#16 |
#17 |
Wes
Corsa exhaust is the one I have and it's fairly loud
#18 |
Because compromise ®
Drives: Red Herring
Not if my opinion changes.
(And yes, I am getting lost with this argument.)
#19 |
That depends on whether or not I can draw enough similarities between your new opinion and your previous response to OP's questions.
#20 | |
http://namelessperformance.com/ humfrz |
#21 | |
Drives: 2015 FRS Asphalt
Here's some links. Invidia N1 http://www.ft86speedfactory.com/invi...l#.WdJt9zVrzMg Tomei 80, single exhaust http://www.ft86speedfactory.com/tome...l#.WdJuNTVrzMg Tomei is LOUDEST! ![]() If you decide later to get a header buy a Perrin catback or Q9300 that way it won't be hella LOUD. Perrin, 2.5 resonated. https://www.86speed.com/products/per...k-exhaust.html Perrin is loud when it needs to be even without a header. Good solid catback. I'll be adding a header in the future. Invidia Q9300 https://www.86speed.com/performance/...ps-hs12sstg3s/ Q9300 is quiet on it's own. Add a header and it'll be louder when it needs to be. ![]() Join your local FT86 club and check out their meets. You can hear all kinds of exhaust systems and ask questions.
#22 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Loud pipes save ... uh
audiologists new boat payments.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (10-02-2017) |
#23 |
I am just shocked that you are still able to function after reading that several times.
#24 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
let's just say it rattles the windows like a thunder storm on a cold start. So don't go custom unless you really don't mind extra noise. In design the header back is most similar to the Perrin I reckon.
I like driving!
| The Following User Says Thank You to 86 South Africa For This Useful Post: | Tcoat (10-02-2017) |
#25 | |
Senior gif poster
Drives: 2013 Asphalt FRS
Sorry but I couldn't help it but ![]() But I forgive you if English isn't your first language. |
#26 |
Drives: 15 BRZ LTD, 05 FXT
What are your actual goals, usage habits, and intent with your car?
If you want to add power either now or later, you need to consider a header. That's where the majority of the performance gains with this car come from until you're boosting it, or swapping a different motor in. A catless header alone will gain a bunch of power and add a decent amount of volume, but the stock exhaust sounds pretty awful with it. If you can hear a catless header with a mild catback like the Invidia Q300, or GReddy Supreme SP you can get an idea of what a typical aftermarket setup on this car sounds like. If you want it louder than that, get a louder catback. Invidia N1 and Tomei 80R are super loud examples, Perrin, MXP SP and Dezod are good examples of the catbacks that fill in the gap. If you make a conservative choice with catback volume and you have a header and catback, and want it to be a bit louder, you can grab a front pipe. Getting a catless one will be much louder, but if it has a high flow cat, a resonator, (or two/both,) it will split the difference. Edit: Nameless catback, 2.5" inlet with 5" mufflers is $650, and a JDL UEL Header is $750. If you start there, you'll enjoy a bunch of extra volume, and still be able to add more with the front pipe if you see fit. Intelligent part selection will help you gain power, lose weight, and tune the sound you want quite a bit. Also keep in mind when you do a header you need to accommodate for tuning. You can have a local flash an OFT map on your ECU for likely $20 or a 6 pack.
#27 |
Somebody needs to define "loud". The actual decibel levels on many exhausts are the same but some seem much louder than others. Tone can be more important than decibel level for what somebody is actually looking for in the sound. Just going loud for the sake of loud can be a big mistake.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | JazzleSAURUS (10-02-2017), Ultramaroon (10-02-2017) |
#28 |
I did it for science but now I have cancer.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (10-02-2017) |
| Loud exhaust / Buddy Club Spec II exhaust help! | chiefshayan | Engine, Exhaust, Transmission | 26 | 12-06-2019 06:59 PM |
| Exhaust Advice. I want a loud exhaust system please help | Rambo2469 | Engine, Exhaust, Transmission | 28 | 04-21-2017 03:41 PM |
| How loud is the n1 exhaust? ( in db) | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-22-2015 04:04 AM |
| My exhaust is loud | mike2100 | Mid-Atlantic | 1 | 08-25-2013 10:13 PM |
| Looking for a loud exhaust | Itssrayyxd | Engine, Exhaust, Transmission | 66 | 04-01-2013 04:53 PM |
