Old 07-05-2012, 05:04 PM   #267
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
Not keep the other set? You plan on driving on summers all year?
If he lives here in Southern California he could drive on summers all year long. A normal winter day in my zip code(90020) is high in the mid 60's and low in the high 40's.
WillRacer1jz is offline
Old 07-05-2012, 05:16 PM   #268
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
So car had no boltons during baseline and STG1 flash.. Now has a header, waiting to hit the dyno again
John
Gotcha. Can't wait for results. Do you know which header he has installed?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline
Old 07-05-2012, 05:29 PM   #269
RWD-boxer
RWD-boxer's Avatar
Drives: Black
No tune needed ... K&n and unbolt muffler
RWD-boxer is offline
Old 07-05-2012, 05:30 PM   #270
RWD-boxer
RWD-boxer's Avatar
Drives: Black
Also just pushing the sport switch is huge no more hump on graph
Old 07-05-2012, 06:55 PM   #271
Visconti
Drives: 05 STi
What?
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
civicdrivr (07-05-2012), jedibow (07-06-2012)
Old 07-05-2012, 07:01 PM   #272
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Originally Posted by serialk11r View Post
If they leaned out the high load cells and didn't touch the stoichiometric areas, if anything it should be better for lead foots and unchanged for most people right? If you're going to change fuel economy the low load areas need to be changed. For example dropping cruise AFR to like 18:1 with increased throttle position would give a noticable fuel economy improvement (and a lot of NOx).
In theory yes, however once you are in closed loop operation the sub routines become a nightmare, a little change here, effects way over there type of situations. It takes time, gas, more time, and more gas. The O2 sensors are always aiming for stochimetric when under closed loop operation, now one could change the load change over point in the cruising areas, say 1500 to 2500 RPM, loads 20-40 to drop closed loop, then the ECU will revert back to fuel calculations instead of O2 feedback, then you can truely gain economy say 3 to 5 mpg, but there is a risk even in this because you will be running the engine at higher operating conditions due to the lean AFR, so CATS start breaking apart, cooling systems start to fail... you get the idea
G
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline
Old 07-05-2012, 07:52 PM   #273
Dimman
Kuruma Otaku
Dimman's Avatar
Hmm... 18 whp from a tune on a NA car is pretty spectacular.
Interesting.
Because titanium.
Dimman is offline
Old 07-05-2012, 08:30 PM   #274
serialk11r
Drives: '06 AM V8V Coupe
G
Even if you completely avoid the 1.05-1.15 equivalence range where the temperature is greatest? When it switches to open loop the fuel trims are still there, and at 50% load even running a bit lean isn't a big deal, at which point you tell it to switch to stoichiometric and everything is all good. At 18:1 (1.2 equiv) you're at about the same peak temperature as stoichiometric.
It's possible to go much higher but at that point you'd need to be really adjusting timing too, and it would be much harder to figure out the corrected throttle position for the same requested torque level.
serialk11r is offline
Old 07-05-2012, 09:40 PM   #275
cruzinbill
Drives: Argento 6spd FR-S
No I just use all seasons all year long.
cruzinbill is offline
Old 07-05-2012, 10:04 PM   #276
jedibow
at 18 to 1 detonation is an issue unless you adjust the timing, correct, but you also have to worry about pre ignition, I don't know if the cylinder head has a proficient design to avoid this.
jedibow is offline
Old 07-05-2012, 10:05 PM   #277
Visconti
Drives: 05 STi
Can you please post the actual dynojet files or post a new graph with SAE correction factor and smoothing of 5 which is the industry standard as I am sure you know. Did you have a tach signal? Why did you post in MPH? Also conditions of each run would be nice.
Read read read.. Smoothing 5 is not the industry standard lol
John
Visconti is offline
Old 07-06-2012, 08:26 AM   #278
arghx7
Drives: car
John
I guess it depends on your definition of industry standard... but setting a Dynojet to smoothing 0 and "STD" correction factor almost always gives the highest peak numbers
arghx7 is offline
Old 07-06-2012, 09:32 AM   #279
Visconti
Drives: 05 STi
Graph wasn't choppy to need smoothing.
Changing from sae or std didn't change the delta
I'm interested in the delta not peak numbers
John
Visconti is offline
Old 07-06-2012, 12:18 PM   #280
xcelir8brz
Drives: 2013 BRZ Limited
subscribed
xcelir8brz is offline
FS: BRZ & 86/FR-S pre-release memorabilia bambbrose Miscellaneous 16 11-19-2012 01:38 PM
SOA and BRZ Release lies SkullWorks BRZ First-Gen (2012+) — General Topics 62 05-02-2012 08:49 AM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 02:02 PM
Cellphones, Software, Transportation Toyota introduces Touch Life smartphone mirrorin quik1987 Other Vehicles & General Automotive Discussions 0 10-27-2011 03:27 AM
