Old 10-16-2017, 01:48 PM   #1
Ron Reefman
Drives: 2017 Toyota 86 Oceanic Blue
Auto-x in CS
I have a turbo Miata and ran SSM just for fun. I know the 2016 & 17 Miata's do a bit better than the FRS or BRZ in C Street. I just got a 2017 86 with a 6 spd and intend to run C Street with it.
So will the 2017 do any better than the FRS or the BRZ? Only 5 more hp and 5 more ft/lbs of torque, but the 4.30 diff might make it a bit quicker?
I'd like to hear anybody's comments.
Ron Reefman is offline   Reply With Quote
Old 10-16-2017, 02:04 PM   #2
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The TRD wheels for the 2017's are a 1/2" wider and the FD should help dig out of corners better than the previous versions. I expect the 17's (with the TRD springs and wheels) to close some of the gap with the ND Miata's.
Twinz is offline   Reply With Quote
Old 10-17-2017, 09:34 PM   #3
Shackelford
Drives: Gray
So to confirm, the TRD parts (Springs, bars and wheels) ARE still legal for use on 17’s? So the 86 would still be favorable over a BRZ?
Shackelford is offline   Reply With Quote
Old 10-17-2017, 09:41 PM   #4
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The BRZ can use the performance package parts, I'm not sure which is better.
I don't think either is going to compete with the ND's.
Get an older twin and go play in SSC. If I were starting today, that's where I'd go. You can't get much better than a spec class for a level playing field and an easy way to prep a car.
14stu is offline   Reply With Quote
Old 10-17-2017, 09:57 PM   #5
Twinz
Twinz's Avatar
Yes.
From the CS classing section of the rule book:
"Toyota
86 (including TRD Lowering
Springs, TRD Sway Bar Kit,
and TRD 17-in. Forged Wheel)
(2017)"
The Following 2 Users Say Thank You to Twinz For This Useful Post:
Shackelford (10-17-2017), strat61caster (10-18-2017)
Old 10-18-2017, 12:11 AM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Local - you'll do just fine with the right tires and good driving skills, the fastest CS car to show at nationals from Florida was a 2016 BRZ so there's probably not an impossible to beat Miata near you.
National - nobody has tried it yet, that doesn't mean it isn't possible
Don't overthink it, go play and have fun. Get OE crash bolts and an alignment, max out front camber with that part, zero out the toe.
ineedyourdiddly
Old 10-18-2017, 07:25 AM   #7
Twinz
Twinz's Avatar
Small correction, it's a 2016 *FRS* (with TRD stuff).
The Following User Says Thank You to Twinz For This Useful Post:
HT auto (rep) lip kit - FRS $220 OBO Apples_ZN6 Canada Classifieds 4 04-26-2017 10:37 PM
SF Auto Show/Auto Salon PMok Northern California 30 12-04-2015 08:53 PM
A/C question: what's the difference between auto and full auto? chenshuo BRZ First-Gen (2012+) — General Topics 29 08-16-2013 04:37 PM
FS: HT Auto lip kit for FRS bisdak Exterior Parts (Aero, Lighting, Etc.) 23 06-28-2013 07:37 PM
Auto-X rbrtndrws FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 06-05-2012 05:59 PM
