#141 |
Drives: '13 Sport Tech
Had my alignment done yesterday, only mod is Cusco Street Zero A coilovers.. I'm not sure whether I should ask them to match the front camber to the natural rear camber, or get rear LCA to get closer to what the front is set at - daily driver.
#142 |
Drives: 2017 Subaru BRZ
More front camber and less rear camber. Get some SPC LCAs if you're on a budget. Have them fix your toe too.
| The Following User Says Thank You to Lust For This Useful Post: | tawheed (08-19-2017) |
#143 |
Drives: 15' Limited BRZ
Hey guys,
After reading the thread I'm understanding that when I lowered my car I got natural camber. Basically I need 0 degrees toe as well So what's the best camber to go on all 4 wheels -2 degrees with 0 degree toe (after I raise my front suspension back up) |
#144 |
Drives: 2017 BRZ
Thoughts on adding ballast for the alignment? On my previous car it was recommended to be aligned with a certain amount of weight in the car. I played around with it at the shop and it made a small difference in the numbers.
#145 | |
If you're planning to track the car, take the spare/etc out. |
#146 |
Max camber or close to 3 up front, or at least more than the rear. 2+ for the front is a good start.
#147 |
Drives: 2014 GT86
Handling wise - depending on for what/where/how you'll use your car. For daily driving only i'd go for -1.5 to -2 front camber, -1 to -1.5 rear. If taking also to track, then -3 front, -2.5 rear. In both cases zero toe front, slight 0.1deg toe-in rear.
#148 |
Because compromise ®
Drives: Red Herring
#149 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Really depends on use and tire selection
#150 |
#151 |
Drives: 2014 GT86
So with stock shocks/springs, at stock height, without slotting, -3 camber front is possible even with rubber top mounts.
SPC 81305 camberbolts lower hole, Whiteline KCA416 ones in upper, Whiteline KCA434 LCA bushings anti-dive kit for slight extra caster, Powerflex PFF69-801G LCA bushings for extra camber, (non eccentric) Subaru group-N topmounts: ![]() But it's about max for front camber (~ -3.1dg), so if more is needed, camberplates or lowering or slotting probably is unavoidable evil for extra camber. |
| The Following 7 Users Say Thank You to churchx For This Useful Post: | Bach415 (01-03-2018), Code Monkey (01-03-2018), R2 (10-06-2017), Racecomp Engineering (01-02-2018), strat61caster (10-06-2017), tony-brz (03-02-2018), Ultramaroon (10-06-2017) |
#152 |
Drives: Scion Frs
So I just got an alignment from tire kingdom. But now I notice when I drive it still pulls to the right a little bit. Is this normal or is this something I should be concerned with? I know alignments will not be prefect every single time but just don't want any extra wear on my car or tires.
#153 |
Drives: 2014 GT86
timmydatooth: first things to check - tire pressures (if tires & their wear same). And who knows, what alignment really is, do you have printout? Alignment been done != alignment done right.
| The Following 2 Users Say Thank You to churchx For This Useful Post: | JazzleSAURUS (01-02-2018), Ultramaroon (01-02-2018) |
#154 | |
Drives: 15 BRZ LTD, 05 FXT
Somebody missed something, either a sloppy job, or a failing component. Hope that helps!
| Alignment Specs? | 86_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 06-10-2013 06:30 PM |
| Anyone do their own alignment? | TemeCal | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-09-2012 11:36 PM |
| Another crash bolts alignment thread | jeebus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 10-28-2012 12:29 AM |
| DIY alignment | dsgerbc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-17-2012 11:41 AM |
| where to get alignment? | FML | Hawaii | 2 | 08-08-2012 01:36 AM |
