Old 10-11-2017, 04:22 PM   #477
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Here's the thing on exhaust. Knowing SCCA and rules and stuff, go as light as you want (or that you can, depending on state rules and sound and all that) for an exhaust. Then, on the hangars, and/or the exhaust joints, weld on some lead/steel weights, or just on any of the pipes to bring it up to the 18lbs min weight.
Don't let exhaust weights and stuff get you wrapped around the axles on which exhaust to buy. Go with common sense, keeping in mind noise restrictions for your event site.
--kC
Imp is offline   Reply With Quote
The Following User Says Thank You to Imp For This Useful Post:
Jawnathin (10-11-2017)
Old 10-11-2017, 04:38 PM   #478
Jawnathin
Drives: Toyobaru FRZ
Yep, good advice. Was going to suggest just finding some weight to stick onto the exhaust to make it legal. Maybe some wheel weights with some heat resistant tape holding them on.
Jawnathin is offline   Reply With Quote
Old 10-11-2017, 06:41 PM   #479
DaWorstPlaya
Drives: 2016 FR-S
Originally Posted by Locust View Post
Hmmmm. I could feasibly find a slightly heavier midpipe and use the exhaust I have then... Although I don't think such a thing exists.
Why even do that? I'm thinking that you can just clamp on some weights to the Ti exhaust to make it legal now since material is open.
DaWorstPlaya is offline   Reply With Quote
Old 10-11-2017, 08:23 PM   #480
bholliday
Drives: 2022 BRZ Premium
Remember lead melts at a pretty low temperature. I don't know if our exhaust gets to that temperature, but it might be better to weld or clamp on steel or stainless steel instead.
Lead: 621 F
Steel: 2500 F
bholliday is offline   Reply With Quote
Old 10-12-2017, 08:59 AM   #481
Imp
Bring out your dead
Or, just put on a series of these?
(Seriously, they're exhaust components and around .88lbs ea.)
--kC
Old 10-12-2017, 09:45 AM   #482
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I saw someone on another site ask "what's to stop someone from adding weight" to a light exhaust to make it legal....like it would be a bad thing.
I already have a hard time caring how much other people's exhausts weigh to begin with, so *how* the exhaust makes weight is even less of a concern to me so long as It's not going to fall apart and leave parts on the course.
Twinz is offline   Reply With Quote
The Following 3 Users Say Thank You to Twinz For This Useful Post:
Cueman (10-12-2017), Jawnathin (10-12-2017), Shark_Bait88 (10-12-2017)
Old 10-12-2017, 09:48 AM   #483
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
There really are very few legal exhaust options under $1,300 where making weight should even be a concern. I think people are making far too much out of this than they need to.
If someone is going to buy a really expensive titanium exhaust, the whole purpose of which is to get a super light exhaust, only to add weights to it to make it 18lbs and think that's the solution to winning, I'm pretty sure they're mistaken on what's really holding them back.
It's particularly silly when it's easy to figure out that you can achieve pretty much as close to 18lbs as possible with a Nameless single exit muffled track pipe on the stock midpipe, which will cost you all of ~$250 new and a lot less used.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 6 Users Say Thank You to Shark_Bait88 For This Useful Post:
Cueman (10-12-2017), Jawnathin (10-12-2017), Ribface (10-12-2017), strat61caster (10-12-2017), TMF (10-16-2017), Twinz (10-12-2017)
Old 10-12-2017, 09:53 AM   #484
Bitters
Drives: Searching for next
Won't this turn into a protest nightmare with ballasting allowed (not that I am against ballasting) at nats? IE: you see someone running a titanium exhaust which would weigh under the limit, do you protest and get them to weigh all the ballasts?
Bitters is offline   Reply With Quote
Old 10-12-2017, 11:03 AM   #485
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
Considering I weigh 310 lbs I don't think I need to worry about how light my exhaust is. The real weight reduction cheat is how light can I become!
JakeRogue is offline   Reply With Quote
The Following 4 Users Say Thank You to JakeRogue For This Useful Post:
Cueman (10-12-2017), imnotsureaboutbrz (10-12-2017), strat61caster (10-12-2017), TMF (10-16-2017)
Old 10-12-2017, 11:16 AM   #486
lonborghini
lonborghini's Avatar
Drives: '15 red FR-S SSC
Originally Posted by Shark_Bait88 View Post
I think the bolded portion is the part that would make the Works axleback illegal, since exhaust gases exiting the driver's side pipe/tip will not be routed through the muffler.
So we just close off the driver's side exit. Problem solved.
lonborghini is offline   Reply With Quote
Old 10-12-2017, 11:41 AM   #487
Shark_Bait88
What's the point of even buying it then? An FT-86 SpeedFactory V2 axleback or Hooker Blackheart single exit axleback are both cheaper, very similar design, and don't require you to block anything off.
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Old 10-12-2017, 12:25 PM   #488
lonborghini
Just thinking of myself. I'm already running the Works resonated axle back.
Old 10-12-2017, 12:53 PM   #489
Imp
Bring out your dead
Sell it and put a legal one on.
--kC
Old 10-12-2017, 12:58 PM   #490
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
The FT86SF V2 axleback will require the FT86SF midpipe. The V2 axleback does not bolt on to the OEM midpipe. Just FYI for future reference.
iLuveKetchup is offline   Reply With Quote
The Following 2 Users Say Thank You to iLuveKetchup For This Useful Post:
Shark_Bait88 (10-12-2017), strat61caster (10-12-2017)
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
