View Poll Results: Do you still hear Cricket/Chirp AFTER getting the October 2016 TSB Service?
The Crickets have NOT returned 19 42.22%
The Crickets HAVE returned 26 57.78%
Voters: 45. You may not vote on this poll
Old 09-19-2017, 10:33 AM   #29
Vital
Drives: 2015 BRZ
Originally Posted by DarkSideFRS View Post
is the TSB performed under warranty only if the car is less than 60 months old or less than 60,000 miles (whichever one comes first)?
My car only has 24k on it, but the first owner bought it in mid July 2012, which means it's just over 60 months old. Can I still get the TSB done for free?
Also, my cricket sound comes on very rarely... if the tech can't replicate the cricket noise during inspection, will they still replace the pump? Or should i just keep the one i have since it only comes on every so often?
The TSB has a specified build date range of all VINs affected. Im sure your car will fall under that and if you are still under warranty they will fix it for free. Also, im not really sure what kind of warranty you have, but the manufacture warranty is only 3 years or 36,000 miles whichever comes first. Depending on your dealership they might swap the fuel pump even they cant replicate the sound. Also, just drive the car for like 15-20 minutes and the chirping should be there and then take it in.
Old 09-19-2017, 10:34 AM   #30
Vital
Drives: 2015 BRZ
My fuel pump was swapped out back in July and ive driven a few thousand miles already and i have no crickets.
The Following User Says Thank You to Vital For This Useful Post:
WazzuGrad (11-18-2017)
Old 09-19-2017, 12:43 PM   #31
DarkSideFRS
Drives: 2013 pearl white FR-S
i believe the powertrain warranty is 5 years or 60k miles... if tht is the case, i'm out of the warranty period... my VIN is affected tho
DarkSideFRS is offline   Reply With Quote
Old 09-19-2017, 04:50 PM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
stop trying to fix a problem that's mostly US/Canada only, maybe ask gas company. XD
Ok i will walk out now, don't slap me.
Old 09-19-2017, 05:56 PM   #33
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
i have a 2017 brz, purchased March 7, and oh boy does it have crickets
tacos is offline   Reply With Quote
Old 11-16-2017, 04:53 PM   #34
davidsn_670
Drives: 2015 Scion FRS
Wow! Looks like a hit or miss with the Oct 2016 revised TSB. Has anyone gotten the March 2017 TSB performed? Looks like it has the same part number though as the Oct 2016 TSB part# SU003-07326.
davidsn_670 is offline   Reply With Quote
Old 11-16-2017, 06:20 PM   #35
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
A few questions. Are the fuel pumps marked with the new part #'s? If so, do the fuel pumps have both the Toyota and Subaru part #'s? It would also be interesting to know what percentage of failures to the survey are Subaru vs Scion since Subaru has not updated their Service Bulletin.
PNW-BRZ is offline   Reply With Quote
Old 11-28-2017, 09:00 PM   #36
ze12o
Drives: BRZ 2015 DGM
Hi Just wanted to chime in,
Im in CA, and gas stations have possibly switched to winter blends for fuel? (please correct me)
i had the TSB performed on my BRZ around May time frame and usually fill with chevron, or 76 and have no crickets.
recently filled with Shell and crickets have returned....
ze12o is offline   Reply With Quote
Old 11-29-2017, 12:50 PM   #37
Doubletap
Drives: 2016 Scion FR-S
I’m also in California as well and I switched to Arco, stuck with it and never got the crickets back. Finding the right gas brand seems to be the hassle free method of getting around the “issue”. Don’t think the blend matters. And I can confirm Shell does bring out the chirps.
Doubletap is offline   Reply With Quote
The Following User Says Thank You to Doubletap For This Useful Post:
ze12o (11-30-2017)
Old 12-29-2017, 04:03 PM   #38
Resolute
in the recliner of rage
Drives: Asphalt FR-S
I had my pump replaced with the new model this past spring, but the crickets just returned. Before the pump was replaced I had become used to the crickets and didn't really mind it so much, but driving without them for the past several months has been nice and now that it's back I find the sound very annoying.
Resolute is offline   Reply With Quote
Old 12-29-2017, 08:59 PM   #39
highway7
Drives: FRS 2013
I have a 13 FRS and since using 93 Esso which is now ethanol free, I don't get any crickets at all
I was talking to a guy with a 17 BRZ with 10k km and he has crickets
highway7 is offline   Reply With Quote
Old 12-29-2017, 09:19 PM   #40
Decep
Drives: 2013 FR-S Series 10
It's odd, i can go months without crickets then it'll show up all of a sudden. Must be different formulations of gasoline though im in CA and can't imagine it changes that much throughout the seasons. i almost always fill up at the shell station (91 octane) near my house.
Old 12-30-2017, 12:37 AM   #41
sIowbrz
Drives: 2015 brz
How you get 93 Esso no ethanol? All station states up to 10% at the pump
sIowbrz is offline   Reply With Quote
Old 01-06-2018, 03:26 AM   #42
Impureclient
Drives: 2015 FR-S
Just checking in for 1 year of TSB fix and still no crickets. Since I had the fix, I've only used Chevron 93 and nothing else.
The Following User Says Thank You to Impureclient For This Useful Post:
stevesnj (01-07-2018)
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
Sykart Meet October 6th, 2016 TheDrkNite Northwest 37 10-07-2016 03:42 AM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 02:21 PM
Engine cricket sound? 86ish Issues | Warranty | Recalls / TSB 19 10-11-2015 05:07 AM
Cricket sound while running, normal? Zzzquil Issues | Warranty | Recalls / TSB 13 02-13-2014 12:59 PM
