#169 |
Drives: Black 17 BRZ LT MT PP
BIG UPDATE!
The new riser covers came, and they fit perfectly with the inner structure. Attached them to the car and it's extremely solid. Also, SUPER FLUSH with the trunk! No gaps or anything. I'm so happy Solved these issues:
Oustanding issue:[LIST][*]Wing still wobbles slightly when slamming the trunk - Not sure if I should invest the time to make a middle riser given than this might be enough. What do you guys think? This riser cover is also made of not very strong material. The production one will be so that could have a further impact on the wobble. Get ready these baby's are almost done!! ![]() SPOILER FLUSH VIDEO RISERS NO LIFT VIDEO SMALL SLAM TEST @johan what do you think of the wobble here? TRUNK SLAM HARD ![]() ![]() ![]() ![]() ![]() Also, If I don't have a middle riser, there are dimples in the trunk that will show. Here's what it looks like with the clear vinyl removed.
#171 |
Drives: '14 981CS, '99 NB1
The wobble is almost non-existant now imo. I think it's a total non-issue.
You mentioned that there is a stud or something in the spoiler that you can't remove where the middle support was? It can't be threaded out? - like with a double nut or something? If not, how did Subaru get it inside the wing in the first place... |
| The Following User Says Thank You to johan For This Useful Post: | Drambeenie (09-17-2017) |
#172 | |
![]() Next step is to order the outer shells in the stronger production material. Last edited by Drambeenie; 09-17-2017 at 01:21 PM. |
| The Following User Says Thank You to Drambeenie For This Useful Post: | johan (09-18-2017) |
#173 |
Drives: DGM BRZ
Nice!
| The Following User Says Thank You to jubella2 For This Useful Post: | Drambeenie (09-17-2017) |
#174 |
Drives: Miata, 17' BRZ
Not sure if this has been covered in previous posts, but how do you plan to address the hole left by the center mounting point?
| The Following User Says Thank You to CAPSLOCK For This Useful Post: | Drambeenie (09-22-2017) |
#175 | |
Do you have any ideas of what you'd do with that? |
#176 |
#177 | |
Drives: between cars...
#178 | |
The center wing stabilizers are something I’m going back and forth about. You don’t need them as the wing doesn’t wobble while driving, and only wobbles if you slam the trunk with your hand on the trunk.. But before I invest more $ I need to see if there’s enough interest in the project at all. |
| The Following User Says Thank You to Drambeenie For This Useful Post: | imnotsureaboutbrz (09-25-2017) |
#179 |
Just received pics of the risers straight out of the 3D SLA printer. Manufactured in Guangdong China. You can see how high quality the print is. Super smooth surface! These have not been sanded or treated in any way post printing.
![]() ![]() ![]() ![]() These cost a lot given the super short quantity, but with a large scale order I can get these down to an appealing price point. Last edited by Drambeenie; 09-27-2017 at 08:42 AM. |
#180 |
Drives: 2014 Subaru Forester
| The Following User Says Thank You to tehShirt For This Useful Post: | Drambeenie (09-27-2017) |
#181 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
This is freakin awesome. Keep up the good work. who are you working with on the 3D printing?
| The Following User Says Thank You to Elliotw For This Useful Post: | Drambeenie (09-27-2017) |
| Tags |
| removal, spoiler, trunk, wing |
| Remove trunk spoiler clips? | Drambeenie | Member's Car Journals | 0 | 05-09-2017 11:31 PM |
| 2017 BRZ Limited Spoiler | Chayce808 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-04-2017 12:49 AM |
| 2017 BRZ without spoiler? | vroomvroom1 | BRZ First-Gen (2012+) — General Topics | 9 | 07-18-2016 10:46 AM |
| Remove spoiler for Rocket Bunny one? | xrinnenganx | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-21-2014 10:28 AM |
| Is there a way to remove the spoiler? | rapier7 | BRZ First-Gen (2012+) — General Topics | 15 | 08-21-2013 10:58 PM |
