Old 09-16-2017, 09:35 PM   #1
HachiRokuX
Drives: 2017 Toyota 86
I need some advice with my upgrades.
So basically, I have a few basic upgrades planned. I just want the 2017, 17" Forged TRD wheels, and TRD lowering kit installed. I went to my local dealer and they want to charge $4000 to install everything. That's obviously insane.
Their reasoning was they want to put some blah blah kit on the car along with the lowering springs.
They also said that when you lower a car and add new wheels (with a different offset from stock), you can't just take the old ones off and put the new ones on, the wheels will rub against the tire and you might bust the tire.
None of that sounds right to me, the TRD Forged wheels should just go right on the car. I think the whole process should only cost $1900 (400 for labor on the TRD lowering springs, 1500 on the wheels which I planned to install myself).
HachiRokuX is offline   Reply With Quote
Old 09-16-2017, 09:50 PM   #2
swarb
Trd lowering kit is just springs. You can get them for $100-200 used and install them for 200-300 or so. Or learn to install them yourself.
The wheels are subjective if you like them or not. I think they look ok, but I personally would get a wider set and lower offset. 7.5 width and +43 (.5 wider and 5mm less offset than stock) They are ok for mild setups, but they aren't that special imo.
They will also steal your stock wheels and springs while they are doing the "install" for you.
The Following 2 Users Say Thank You to swarb For This Useful Post:
HachiRokuX (09-17-2017), why? (02-25-2018)
Old 09-16-2017, 10:15 PM   #3
HachiRokuX
Thanks for the quick reply. I actually already bought the lowering springs new, I didn't want to risk getting them used..it was only about 220$ for four, great deal imo. I've spent a long time comparing wheels but I really love how the new TRD forged wheels look. Is there any truth to what the dealer was saying, though? I was thinking since the wheels are all the same size, they would be an easy swap with the stock wheels, even if I lower the car.
Old 09-17-2017, 12:22 AM   #4
swarb
They are 17x7.5 +43(the multispoke bronze wheels?) Stock is 17x7 +48
The wheel will be about 1/2 inch further out. They will not rub. They are using scare tactics so you get them to install it. They are lying to you. Nothing special is required after the install of both the springs and wheels, Just an alignment. They will say anything to make a buck... in this case; an extra $2500.
The Following User Says Thank You to swarb For This Useful Post:
Old 09-17-2017, 10:16 AM   #5
HachiRokuX
Thank you, I knew they were lying, just wasn't sure to what extent..so glad I decided to ask here. I'll make sure to install the wheels myself and have a shop do the lowering springs. Thanks again.
Old 09-18-2017, 02:42 PM   #6
Student Driver
Drives: 2013 Scion FRS Series 10
lowering springs really aren't hard to do yourself and will save you a couple hundred $$$ I did mine in my garage in about 3 hours when I first got my car. just a thought, if you were looking to save a little more
Student Driver is offline   Reply With Quote
The Following User Says Thank You to Student Driver For This Useful Post:
why? (02-25-2018)
Old 10-05-2017, 01:42 AM   #7
HachiRokuX
Hey guys, I actually changed my mind....I'm going with the 18" TRD wheels. I hate sliding at times, so I also want meatier tires.
For the wheels, Toyota offers 18x7 and 18x7.5 wheels, :
PTR5618130
PTR5618131
Does it matter if I get four 18x7 wheels, or is the staggered fit with 18x7.5 in the back better?
And would Yokohama ADVAN NEOVA AD08 R tires with a rear width of 255/35R18 go well with these wheels if I want more grip?
Old 10-05-2017, 01:52 AM   #8
swarb
PTR5618130
PTR5618131
Read the tire spec and see the recommended wheel width for the tire.
Offset matters.
7.5 is a better choice, do not stagger for this car, it isn't ideal.
255/35R18 is for a 9+ wheel, 8.5 should work also.
18x7.5 with a 225/40/18 is a good size depending on offset. But a very mild setup that won't rub(depending on offset, 35-45 is a good range) and retain some nimbleness. Going too wide will take that away, but you will gain more grip at the limit.
AD08R's are a little overkill if you don't plan to track your car. Almost anything that is a "summer" tire from a reputable brand will be an upgrade from stock.
Check out reviews on tire rack.
Old 10-05-2017, 11:30 AM   #9
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
AS someone that has done what you would like to do, I thought I would give you some input. I have the 949 wheels, 7 1/2 x 17", with the tires listed below in my signature. I have found this to be a good set up for fast street and maybe a few track days. I did not go with 18" because of the increase in unsprung weight. Also I had just the TRD springs on my 86 that I traded in on my 860. The improvement was huge. The ride was stiffer, but not over the top. Then on my new 860 I added the TRD sway bars ( $1000 installed at the dealer). The improvement is another step up. The ride is no worse at all. But the car corners so flat, and the steering response is great and much faster. Also if you lower the car 1" (as with the TRD springs) be careful of driveways and cement parking space blocks. Especially with any after market splitter. The bottom of the front and lower front end will hit. I stop about a foot from the parking lot blocks, and take driveways at a 45 degree angel.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
The Following User Says Thank You to Ron B Avery For This Useful Post:
HachiRokuX (10-05-2017)
Old 10-05-2017, 11:44 AM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
PTR5618130
PTR5618131
255 is not a great selection for either of those sizes.... You say you want meatier tires, you need wider wheels, not bigger ones. There are better offsets available too to help get you wider tires and correct sizing.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
HachiRokuX (10-05-2017), Tcoat (10-05-2017)
Old 10-05-2017, 02:42 PM   #11
Jordanwolf
Rice King
Jordanwolf's Avatar
PTR5618130
PTR5618131
What about 17x9 ??
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 10-08-2017, 08:48 PM   #12
HachiRokuX
Originally Posted by Jordanwolf View Post
What about 17x9 ??
I wanted 18s because I plan on installing a supercharger sometime down the road and would be able to install bigger brakes etc..I also wanted to install the TRD bodykit and the black TRD wheels would look great with it.
Just getting forged 17s and keeping the body/engine stock is obviously the wiser/cheaper choice but part of me just wants to go crazy with this car.
Old 10-09-2017, 11:30 AM   #13
Jordanwolf
Rice King
Jordanwolf's Avatar
Well you say you want meaty, and 18x7 is not meaty at all, that is the stock width. If you wanted something meaty I would suggest getting a width of at least 8.5, that way you can actually put the bigger tires on them.
The TRD wheels are nice, but you won't have a meaty look, you'd have something close to stock because of what would fit properly on the wheel.
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
HachiRokuX (10-09-2017)
Old 10-11-2017, 11:21 AM   #14
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
If you're afraid of buying used lowering springs, might as well buy quality coilovers and install them yourself. Coilovers are easier to install than lowering springs because it doesn't require the disassembly of the struts. Anything the dealer says is a lie because that's what they do and how they make money. You bought a car that's made to be modified, don't be afraid to go the aftermarket route. Like the others said, the TRD wheels won't be a lot meatier than the stock. And for aesthetics they won't be flush with the wheel well and still look stock. For meatier tires you might want at least a 9.5s in the back to go with 255s or 265s
Jollibee86 is offline   Reply With Quote
The Following User Says Thank You to Jollibee86 For This Useful Post:
HachiRokuX (10-12-2017)
Looking for some upgrades Rinzler_ft86 Want-To-Buy Requests 0 06-14-2015 02:31 AM
upgrades to my frs marine12 Engine, Exhaust, Transmission 9 04-10-2014 08:06 AM
All Possible Car Upgrades? pwnisher Scion FR-S / Toyota 86 GT86 General Forum 31 07-23-2013 01:27 PM
Any differential upgrades? slicktop Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-20-2013 08:51 PM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 05:18 PM
