Old 10-03-2017, 10:33 AM   #1
86Craze
Drives: 2016 FR-S
Will my next event be a waste of time?
Hey!
I have done a few autocross events on a completely stock car. The car has Prius tires on it with 26K miles on them. It was a bit of a challenge autocrossing with reduced grip but I had a ton of fun power sliding and still managed decent times. For the most part I landed in the middle of the pack with my personal times.
Now I turbocharged the car. It put down 290 wheel hp on pump gas.
I am registered for an event later this month but I am not sure that I will be able to upgrade brakes and get new wheels and tires by then. The car definitely has traction issues now. If the car is not going straight or with any steering wheel input, I can roast the tires in third gear.
Should I even bother attending the next event? I suppose I can baby it around the track and not utilize all the power. What would you do?
Thanks!
86Craze is offline   Reply With Quote
Old 10-03-2017, 10:37 AM   #2
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Go through the entire course sideways tho
Slammillionaire is offline   Reply With Quote
Old 10-03-2017, 10:50 AM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Well that was really stupid of you, why would you do that? It's gotta be fun, but there's a reason tires are one of the best first upgrades...you kind of went 0-100 with the turbo kit before tires lol.
JazzleSAURUS is offline   Reply With Quote
Old 10-03-2017, 10:55 AM   #4
86Craze
Drives: 2016 FR-S
The wheels and tires are in the works. I don't plan on leaving the car on stock wheels/tires. The car is not a daily driver. I have owned it for 6 months. In those 6 months I have put on 1100 miles. It has seen 4 track events in that time frame. It has been turbocharged for about 100 miles now, test miles really after the tune to ensure all is well. I have also upgraded the suspension since the turbocharger install. Its now on Flex Zs with TRD sway bars.
Old 10-03-2017, 11:20 AM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
No, go learn how the the throttle responds with boost at the limit and have fun.
ineedyourdiddly
Old 10-03-2017, 12:50 PM   #6
fykcha
Drives: 2013 FR-S 10 Series
If you can be fast in with less traction and brakes, you'll be even better once those parts get upgraded.
fykcha is offline   Reply With Quote
Old 10-03-2017, 12:53 PM   #7
strat61caster
Wait this is a track day or autox? What brake pads and fluid are you using?
ineedyourdiddly
Old 10-03-2017, 01:14 PM   #8
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Will you be competitive?: Absolutely not.
Will it be a waste of time?: I don't think so. You will be able to start learning the new power delivery and balance of the car.
This is assuming the event your talking about is an AutoX. If it's a track day/HDPE, then you need better brakes/fluid.
nico_rsx is offline   Reply With Quote
Old 10-03-2017, 02:42 PM   #9
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Any time spent behind the wheel at the limit in a controlled environment is never a waste.
mjanmohammad is offline   Reply With Quote
Old 10-03-2017, 02:44 PM   #10
jvincent
jvincent's Avatar
Just think of it as similar to a session in the rain.
You've got to figure out how much grip you've got and how to get on the power smoothly.
I was just in the rain on Friday and it was funny to see guys sliding around as they adjusted their driving to the conditions.
Old 10-03-2017, 04:28 PM   #11
stevesnj
stevesnj's Avatar
Why put yourself or others in danger if you think the car could be uncontrollable? Wait for the proper tires, brakes, etc. to do it safely.
My 2016 Build thread
Old 10-03-2017, 06:51 PM   #12
FirstWinter
Drives: Car
For the tires you should be fine just be careful not to destroy them as you still have to drive back home. Regarding the brakes - do you have upgraded fluids & pads? I'd be careful of them since you'll be going a lot faster now. It can get pretty sketchy once they start fading or overheat and you're carrying twice the speed you were before down some straight.
FirstWinter is offline   Reply With Quote
Old 10-04-2017, 02:46 AM   #13
dutchman1
Drives: 2017 86 6-Speed
Just work on your throttle response. You shouldn't be any slower than before the turbo, even a little faster if you can control it.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 10-04-2017, 12:22 PM   #14
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Absolutely not a waste of time. Sticky tires hide driver mistakes, the Primacy HP's are fantastic for learning because they teach you how to balance the car. That is because they are more punishing instead of forgiving; upset the balance of the car and you will slide or even spin out in areas where a sticky tire would not.
Plus, I believe there is value in changing only one part of the car at a time. That way, you can experience how each mod individually affects the car's performance. Obviously we know what happens when you increase power without increasing traction, but there is value in going out there and feeling it for yourself.
Keep calm and drive safe
housecat is offline   Reply With Quote
stroker kits on this engine are a waste (save the Toda thread) themadscientist Engine, Exhaust, Transmission 80 03-25-2016 11:46 AM
Are wheel locks a waste of money? kappaknight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 05-14-2015 03:42 PM
Toyota 86 GT Autumn Ring Time Trial (GT5 Seasonal Event) switchlanez Scion FR-S / Toyota 86 GT86 General Forum 18 08-03-2013 05:59 PM
Waterford Hills Time Trials event 8/10 - 8/11 SeanRTR Great Lakes 0 07-18-2013 01:37 AM
Markville Scion Titan Vehicle Protection - Waste? Robogenius CANADA 3 07-07-2012 09:59 AM
