Old 10-02-2017, 05:31 PM   #379
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
so my Greddy Catback that my girlfriend got me should be legal right? Just making sure...
JakeRogue is offline   Reply With Quote
Old 10-02-2017, 05:56 PM   #380
chucky12012
Drives: 2013 Asphalt Scion FR-S
Originally Posted by cjd View Post
You can get stock length ARP studs.
Running a 5mm spacer for SSC means you'd need the extended studs. I'd expect they are legal, as it is simply a maintenance need, but given some of the rules, I'll keep my expectations in check.
chucky12012 is offline   Reply With Quote
The Following User Says Thank You to chucky12012 For This Useful Post:
strat61caster (10-02-2017)
Old 10-02-2017, 06:08 PM   #381
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
They should clarify the rules to say they are allowed, but if someone protests studs.....damn that would be sad.
They should just copy/paste the street class verbiage on spacers and studs.
Twinz is offline   Reply With Quote
The Following User Says Thank You to Twinz For This Useful Post:
Old 10-02-2017, 06:34 PM   #382
Ribface
Drives: 2014 FR-S Hot Lava
Look like rules have been updated. 10-02
I noticed 2 changes:
- Offset range (mm): +40 to +48 (+40ET to +48ET)
- The installation of oil catch tanks or oil separators is allowed provided the function of the PCV system
remains functional.
/Edit just saw Shark_Bait88 post on the previous page on the offset update
Ribface is offline   Reply With Quote
Old 10-02-2017, 10:24 PM   #383
Twinz
Twinz's Avatar
So, I just put a scope down the stock midpipe and confirmed that the resonator is a straight-through design. Since the rules use the word "baffled" when referring to replacing it, it seems their definition of baffled includes straight-through designs. (Unless they are mandating that a stock part replacement be functionally different than the OEM part..which seems unlikely)
I still think the cars are quiet enough for a single resonator, but is seems that we basically just need a resonator when we replace each part. - 2 total (And the muffler replacement needs to be a certain length)
The Following 2 Users Say Thank You to Twinz For This Useful Post:
Jawnathin (10-08-2017), strat61caster (10-03-2017)
Old 10-02-2017, 10:26 PM   #384
blkwrxwag
Drives: DS FRS
Yeah, I wouldn't be surprised to see further updates to the rules as these things are hashed out.
-Max H.
blkwrxwag is offline   Reply With Quote
Old 10-02-2017, 10:55 PM   #385
Twinz
Twinz's Avatar
Lol. The ad software here is getting really good. Bottom of my page shows the Enkei "Kojin 17x8 40mm inset 5x100..."
Shark_Bait88 (10-02-2017)
Old 10-03-2017, 05:45 PM   #386
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Basically for the exhaust rule currently the midpipe needs to be resonated and the muffler section needs to have a muffler. There is talk of not allowing homebrew exhausts/
2superblus is offline   Reply With Quote
The Following User Says Thank You to 2superblus For This Useful Post:
Shark_Bait88 (10-03-2017)
Old 10-03-2017, 06:00 PM   #387
Ribface
Is there any value for us to have an oil catch tank or is that just added weight?
Old 10-03-2017, 06:47 PM   #388
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
There's always value in a catch-can for stability sake but in a street level class it's not a huge need. It won't make you go faster if that's what you're asking.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 10-03-2017, 07:00 PM   #389
bholliday
Drives: 2022 BRZ Premium
Assuming the above is true, does anybody know the reasoning behind allowing a track pipe w/ a 5" muffler (6 lbs per Nameless) and not allowing a track pipe w/o a muffler (3 lbs per Nameless). Since the weight difference is very small, it is hard to believe that weight is the reason. I also don't see noise as a reason either, since the track pipes are not loud. What other reason would there be?
bholliday is offline   Reply With Quote
Old 10-03-2017, 09:20 PM   #390
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I think that specific product falls into a grey area, it meets the muffler requirement but not the "no track pipes" rule. It's a matter of which rule trumps which. I'd be inclined to guess that they'd rule it as illegal, since the product is specifically called a "track pipe." But that certainly requires clarification.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 10-03-2017, 09:40 PM   #391
Twinz
Twinz's Avatar
They put the offset bact to 40mm in the rules. (Which is great) but the blurb on the SCCA website has not been put back to 40mm yet. I hope they update soon.
Also, I noticed TR updated their SSC wheel offerings with a 17.0lb OZ wheel and the NT03RR at 17.15lbs.
Shark_Bait88 (10-04-2017)
Old 10-04-2017, 08:11 AM   #392
Shark_Bait88
I really wish the NT03RR was cheaper. I think it's a great looking wheel. Although I wish the offset was lower too.
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
