Old 09-23-2017, 08:32 PM   #1
Dreamzqt
Drives: 2014 limited BRZ
Awful rattle sound when on/off throttle!
[ame="https://www.youtube.com/watch?v=Reea-_o44jQ"]BRZ rattle! need help - YouTube[/ame]
Hello everyone I am hearing this awful rattling sound coming from the driver side of the engine bay and i can't figure out what it could be.
It happens when I'm getting stepping on the throttle and when i start letting off..
It started right after i finished a 3-5 min spirited run.
I recently installed coils a week ago
UEL header 3 months ago
OFT 6 months ago
I think it may be my header i knew some bolts weren't tightened down enough and i never got back to them.. any help is greater appreciated!
Update! Was driving on the highway and my car had died on me (not stalled) I couldn't get it to turn back on it's not cranking over. All my electronics on my dash are wonky and key fob or windows won't work.. got a tow and tried to jump start, it turned on and ran for a few making terrible noises so I turned it off and it drained the tow guys jump start machine.
Really bummed out and excuse my terrible attempt at trying to explain what's happening
Update#2 car is completely dead. I won't start and no electronics work at all.. going to try to flash to stock some how and tow it to the nearest dealer about 3 hours away..
Dreamzqt is offline   Reply With Quote
Old 09-23-2017, 09:00 PM   #2
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
well if anything you already maybe solved the issue, get underneath the car and check the suspension for loose bolts, then check header bolts if that doesn't solve it.
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
The Following User Says Thank You to EdBoy For This Useful Post:
humfrz (09-23-2017)
Old 09-23-2017, 09:56 PM   #3
Boomerang
86
Boomerang's Avatar
sounds like exhaust leak
Old 09-23-2017, 11:26 PM   #4
OFT 6 months ago
DANG! ,Dreamzqt .....you know what has to be done ....... just do it .......
Old 09-24-2017, 12:59 PM   #5
Dreamzqt
Old 09-24-2017, 03:37 PM   #6
What kind of terrible noises .....??
Are you sure the battery is charged up to full capacity ..... ??
Old 09-26-2017, 02:08 PM   #7
Dreamzqt
Can't really describe it.. it was just really loud rattling.
And I have no idea about the battery's charge
Old 09-26-2017, 02:57 PM   #8
To check your battery you could take it into a shop or .....invest in a volt meter and check it yourself .....
http://www.aa1car.com/library/battery_runs_down.htm
Kicking up rock sound in rear under heavy throttle? Blizzz Issues | Warranty | Recalls / TSB 15 09-24-2015 06:10 PM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 11:36 AM
Sucking sound upon throttle after Magnaflow Catback install Thrustin Engine, Exhaust, Transmission 13 05-25-2014 03:05 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 07:16 PM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 05:37 AM
