#576 |
Drives: Dodge Patitas
A TSB came out to replace the TOB, but only covered for 36k miles. Might want to look into getting that new TOB P/N (SU003-07349) installed rather than the old P/N (SU003-00802)
http://www.ft86club.com/forums/showthread.php?t=117440 Sent from my E6653 using Tapatalk |
| The Following User Says Thank You to sato For This Useful Post: | Ethereal05 (04-15-2017) |
#577 | |
Drives: 2015 BRZ Series.Blue
Awesome, looks I am rolling into the dealer with the TSB number...Thanks! |
#578 |
Any updates on this? I started getting the same sound, both pushing and releasing the pedal.
#579 | |
Drives: 2013 GBS BRZ Limited
I let the grease sit for a few minutes then pumped the clutch pedal for about 20-30 seconds and the creak/squeak was gone.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
| The Following User Says Thank You to BFIFE22 For This Useful Post: | wrh3 (05-28-2017) |
#580 | |
This other one is heard entirely inside the cabin. For this sound, you wouldn't hear it if you're outside and the doors are closed and someone is pumping the clutch. Anyway, I figured it out already. It's the clutch master cylinder, the internal push-rod/plunger rubbing against the inner bore as it's too dry. As per the service manual, re-grease with SILICONE GREASE G-40M or equivalent. DO NOT USE THE SPRAY SILICONE LUBRICANT, IT WILL NOT LAST. Use a toothpick or something thin with grease on the tip, push the clutch in all the way, and go ahead and grease the inside of the CMC. |
| The Following 3 Users Say Thank You to bottle For This Useful Post: |
#581 | |
#582 |
So 2 years ago I had to take my car in to get the TOB, pressure plates, etc. replaced due to this squeak...that stopped the squeak for 2 years and a couple of days ago it started again. This time it was squeaking only when I pressed on the clutch and not when releasing it. I figured it had to be the clutch fork. So I went outside, removed the rubber boot that's on top of the transmission and sprayed a generous amount of white lithium grease inside on the pivot point...squeak is gone now. We'll see for how long that lasts.
| The Following User Says Thank You to cmihaylov For This Useful Post: | sato (10-01-2017) |
#583 |
Drives: 2015 Subaru BRZ Series.Blue CWP
Seems I'm having this issue. Gonna have to take it to a dealer and hope they fix it.
#584 |
#585 |
Yeah I got the car in May and it's a MY2015 and I'm nearing 32,500 miles, so I think I'm in warranty?
#586 | |
yerp
Drives: 2015 WRX
#587 |
Drives: BR86
I lubed the clutch fork pivots & TOB as best I could using HTB grease through fork/boot next to slave using a flexible plastic paddle & my fingers. I did this a few months ago, noise is gone & actuation is far smoother . . . for now.
#588 |
Drives: '15 FRS
I just started hearing the whirr today, the clutch has been a bit squeaky for a awhile, I figured it was normal.. Just under 70,000km, taking it in tomorrow to see if they'll cover it under warranty since It has the 5yr/100k and I paid more for the extended coverage.. This bullshit comes up right as I'm in plans to get a second car
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
