Old 09-26-2017, 08:38 AM   #16115
sweetpea
sweetpea's Avatar
I'm taking mine in for an issue. Seems my Check engine light keeps coming on whenever I get fuel. The cap won't twist any further so its probably a bad sensor. Still under warranty so it is what it is. My cruise control doesn't work when the check engine light is on. It will turn on but you can't turn it off or set the speed. Seen this in my Dodge Ram, so it's probably some computer safety thing.
sweetpea is offline   Reply With Quote
Old 09-26-2017, 07:04 PM   #16116
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Originally Posted by tomm.brz View Post
They look good of course, but 245 tires on a BRZ.. don t they kill the performance on the road?
Haven't noticed any lack of performance, if anything the car feels more planted and sticks to the road through the corners.
derekbrz24 is offline   Reply With Quote
Old 09-26-2017, 07:06 PM   #16117
justinco
justinco's Avatar
Drives: 2022 GR86
Cuddled with some M3's.
justinco is offline   Reply With Quote
Old 09-26-2017, 07:14 PM   #16118
derekbrz24
derekbrz24's Avatar
Removed and painted the silver trim on my 2017 steering wheel. The color and sheen matches the rest of my black trim. Next is ordering a Raceseng shift knob to complete the interior.
Name:  steering wheel.JPG
Old 09-27-2017, 12:56 PM   #16119
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Slick Automotive in Ottawa did his magic yesterday.
Guru Woodman is offline   Reply With Quote
Old 09-27-2017, 01:09 PM   #16120
imnotsureaboutbrz
Drives: between cars...
I installed a HKS Legamax catback! Which was way easier that I thought!
I also determined that 17x9 +35 RPF1s will not clear the Performace Pack Brembos!
imnotsureaboutbrz is offline   Reply With Quote
Old 09-27-2017, 01:18 PM   #16121
tomm.brz
Drives: brz 2017 hksv2
Attachment 158668
Attachment 158669
Attachment 158670
Attachment 158671
is it easy to remove the center part of the steering wheel?
Old 09-27-2017, 06:30 PM   #16122
derekbrz24
derekbrz24's Avatar
can we get a sound clip of the exhaust?
Old 09-27-2017, 06:37 PM   #16123
derekbrz24
derekbrz24's Avatar
Not too hard only took ten minutes. Disconnect the battery, pop a few clips, three pins that pop out the airbag and 3 screws per side. After that it slides away from the trim holding the steering wheel buttons. I just reviewed an old tutorial on the forum and replicated the steps. Only difference was the screws connecting the black trim on the steering wheel.
Old 09-29-2017, 05:52 PM   #16124
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Got some new hardware today.
BirdTRD is offline   Reply With Quote
Old 09-29-2017, 09:43 PM   #16125
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
UGHHH I need to do this!
Drambeenie is offline   Reply With Quote
Old 09-29-2017, 10:23 PM   #16126
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Did you also paint the silver trim on the kneepads?
Blackout looks way better in this car.
What kind of prep/paint did you use for this?
wolffbite is offline   Reply With Quote
Old 09-30-2017, 01:27 PM   #16127
norcalpb
norcalpb's Avatar
Raised my Greddy Supreme SP exhaust as well as my diffuser, only needed 5mm spacers out of the possible 25mm!
Old 09-30-2017, 04:03 PM   #16128
derekbrz24
derekbrz24's Avatar
The trim on the knee pads are the jdm black Toyota parts from FT86speedfactory. As far as prep goes I lightly sanded with scotchbright fine pad cleaned with alcohol and painted with krylon covermaxx flat black spray can. I work at Sherwin Williams so I was able to test a few different sheens and paints till I got the perfect match.
