Old 09-16-2017, 09:21 AM   #197
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Do we know if SSC will require the lockout washers or not? Since we will all be on the same shocks, I don't see a need for the washers.
Twinz is offline   Reply With Quote
Old 09-16-2017, 10:03 AM   #198
TeamBadger
Drives: 2016 Brz Limited
No they will not be required, it's part of the reason they were able to get so much camber out of the "concept" car at nationals.
TeamBadger is offline   Reply With Quote
The Following User Says Thank You to TeamBadger For This Useful Post:
Twinz (09-16-2017)
Old 09-16-2017, 11:52 AM   #199
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
Can someone educate me on these washers or point me to where I can read more about them? About how much camber can a SSC car get with them and camber bolts?
ApexEight is offline   Reply With Quote
Old 09-16-2017, 12:22 PM   #200
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Read somewhere in the last 15 pages of the C-Street thread. Konis have a larger hole in the top slot of the front shocks so they could gain 1 degree more camber. Washers were sent out to fix this. It doesn't matter in SSC because you get camber bolts... the washer is irrelevant with the camber bolts.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 09-16-2017, 12:26 PM   #201
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
First result when googling "koni brz washer scca"
http://apexjunky.com/2015/12/koni-ad...al-for-frsbrz/
No ideas how much you'll get as when it was happening in CS you only got one camber bolt and ssc will give you two, but back then people were getting -2 or more.
Edit iirc the washer/no washer is not irrelevant as you'll still be using the crash bolt in the upper hole and the spc in the bottom hole. I'd be surprised if this was enough to get you -3 which is probably what people would want so you'll still be asking the alignment guy for maximum negative up front.
ineedyourdiddly
Old 09-16-2017, 12:51 PM   #202
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
I haven't bought anything from tire rack yet, but had a Whiteline eccentric camber bolt lying around when I installed lockout washers on my Koni's. For kicks, I installed the eccentrics first and measured. It was more than three degrees.
I personally don't imagine wanting quite that much camber.
Cueman is offline   Reply With Quote
Old 09-16-2017, 04:08 PM   #203
strat61caster
Interesting so that's on the 'big hole' Koni's you got ~3 degrees with one camber bolt? If that's the case that's awesome if that's what SSC will be capable of, if it's not a camber challenged setup it's going to be surprisingly quick if the spec tire can keep up with the fast street tires (personally I bet it's BFG, they've been trying super hard over the past few years to make a name in amateur motorsports, but I have no tipoffs for that hunch), like faster than a lot of STX cars quick.
fwiw when I was first autocrossing I was running totally stock except Z2SS, Whiteline upper camber bolts and Raceseng camber plates and I was right around -3.2 up front and loved the balance of the car (more camber was too much front grip and I chased the rear, less camber and the front pushed), I'm a different driver now and with SSC you'll be able to dial in rear alignment as well for better grip than I had at the time, but I can't imagine you'd want less than 2.8 or so, I'd start with -3.0 if I were building the car and had that much adjustability and would plan on going up from there.
To put it another way, STX 86's seem to be playing in between -3 & -4 for front camber, and you can put all the spring and swaybar you want on the car to control body roll and they STILL want that much camber. Compare to softer lowering springs and I bet most SSC cars will be maxed out, but maybe I'm wrong.
ineedyourdiddly
Ultramaroon (09-16-2017)
Old 09-16-2017, 10:59 PM   #204
Cueman
Cueman's Avatar
Interesting. I haven't paid enough attention to realize that. Feels like a lot of camber for a street tire... but yes, I expect that the flexibility will be there.
Now if only they could do some other things to make the class really really interesting.
Old 09-17-2017, 06:55 PM   #205
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
There are a few twins running around -4.5 degrees in the front as well.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
strat61caster (09-17-2017)
Old 09-17-2017, 07:04 PM   #206
Twinz
Twinz's Avatar
At some point, the top of the wheel will have clearance issues with the stock-sized springs. I think the STX guys can run skinny springs on their coil-overs and camber plates.
I was told the sample car had about 2 degrees. There was not a lot of space between the top of the wheel and the spring/strut.
Old 09-18-2017, 02:14 PM   #207
tony_r
tony_r's Avatar
Drives: '15 STX
Sample car was running -2. At one point in development the owner did max out the front at -3 and change. Considering there is a bit of camber loss with travel, and the car is softly sprung, somewhere around the max is going to be close to the optimal setting. Can get away with less on asphalt sites.
Rear toe/camber setting will be the more interesting part of setup for the car, since I felt the Street trim of the car abruptly broke loose on mid to corner exit.
Also; hi. I will be running this next season. :P
tony_r is offline   Reply With Quote
The Following 3 Users Say Thank You to tony_r For This Useful Post:
Shark_Bait88 (09-18-2017), strat61caster (09-18-2017), Twinz (09-18-2017)
Old 09-18-2017, 04:00 PM   #208
blkwrxwag
Drives: DS FRS
I'm not convinced all that rear adjustable crap is needed unless that car is slammed. I could be wrong of course, but initially I think I will skip it. When I had my old BRZ on Eibach springs, rear alignment was not an issue.
Edit : Are you buying one Tony, or did you find yourself a Sugar Daddy?
-Max H.
blkwrxwag is offline   Reply With Quote
Old 09-18-2017, 04:24 PM   #209
tony_r
tony_r's Avatar
Drives: '15 STX
Sugar Daddies are a hell of a gateway drug, I find.
Old 09-18-2017, 07:31 PM   #210
ApexEight
The rear gains negative camber through its compression stroke. Doesn't that mean you would want less static negative camber to attain the biggest contact patch in a corner? I'm not well-versed in front to rear camber ratios.
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
