Old 06-17-2017, 08:29 AM   #2395
fourdegrees
Drives: None
My service department quoted $1800 for the lip, side bits, and rear spats.
fourdegrees is offline   Reply With Quote
Old 06-17-2017, 08:30 AM   #2396
fourdegrees
Drives: None
Installed.
Old 06-17-2017, 11:43 PM   #2397
Poodles
Drives: 2015 Series.Blue
Yep, same price as the Series.Blue at the time. Difference is I got the lighter STI wheels and underbody panels as well (another $2K in parts alone). Painted brake calipers, STI start button, blue accent interior and the knee pads all add up to a bargain at it's price.
How much of a bargain the new tS is will have to wait until the price is announced.
Old 06-18-2017, 07:54 AM   #2398
fourdegrees
Drives: None
How hard were the Series Blue to get a hold of? Looking back Subaru made 1,000 of those. If we're looking at 500 of the tS this time around, how hard are they going to be to get a reasonable price on. I know right now I can get 500 under invoice for a 2017 with PP. If demand is solid the best hope would be to get it for MSRP for the tS.
If they don't add any of the hard stuff to the tS (stiffer rear subframe, up rated bushings) then swapping the other stuff won't be that much of an expense or issue. The wing doesn't add anything to my desire for this car either. Looks like it will attract the wrong kind of attention.
The wait is tough since I'm ready to pull the trigger on a 2017 PP. Did no one get a chance to look underneath the car at Boxerfest?
Old 06-19-2017, 02:53 PM   #2399
Poodles
Dallas/Fort Worth area is pretty big for these cars, so there were quiet a few available here. Depends on your area and your dealer allotment.
Old 09-25-2017, 08:16 PM   #2400
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
Anyone have the STI v-bars setup with the flexible tower bar? Ever since I installed the v-bars I have been dealing with a knock sound then the body flexes. Sounds like the v-bars are loose and making a knock sound when put under pressure. All nuts/bolts torqued to spec. Thanks for any insight.
Ethereal05 is offline   Reply With Quote
Old 09-27-2017, 02:02 PM   #2401
DSOmegaX
DSOmegaX's Avatar
Mine has the setup but have no noise :/ try loosening the bolts and retighten. Sorry can't give any additional advice
@dsomegax.cars
Old 09-27-2017, 04:50 PM   #2402
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
^^^ agreed. Probably best to readjust. Check the bracket that holds to the subframe as well. If I remember correctly, it is designed to install with a lot of play between the bolts/bracket/mounting locations until tightened and you may have missed something there? Maybe also check the strut tower bar torque specs? That might be groaning.
I don't have this problem myself though.
kuczynskika is offline   Reply With Quote
Old 09-28-2017, 04:12 PM   #2403
Ethereal05
Ethereal05's Avatar
Thanks for the replies guys. I have done everything under the sun. Taken both off put back to stock, no noticeable noise for two days. Put tower bar back on by itself, no noise. Put everything back on, noise comes back. Tighten beyond spec, still noise. Readjust back to spec. Can't seem to figure it out. I thought about needing the draw stiffener but would that cause an issue not having it? Perhaps it is something else....
Old 09-28-2017, 04:22 PM   #2404
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Have you tried just using the flexible v-bars without the flexible tower bar? Since they originally don't recommend running both together with our older cars anyway.
BTW don't reuse those stretch nuts get new ones just to be safe.
krayzie is offline   Reply With Quote
Old 09-28-2017, 05:44 PM   #2405
JMon85
JMon85's Avatar
Drives: 2019 WRX
Sexy.. everything.. except the wing. I really want those seats!!
JMon85 is offline   Reply With Quote
Old 09-28-2017, 10:07 PM   #2406
kuczynskika
It wont affect things adversely necessary... just wouldn't have the benefits.
IDK what to say about the noise tho...
Old 10-01-2017, 12:07 AM   #2407
DSOmegaX
DSOmegaX's Avatar
Further new and old wing comparison
@dsomegax.cars
Old 10-01-2017, 12:19 AM   #2408
Side
Side's Avatar
Drives: 2018 BRZ tS
I think I prefer the new wing. Feel like it fits the aero kit better.
Side is offline   Reply With Quote
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
