22R
Drives: 2012 Camry SE 2017 Toyota 86
Exhaust Research question
Hi, I have a 2017 86. I just bought a Open Flash Tablet and I am waiting for it to come in. The only other mods I may do are a drop in air filter and a Header. Which non catted header UEL would give it the best sound but not make it loud. I guess in other words I want to enhance the boxer rumble but not be loud. Any tips ?? I am plan to keep everything else stock behind the header if I do get one. Thanks for any tips.
22R |
#2 |
Drives: 2013 Scion FR-S 6M Argento
Any catless header will be louder than a catted, and a aftermarket catted header will still be louder than stock. The difference isn’t much, and with a stock exhaust nobody will likely know it didn’t come that way from the factory. If you’re using an OFT I’d recommend using their UEL header, otherwise I’d recommend JDL.
| The Following User Says Thank You to Jrdad For This Useful Post: | 22R (10-17-2017) |
#3 |
You should consider getting a new overpipe as well. Relative to the OFT and headers it doesn't cost much. You'll be in the area of the overpipe as well taking out the headers. Stock overpipe is definitely one of the worst parts of the exhaust imo, maybe even the worst given how complicated it is to design headers
#4 |
Drives: 2014 Scion FRS (Asphalt)
All catless headers are around the same volume because they are essentially pipes with bends. It's like asking which straight pipe is louder/quieter, they're all going to be about the same volume if they're the same diameter.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#5 | |
#6 |
22R
Appreciate all the replies Guys. I am enjoying learning as I go about the 86.
22R |
#7 |
Drives: 2016 BRZ Limited
Can we talk more about the necessity of the overpipe? I just snagged an OFH/OFT and a TRD cat-back. Not sure if I want to grab an overpipe before I go through with the install.
#8 |
Drives: BRZ SWP Limited -6MT
largely because u have to unbolt one side (if not both) to get the header off. a/m units are likely less restrictive for flow. top speed sells the piece for 100 bux vs others for 300+.
#9 |
http://counterspacegarage.com/csg-competition-gt86.html
The CSG Touring 86, with a catless setup, will be quiter than a TRD or Perrin unresonated on an otherwise stock car. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Lust (10-21-2017) |
#10 | |
#11 | |
Generally you get what you pay for |
| Need Help w/ Research on Noblesse Center Exhaust | Echiwa | Engine, Exhaust, Transmission | 7 | 07-20-2018 02:15 PM |
| BRZ exhaust system research - Portland, OR | darnoc | Engine, Exhaust, Transmission | 16 | 03-27-2016 05:28 PM |
| Research help! | Poogles | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 04-15-2013 07:58 PM |
| DD Performance Research tuned | *KID* | Engine, Exhaust, Transmission | 9 | 03-18-2013 01:45 PM |
| Maritz Research Study? | Marcoscrdo | Mid-Atlantic | 18 | 03-14-2013 01:40 PM |
