Drives: Subaru BRZ
Help with picking coilovers
Hey guys, just got a 2014 BRZ so new to this forum and need a little help picking coilovers. I DD the car (about 100 miles round trip to Work and back) and I plan to do some autocross with the car (not too much just about 4-6 times a year). I want some good quality coilovers but I am on a little bit of a budget. I would like to lower the car a little more than most of you would probably approve of also. I know it will take some of the performance away and I will probally get a ton of crap for this but I really like the look of a low car. So are there coilovers out there that are in the price range of about $1,500 USD that can give me the low I want with still a decent performance for track days?
Appreciate it guys! |
#2 |
Drives: 2014 GT86
"want decent performance for track days" and "lower the car more then most would approve"? Imho those bits are exclusive. You don't care about handling and just overlower car for arguable looks, or you care about handling/performance and don't make suspension close to unable to do it's job. +If you lower car to unreasonable extent, you need more spendings to offset all the wrongdoings to suspension/geometry. LCAs or topmounts better fit for lowering that would leave at least some shock travel, roll center adjustment kits, diff riser and so on. "Quality coilovers" bought for sum that left off after deducting cost of these parts & work to install them? LOL
| The Following 3 Users Say Thank You to churchx For This Useful Post: |
#3 |
Drives: 1980 corvette, 2014 Subaru BRZ
Low
Performance Cheap Pick 2
#4 |
Drives: Subaru BRZ
Maybe I worded it wrong. I care more about the performance than it being really low. Basically what I want is as low as I can go without compromising performance.
#5 |
Drives: 2017 BRZ
I think the CSG spec Tein Flex A are a good fit. I’ll be considering those when I’m ready for coils
#6 |
Drives: Car
The CSG spec Tein Flex A are right in your budget and fit your needs. CSG is taking pre-orders for them currently.
#7 |
Wheels for Brains
There are a lot of mid entry level coil overs at the $1.5k range.
Tein Flex A and Tein Mono Sport come to mind. The Flex A is more street oriented while the Mono Sport is more track oriented. CSG is also developing a performance Flex A variant. RCE Tarmac 0/KW Variant 1/Variant 2 are also popular and have good value. It's hard to get a sense of how low you actually want to go without a reference, but I think most of the performance coilovers have lowering potential that should suit most people's needs. If you get performance coil-overs, there are usually recommended ride height adjustment specifications. If you deviate from the specifications, you'll have to dip into preload/shock travel (which is not ideal). This enables more ride height lowering at the cost of performance potential. ----- I DD my Flex A and have been pretty happy. I think they have tremendous value and perform well. Front camber plates standard was definitely appreciated |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | Clipdat (10-10-2017) |
#8 |
Drives: '13 FRS - STX
Eibach Pro-kit Springs + Koni Yellow or Bilstein B6
Alternatively: Swift lowering springs, Racecomp lowering springs |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Teseo (10-10-2017), x808drifter (10-10-2017) |
#9 | |
Drives: Subaru BRZ
Thanks for the replies, now I have somewhere to start looking.
#10 | |
Drives: between cars...
#11 |
#12 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | imnotsureaboutbrz (10-10-2017) |
#13 |
#14 |
Drives: 2015 Raven FRS
My Flex A's worked well on the street. The hyd bump stop really helped smooth out the ride.
| The Following User Says Thank You to Lunatic For This Useful Post: | CSG Mike (10-10-2017) |
| Tags |
| coilovers, suspension |
| Need help picking coilovers | Cchmelir | Brakes, Suspension, Chassis | 5 | 10-11-2017 01:33 PM |
| Picking up a 86, or maybe not... | andyzpandy | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 05-12-2015 04:04 AM |
| A little help picking a set up.... | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 11-18-2014 06:41 PM |
| Picking her up at 5! | remorse87 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-07-2012 10:51 AM |
