Old 09-27-2017, 10:37 AM   #1233
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Krion View Post
So I installed my headers yesterday and the difference from stock is amazing. It feels like a totally different car.
The one thing I did notice is a pretty loud whooshing or shhhh sound under hard acceleration. Is this normal or do I have some type of exhaust leak?
I believe it's normal. Thinner piping will have more of a raspy whooshing noise.
MS, CSCS, TSAC-F, CPT
Old 09-27-2017, 10:43 AM   #1234
Krion
Drives: 2017 BRZ
That's what I figured. Thanks for the reply.
Krion is offline   Reply With Quote
Old 09-27-2017, 03:19 PM   #1235
CSG Mike
CSG Mike's Avatar
You're hearing exhaust flow!
Ceramic coating and/or wrapping will decrease/muffle it to a degree. I don't recommend wrapping this header, however, due to the clearances. You won't be able to get a tight wrap in many places around a single pipe.
Old 09-27-2017, 03:45 PM   #1236
weederr33
weederr33's Avatar
They will come to find the sound soothing like the flow of water down a stream in the country side.
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
CSG Mike (09-27-2017), funwheeldrive (10-31-2017)
Old 09-27-2017, 03:47 PM   #1237
jasonojordan
Drives: 2013 satin white brz limited
I love the sound. Just also when I first put mine on I had a similar concern.
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
Old 10-03-2017, 06:13 PM   #1238
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Have you guys tried fitment of the intake air scoop on an edelbrock supercharged car? I'm interested in modifying to fit mine.
B T is offline   Reply With Quote
Old 10-03-2017, 06:31 PM   #1239
CSG Mike
CSG Mike's Avatar
I believe you would have to trim a bit of the top portion for the LTR, and trim the side for heat exchanger hoses. Otherwise, it'll fit!
Old 10-03-2017, 06:56 PM   #1240
empower-auto
Kouki-Monster
empower-auto's Avatar
Mike do you know how to get ahold of someone from Ace? I have a few questions and don't feel like polling the masses here. I'm pretty interested in trying out a full header back system on our shop track car.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-03-2017, 08:01 PM   #1241
CSG Mike
CSG Mike's Avatar
Unless you speak fluent Taiwanese... @CounterSpace Garage is who you will want to speak with. Matt (literally the only white dude there, who speaks Taiwanese) is no longer at Ace.
AceHeader-MT (10-06-2017)
Old 10-04-2017, 05:43 AM   #1242
86_IT
86_IT's Avatar
I have the full ace catalog on my car minus the hood scoop. What do you want to know?
Instagram: 86_IT Twitter: 86_IT_BRZ Facebook: 86itbrz Youtube:86 IT
86_IT is offline   Reply With Quote
The Following 2 Users Say Thank You to 86_IT For This Useful Post:
AceHeader-MT (10-06-2017), ThatAsianBradah (10-31-2017)
Old 10-31-2017, 01:02 PM   #1243
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
It's getting close to where I'm about to grab the A/350 + ACE SSFP + ACE I/O Ceramic Coating + ACE DT (Fixed for Edelbrock SC on a MY17 running strctly on 92 octane with the TRD catback attached).
How much WHP/WTQ will I gain through this setup? *Crosses fingers*
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 10-31-2017, 01:21 PM   #1244
Reamer
Drives: 2015 FRS
Highly dependant on the stickers you add in the process.
Sent from my HTC 10 using Tapatalk
Reamer is offline   Reply With Quote
The Following 2 Users Say Thank You to Reamer For This Useful Post:
johan (10-31-2017), x808drifter (10-31-2017)
Old 10-31-2017, 01:33 PM   #1245
ThatAsianBradah
I have enough stickers already. All of my stickers add up to somewhere around 50bshp to the driver. It's definitely a MUST when you're wanting to pack as much power as possible; especially when running a NA build 😎🤙
Old 10-31-2017, 02:14 PM   #1246
churchx
churchx's Avatar
Drives: 2014 GT86
Are your stickers genuine JDM? Maybe just cheap reps that provide just half of power
The Following 3 Users Say Thank You to churchx For This Useful Post:
CSG Mike (11-01-2017), johan (10-31-2017), Reamer (10-31-2017)
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
