Old 10-17-2017, 03:04 PM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Unboxing my MCS 2-way remote suspension system
After being on RCE T2's for a couple years, I felt like a change and trying something new. In comes a set of MCS 2-way adjustable coilovers with remote reservoirs. This is my first set of remotes I've ever had, and one of the main reasons for the upgrade. I will miss my T2's as they have been great, but looking forward to trying out the new setup. So far, the kit looks top notch with great support from MCS!
[ame]http://www.youtube.com/watch?v=CfFVvyWN-C8[/ame]
justinco is offline   Reply With Quote
The Following 4 Users Say Thank You to justinco For This Useful Post:
dowroa (10-17-2017), FirstWinter (10-17-2017), rcm47 (10-20-2017), Teseo (10-17-2017)
Old 10-17-2017, 05:46 PM   #2
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Nice!
Interested to see how you decide to route the hoses and mount the canisters.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
justinco (10-17-2017)
Old 10-17-2017, 05:51 PM   #3
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by ILLSMOQ View Post
Nice!
Me too 😂
Old 10-17-2017, 06:08 PM   #4
imnotsureaboutbrz
Drives: between cars...
subscriber giveaway for the RCE T2's?
imnotsureaboutbrz is offline   Reply With Quote
The Following User Says Thank You to imnotsureaboutbrz For This Useful Post:
rcm47 (10-20-2017)
Old 10-17-2017, 06:16 PM   #5
FirstWinter
Drives: Car
Nice! Interested in how you like these compared to the RCE Tarmac 2's. Looks like there's plenty of experimenting with adjustment to get what you want during this off season. Think you can mount the external reservoirs on the strut braces for the front (if it's long enough) and in the trunk through the vents for the rear. I'm guessing the surprise are some new Taiwanese headers
FirstWinter is offline   Reply With Quote
Old 10-17-2017, 06:36 PM   #6
Pat
Pat's Avatar
Drives: 2023 BRZ
I'll be interested to hear what you think of how they compare to T2s. Robbie replaced his T2s with MCS singles recently and said the difference was noticeable, but not big.
Old 10-17-2017, 07:26 PM   #7
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Sure, the entry cost to the giveaway is $1500
Yea, I have an idea of where to mount them, just have to get in there and see what I can do.
I remember talking to you about that at HPR the other weekend. We will see soon enough!
The Following User Says Thank You to justinco For This Useful Post:
imnotsureaboutbrz (10-17-2017)
Old 10-20-2017, 05:27 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
justinco (10-20-2017)
Old 10-20-2017, 03:20 PM   #9
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks for the photo.
I have seen others mount the reservoirs on the inside of the car. That is what I will be shooting for (in the rear).
Old 10-20-2017, 03:45 PM   #10
e1_griego
e1_griego's Avatar
Drives: Many
I mounted mine in the spare tire well. Had to dismount the tire from the wheel because there's not enough room (and i wanted to keep using the wheel to support the weight of the trunk floor) but I like that the reservoirs are out of the way from contact with anything.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
Old 10-20-2017, 04:10 PM   #11
Captain Snooze
Drives: Red Herring
I would have liked to have done that with the ASTs but it looked like too much trouble. I don't know why the hose couldn't be mounted on the top of the shaft like the fronts were. *shrug*
Old 10-20-2017, 07:05 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The cannister has to be attached to the damper body, not the damper piston shaft.
Front struts on the AST are inverted like this picture so the 'top' is the damper body. Rear has the body on the bottom attached to the LCA, the 'top' of the rear is actually the damper piston. A "remote reservoir" basically moves the blue area in Tein's diagram to the cannister per the 2nd picture below.
MCS like Justin has is non-inverted front struts so the reservoirs are on the 'bottom' but have the same configuration on the rear. It's why Justin comments about the thick shaft on the MCS, that shaft takes the entire load of the front suspension, the KW/RCE is the same design.
As far as I know nobody has an inverted rear for this car, not impossible, but clearance is trickier and your shaft is at higher risk of getting contaminated which would lead to premature leaking and seal wear. It's probably better to just go to both adjusters on the piston shaft like Bilstein has, but that's just as pricey if not moreso than remote reservoirs.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
Captain Snooze (10-21-2017), gtengr (10-21-2017), justinco (10-20-2017), Racecomp Engineering (10-21-2017)
Old 10-21-2017, 02:56 AM   #13
Captain Snooze
Drives: Red Herring
The cannister has to be attached to the damper body, not the damper piston shaft........
Excellent explanation, thank you.
Old 10-23-2017, 09:19 PM   #14
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Good point on where the hose is mounted. Although I have seen MCS remotes mounted in the trunk, @M0nk3y will help me
Beatrush Suspension Products (Unboxing, Install, & Review) zeal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 07-14-2017 11:59 AM
The ISC Suspension-NA N1 Coilover System for the BRZ/FRS ISC Suspension Brakes, Suspension, Chassis 17 04-29-2014 09:56 AM
EasyGo system. Car remote starts then shuts off Unsustainable Electronics | Audio | NAV | Infotainment 3 06-27-2013 08:42 PM
