Old 09-19-2017, 02:29 PM   #2241
jubella2
jubella2's Avatar
Drives: DGM BRZ
drool worthy
jubella2 is offline   Reply With Quote
Old 09-23-2017, 11:59 AM   #2242
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
general comment, most 265's will fit easy with minimal clearance if your offset is 40 or higher. Once you go lower, past 38-35 offset you will need a decent amount of camber to fit a 10" wide tire (255-265). I ran MPSS and RE11 in 265 with no issues. The only time it rubbed was backing up full lock to the left (super weird...) and as stated in my OP I just trimmed the tabs so they wouldn't rub.
Jive Turkey is offline   Reply With Quote
Old 09-23-2017, 12:45 PM   #2243
kai_gt86
Drives: 2017 Toyota 86
Me too!! But not when the wheel is full lock to the right, so weird haha
@kai_gt86
kai_gt86 is offline   Reply With Quote
Old 09-27-2017, 05:49 PM   #2244
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Advan GT
Finally after years of watching this thread I can contribute!
Wheels/Tires:
Advan GT 18x9.5 +40
Falken Azenis RT615K 265/35/18
Suspension Mods:
HKS Hipermax IV SP
Racer X adjustable F/R endlinks
Parts Shop MAX rear LCA/Toe/Traction arms
Current Alignment:
Front Caster: 5.8 (Stock - not adjustable with current mods)
Front Camber: -3.2
Front Toe: 0
Rear Camber: -2.5
Rear Toe: 0
Chassis Modifications:
Rolled front fenders near turn signal.
Rear bumper slowly being shaved by tire.
Emergency brake cable guide brackets completely removed.
Emergency brake cable routed behind toe arm shank.
Impressions:
I have been playing with the ride height/alignment the past few weeks. I do enjoy spirited driving, and am getting it ready for track usage, so I'm trying to balance function vs. form/stance.
The car started a bit lower, with less aggressive camber (-2.2 front, -1.8 rear), but I was rubbing in the back quite a bit on the top of the rear fenders. I raised the rear up a bit, but I already rubbed a good amount of paint off. oops!
A lot of people in this thread say can just roll them, but the lip is so thin, I can't imagine it being able to fold up on itself. Does anyone have any pictures they can share of their rear roll jobs? I have no reservations about getting it done, just about doing any type of permanent damage to the fender.
For the front, it does rub at full lock on the inner fender. I am also rubbing the front near the side marker, which I haven't rolled/bent inward yet.
I've taken it on a few drives through the hills and it feels great at it's current settings, which are reflected in the pictures shown. Not too much rubbing, just on hard dips and the occasional bump. Doesn't seem to rub during hard cornering, and I can keep my foot planted on the gas through much of the corner, which is a huge improvement over stock.
I wouldn't mind lower it a tad more, but I feel I would risk some of the handling/suspension travel at that point. Would love to hear some thoughts and opinions on the matter.
JeremyR is offline   Reply With Quote
The Following 6 Users Say Thank You to JeremyR For This Useful Post:
DuMa (06-28-2019), gkubed (02-17-2019), ILLSMOQ (10-03-2017), JMon85 (03-29-2018), spike021 (10-08-2017), swarb (09-30-2017)
Old 09-30-2017, 12:24 AM   #2245
tawheed
Drives: '13 Sport Tech
Only 255s but I was going for a meaty look as well
tawheed is offline   Reply With Quote
The Following 4 Users Say Thank You to tawheed For This Useful Post:
JeremyR (10-01-2017), JMon85 (03-29-2018), Kami Speed (10-04-2017), swarb (09-30-2017)
Old 10-01-2017, 01:56 AM   #2246
JeremyR
JeremyR's Avatar
Looks like the new nt03rr's!
Wheel specs???
Old 10-01-2017, 03:00 AM   #2247
swarb
Wheel specs???
17x9 +40 on 255/40
The Following User Says Thank You to swarb For This Useful Post:
Old 10-01-2017, 01:24 PM   #2248
tawheed
Originally Posted by swarb View Post
17x9 +40 on 255/40
Nailed it!
The Following User Says Thank You to tawheed For This Useful Post:
Old 10-03-2017, 07:38 PM   #2249
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Looks great! I think you’re right about going lower it would hurt performance and probably be a pain to get i and out of driveways and over speed bumps. Sits perfect like that, pretty low but still functional.
I’d like mine a bit lower too but also I like having some ground clearance and suspension travel...less stressful to drive it haha. Measured at the front and rear jack points, I’m at 4 3/4” front and 5” rear
The meat is 285/30R18 RE71R
ILLSMOQ is offline   Reply With Quote
The Following 13 Users Say Thank You to ILLSMOQ For This Useful Post:
ajaxthebetter (10-04-2017), akahenry (10-17-2017), AllSickLike (10-16-2017), ApexEight (10-04-2017), cactus (10-05-2017), DuMa (10-16-2017), DustinS (10-04-2017), Elliotw (10-03-2017), JeremyR (10-04-2017), JMon85 (03-29-2018), Kami Speed (10-04-2017), mmmcambelsoup (10-04-2017), swarb (10-04-2017)
Old 10-04-2017, 04:13 PM   #2250
JeremyR
JeremyR's Avatar
Looks awesome man! The brakes really fill the wheels in nice. Any rubbing issues with that size tire?
The Following User Says Thank You to JeremyR For This Useful Post:
ILLSMOQ (10-18-2017)
Old 10-04-2017, 04:37 PM   #2251
ILLSMOQ
Thanks, I love it! The front tires rubbed the tab at the side marker light, it was super easy to roll those up. They also rub a little at full lock at the sway bar. I think they make some kind of sleeve that limits the rack travel. I have to track those down.
The rear only rubs at the top of the inner fender and it’s slight...I think when I hit big dips or bumps in the road.
Since all my suspension is adjustable I was able to narrow the track enough so there is minimal contact with the fenders. I’m not concerned as much with inside clearance...easy to bend, cut or grind more room👍🏽
The Following User Says Thank You to ILLSMOQ For This Useful Post:
JeremyR (10-09-2017)
Old 10-14-2017, 07:30 PM   #2252
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Bonus rolling shot
DuMa is offline   Reply With Quote
The Following 2 Users Say Thank You to DuMa For This Useful Post:
ILLSMOQ (10-16-2017), JMon85 (03-29-2018)
Old 10-16-2017, 11:13 AM   #2253
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
Originally Posted by DuMa View Post
Bonus rolling shot
Specs?
Sent from my SAMSUNG-SM-T677A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
Old 10-16-2017, 02:11 PM   #2254
AllSickLike
Drives: iso white BRZ
thats alot of rubber..... jesus
AllSickLike is offline   Reply With Quote
The Following User Says Thank You to AllSickLike For This Useful Post:
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
