experience isn't in an FA20, just because I'm not a huge fan of boost doesn't mean you won't be, and my experience is primarily turbo based, supers may be up my alley. Best of luck.
ineedyourdiddly
Tcoat (10-19-2017)
Old 10-19-2017, 02:57 AM   #25
Detroiter
Detroiter's Avatar
Okay I get what your saying now. Yes a turbo car can have a noticeable amount of lag depending on the size of the turbo to displacement. From my experience in the B6 A4 came with one of the smallest turbo's in existence and spooled essentially instantly. As long as I was above 2.5k I would mash the throttle and instantly feel the torque. The lag that was there I'd equate to the instant you hit the pedal I had 85% of torque, then that last 15% would come in over a short 1/4 - 1/2 second period.
I actually think it equates very well to a motor like the fa20 where all the power is at redline. Rather than feeling the power build as you push to the limiter you feel it build in the mid range just quickly and then it eventually dies off up top (downside of a small fast spooling turbo). At least in my driving it was felt like a similar sensation especially with slightly bigger turbo like in my friends sti. The longer amount of lag allowed the torque to build up in a natural and smooth way just like a high sprung NA motor just earlier on in the power band.
Raven
Old 10-19-2017, 07:08 AM   #26
new2subaru
Weight Weenie
Drives: 15 FR-S
What you wrote rings true to my ears. Unfortunately, I still feel the car is lacking, just a tad...I'm not sure if a header/tune will get it where I'd like it to be. The only way to find out is to go for it. I should go test drive a MY17/18 first.
The Following User Says Thank You to new2subaru For This Useful Post:
funwheeldrive (10-19-2017)
Old 10-19-2017, 08:01 AM   #27
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Originally Posted by perryair View Post
for anyone who changed from a twin over to a last generation cayman (not the s), how do you find the difference in driving experience? it seems like it would be somewhat familiar, with 275 hp and 213 tq - that youd need to wring the power out in revs and that you'd really have fun throwing it around corners. and certainly its a more expensive car, but a few year old model is around the price of most new entry level luxury sedans/crossovers these days..
i really enjoy my brz and it provides tons of joy, but just thinking of what the next car will be when it comes time!
Just remember to consider running and maintenance cost.
For example, for this same pricing, you can get a c5z06. In general, it is cheap to maintain. However, compared to a BRZ, the amount of oil used, clutch reservoir maintenance and 3x more expensive tires make the running costs far exceed the BRZ.
Also, while I don't have direct experience with the Cayman, I am going to assume the gearing per gear is very wide. This just means the experience you are going to get on the street is going to be very different. All the updated power you aren't really going to be able to use.... or be able to use legally for long. This is something you have to do beyond the honeymoon-phase to understand what the difference really means.
Good luck in your quest.
2013 Boxster S
Ratio. Max speed (rpm)
3.91:1 44mph (7800)
2.29:1 75mph (")
1.65:1 104mph (")
1.30:1 132mph (")
1.08:1 159mph (")
0.88:1 172mph (6850)
0.62:1 172mph (4825)
LSD diff
Final drive ratio: 3.89:1
dowroa is offline   Reply With Quote
Old 10-19-2017, 09:28 AM   #28
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I'd be curious to see the dyno curves overlaid between the 718 and 981. I would imagine the difference in low and mid range torque would be substantial. Whether or not you care for the aural aspects of the modern turbo 4's you can't deny the improvement in acceleration capability. Lap time magazine comparisons really illustrate the difference.
Lighting Lap:
2014 Cayman S 3:02.6
2917 Cayman S 2:58.3
2017 Honda Civic Si 3:14.6
2017 BRZ 3:19.7
Tuning just increases the disparity if you are willing to roll the dice. I have an APR tune on my wife's TTS and the car runs 0-60 in 3.8 seconds on a V box and will pull bus lengths on my supercharged FRS. Honestly I'd love to have the power delivery from my Audi 2.0l available in the Scion.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
BRZ vs Cayman/Corvette Norcalkid FR-S / BRZ vs.... 128 01-31-2017 01:36 PM
Twins vs Cayman/Boxster 211 botbs FR-S / BRZ vs.... 15 10-06-2014 11:09 AM
2013 981 Cayman ironchef Other Vehicles & General Automotive Discussions 49 12-09-2012 08:03 PM
FR-S vs Cayman colganc FR-S / BRZ vs.... 102 09-13-2012 05:17 PM
GT86 vs. 370 vs. Cayman S wrxgoose FR-S / BRZ vs.... 0 08-28-2012 12:26 AM
