#29 |
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (10-02-2017) |
#30 |
The Dictater
Drives: '13 Red Scion FRS
Drive with the rear seat down.
#31 |
Drives: 17 Series Yellow BRZ
I'm using a catless JDL UEL header with an otherwise stock exhaust and I think it sounds good. Louder on cold start, and when you're getting on it, but when just cruising it isn't much louder than stock. I think it gives the otherwise stock exhaust a nice tone, and a nice subtle rumble. With a stage 2+ OFT tune it definitely added more HP and torque, and basically eliminated the torque dip. Not sure if I'll do a catback or not later on, but for now I'm happy.
#32 | |
| The Following User Says Thank You to Harvir For This Useful Post: | JSube (10-03-2017) |
#33 | |
#34 |
Drives: 2015 FRS Asphalt
#35 |
Drives: 15 BRZ LTD, 05 FXT
Well then order up the JDL turbo kit and a Tomei 80r, and catless front pipe.
![]() The turbo gets the fast side of things sorted out, but turbos do muffle a lot of the exhaust noise so you're free to get a more wild catback.
#36 |
@DandoX .........
![]() English is NOT his first language .......can't YOU read ...... he's from Vancouver ........ his first language is either Canadian or Vantuckyian...... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | DandoX (10-04-2017) |
#37 |
In case you haven't googled for yourself, headers are the pieces of piping that collect exhaust gas from the engine. They are the first bit of exhaust piping and as such play a big part in how the engine behaves. For this car you can get equal length (EL) and unequal length (UEL) headers with or without catalytic converters (cats).
Generally speaking, EL headers make more hp and maybe torque, but this occurs close to redline. UEL headers will give you a bump in torque in the middle of the rpm range, making them a great option for daily driven cars. Some people also enjoy the unique noise UEL headers make due to exhaust pulses colliding. Cats convert uncombusted fuel to CO2 and H2O. This is good for emissions and the planet, as the carbon-hydrogen bonds in reduced organic molecules do a great job turning our planet's atmosphere into a greenhouse (the oxygen-hydrogen bonds in water do as well, making water vapor a potent greenhouse gas, though seeing as our planet is ~72% covered in water there is nothing to be done about that). Molecules such as methane, ethane, propane, and butane are potent greenhouse gases that are largely eliminated from vehicle exhaust thanks to cats. However, cats also restrict airflow, lowering the rate at which air can flow through the intake, engine and exhaust. This means that the presence of cats lowers maximum potential power output, which is why racecars tend not to have them and why some car enthusiasts delete them from their exhaust. Many aftermarket exhaust bits - headers included - have catted and catless versions with the catted versions being high flow cats, providing a middle ground between restrictive oem cats and a catless setup. Hopefully you are now better informed about headers ffs I meant to quote this "What are headers, if they are something i can add later on i might," but I replied to you anyways |
| Loud exhaust / Buddy Club Spec II exhaust help! | chiefshayan | Engine, Exhaust, Transmission | 26 | 12-06-2019 05:59 PM |
| Exhaust Advice. I want a loud exhaust system please help | Rambo2469 | Engine, Exhaust, Transmission | 28 | 04-21-2017 02:41 PM |
| How loud is the n1 exhaust? ( in db) | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-22-2015 03:04 AM |
| My exhaust is loud | mike2100 | Mid-Atlantic | 1 | 08-25-2013 09:13 PM |
| Looking for a loud exhaust | Itssrayyxd | Engine, Exhaust, Transmission | 66 | 04-01-2013 03:53 PM |
