Old 09-15-2017, 09:14 PM   #17473
zeal86
zeal86's Avatar
Drives:
I was notified today that my Wheelwell Inside the Build feature is live! Check it out!
Wheelwell.com is another site in which one can catalog their build.
This is a link to my regular build page Wheelwell Build Page
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 09-16-2017, 08:54 AM   #17474
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Impureclient View Post
There should be driving tests done every 5 or 10 years(every 2-3 is better but nobody would agree to it)for everybody to retain the driving licenses.
It would probably thin the herd a little and keep the roads a little safer.
It wouldn't be targeting any certain group but a few youngins and ol' folks will be better drivers for it if their driving privilege depended on it.
I'd be fine paying for it too and yes I'd be the first one in line with cash in hand to pay for it since I know it would save lives including my family, friends and own.
Interesting concept. Just go for a spin every 5 years and they could correct all your bad driving habits lol
She barely touched the car. It's almost as if she was using it to judge where she was located. I'm glad we have plastic bumpers now! No harm done. The front bumper is trashed anyways...
Her Daughter and a couple of neighbors had horrified looks on their faces though. That was funny!
The Following User Says Thank You to new2subaru For This Useful Post:
Spuds (09-16-2017)
Old 09-16-2017, 04:05 PM   #17475
zeal86
zeal86's Avatar
Drives:
Today I finally got around to making the small adjustments I needed to have my Rising Sun intake manifold cover ready for paint.
Btw, top hardware is temporary.
The Following User Says Thank You to zeal86 For This Useful Post:
MJones_RB (09-19-2017)
Old 09-16-2017, 04:59 PM   #17476
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Oh lol, yeah I think that's what I was talking about. I think it's in the manual somewhere. There might be another setting for what you are looking for. Haven't looked at that section since 2013 lol.
You can adjust all of this with Carista.
PetrolioBenzina is offline   Reply With Quote
Old 09-16-2017, 05:10 PM   #17477
Impureclient
Drives: 2015 FR-S
When that "spin" would determine if you are capable or not, the driving privilege would be taken more seriously. No corrections would happen other than a driver license being suspended and or eventually revoked if they can't get it right. It should be if you screw up after 5 consecutive years of driving for a short 10-15 run with a instructor by your side, you don't deserve to be on the road. So pretty much get 100% on the test or fail. Then if they felt they needed to be on the road still, they'd read up on the rules and maybe learn something or maybe they just suck at driving and we'll keep somebody off the road who shouldn't be there.
Old 09-17-2017, 12:52 AM   #17478
The problem I see with that plan, is that the mass transit system in Florida would be overloaded ......
Old 09-17-2017, 01:09 AM   #17479
Impureclient
Drives: 2015 FR-S
They could concentrate all the bad drivers and put them all in special camps so they don't have to be transported anywhere. I don't know maybe even put a tattoo on them to identify they can't drive.
Old 09-17-2017, 02:24 AM   #17480
To be fair, maybe the older drivers just need special cars .......
Old 09-17-2017, 09:30 PM   #17481
notout86
Drives: GTS 86 auto
Got a suspicion that the dealer over-filled my oil so I came in to have them check it. I heard about how they over-fill it on purpose cause supposedly the car is "known to burn oil". Mine is brand new so it's not burning anything. I looked at both sides of the dip stick, checked on 3 separate occasions now, and all 3 times the oil film is an inch above the mark. Usually one side is right at the dot or slightly above it. But this is way over. Let's see what they say
Update: they changed the filter again "no charge", I guess to smooth things over. I checked the oil level in the parking lot and it was good now. Didn't say anything about the oil level so I suspect it was overfilled. Going to my mechanic from now on, no more dealer
Always check the level when the oil is hot. Also, ease the stick down slowly once it's o-ring seal reaches the top of the tube to avoid splashing oil up.
Roughening the stick between the little level holes helps you see the oil on it.
Is there an easy/accurate way to tell when the car is level?
GTS86 Auto (Australia)
Old 09-17-2017, 09:36 PM   #17482
StraightOuttaCanadaEh
Wes
Not sure, I just find the flattest spot. And yeah, usually I check it after a drive. But that time it didn't matter when I checked. It was always an inch above the hole
Old 09-17-2017, 09:39 PM   #17483
Impureclient
Drives: 2015 FR-S
It's right in the manual: Put car in neutral, get out and push it. If it rolls away then chase after it and try again on another surface.
Old 09-17-2017, 10:19 PM   #17484
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Oh great. We are talking about how to read the dipstick again. My favorite!
As for what I did today... Brake and clutch fluid change, single wheel lug replacement (rears suck) and that's about it. Was planning to install an oil drain valve, shifter bushing, and try out the rpf1s I got today, but I'll have to do that later this week.
Also recently installed a master cylinder brace, 4" antenna, and an afe dry air filter.
Old 09-17-2017, 11:05 PM   #17485
........................... Is there an easy/accurate way to tell when the car is level?
Are you just checking to see if we are payen attention ....... OR, do I need to ..... ...... you ..??
notout86 (09-28-2017)
Old 09-17-2017, 11:40 PM   #17486
zeal86
zeal86's Avatar
Drives:
Woke up early to go shoot at a local steel yard... took many nice pics... here are three I've edited so far...
The Following 9 Users Say Thank You to zeal86 For This Useful Post:
Astroboy (09-18-2017), BirdTRD (09-18-2017), humfrz (09-18-2017), JD001 (09-19-2017), MJones_RB (09-19-2017), mrderp (09-18-2017), RSKYBZ (09-18-2017), StraightOuttaCanadaEh (09-18-2017), stranger things (09-18-2017)
