Old 09-03-2017, 11:13 PM   #85
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Everything will eventually heat soak, including a ceramic coated header. Foe example, if a car is parked after a hard drive, the measured under-hood temp after a few minutes will likely be identical, whether you have ceramic or not. This isn't something I can A/B test, as swapping a header into an engine bay for back to back testing isn't really feasible on this scale, but the overall gist is "cooler".
If under-hood temps are really a big concern, the proper way to address it is with a vented hood and/or powerful fans.
The primary purpose of the ceramic coating is not to keep heat out of the engine bay, but to keep heat inside the header, to keep exhaust gas energy higher. Hotter exhaust = higher volume = more flow = more scavenging = more performance.
I didn't even think of that. I guess that's a year 4 mod...
Sent from my Nexus 6 using Tapatalk
Old 09-04-2017, 04:07 AM   #86
churchx
churchx's Avatar
Drives: 2014 GT86
.. The primary purpose of the ceramic coating is not to keep heat out of the engine bay, but to keep heat inside the header, to keep exhaust gas energy higher. Hotter exhaust = higher volume = more flow = more scavenging = more performance.
I didn't think of that. Makes sense. Just that imho many that did ceramic coating, reasoned that for themselves to lessen heat soak
Wondering though, if scavenging changes enough to need different tune vs uncoated header ..
Old 09-04-2017, 12:34 PM   #87
Breadman
Breadman's Avatar
pv=nrt so if you remove the constants, pressure is directly proportional to temp. more pressure, faster evacuation and thus better scavenging.
The Following User Says Thank You to Breadman For This Useful Post:
CSG Mike (09-04-2017)
Old 09-04-2017, 06:08 PM   #88
CSG Mike
CSG Mike's Avatar
Any additional flow wo uld be pick up by the MAF/MAP
wparsons (09-11-2017)
Old 09-10-2017, 10:19 PM   #89
n0thing
Drives: Subaru BRZ
Ace Type B 150 would yield more top end hp in exchange for low/mid torque, correct?
n0thing is offline   Reply With Quote
Old 09-10-2017, 10:47 PM   #90
CSG Mike
CSG Mike's Avatar
The Type B is phased out, and is no longer produced.
The B/150 specifically has been supersceded with the Anaconda xFire.
http://counterspacegarage.com/produc...fire-gt86.html
Old 09-14-2017, 03:47 PM   #91
omran
Drives: GT86 TMG CS-V3
i don't know if this is me only, but i didn't like the Anaconda 42.7 performance in comparison to the A350 reports i see here. i also have the believe that the Anaconda needs more mods to the engine itself to get the most out of it. if you are using a stock engine, then the A350 is the answer i believe.
omran
omran is offline   Reply With Quote
Old 09-14-2017, 04:18 PM   #92
CSG Mike
CSG Mike's Avatar
Originally Posted by omran View Post
i don't know if this is me only, but i didn't like the Anaconda 42.7 performance in comparison to the A350 reports i see here. i also have the believe that the Anaconda needs more mods to the engine itself it get the most out of it. if you are using a stock engine, then the A350 is the answer i believe.
omran
I absolutely agree. For the vast majority of cases, the A350 will be the best option.
The Anaconda headers are for specialized applications only.
omran (09-15-2017)
Old 09-15-2017, 01:34 PM   #93
CSG Mike
CSG Mike's Avatar
Extended in-car audio clip.
To clarify, Ace A350 with CSG ceramic, Delicious MK1+ FF, OEM intake, OEM FP, OEM catback.
[ame="https://www.youtube.com/watch?v=i_FOI2Dowzw"]2017 Subaru BRZ - (Modified) Review - YouTube[/ame]
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
imnotsureaboutbrz (11-05-2017), jmark (09-15-2017), justinco (09-15-2017), Kenny_LongWrench (11-05-2017), Lonewolf (09-16-2017), whataboutbob (11-04-2017)
Old 11-04-2017, 10:33 PM   #94
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Do you really need the $400 ceramic coating?
Lakitu is offline   Reply With Quote
Old 11-05-2017, 02:50 AM   #95
Lust
Drives: 2017 Subaru BRZ
Do you really need it? No. Does it make a difference? Yes. I personally opted to go for the dual ceramic coating to maximize gains. Mine should be arriving and installed soon. I’ll be able to share more feedback then. I’d encourage you to email counterspace garage so they can elaborate more on it for you.
Lust is offline   Reply With Quote
Old 11-05-2017, 08:15 AM   #96
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Of course not. If you look at Mike's build, most the car remains stock. You could think that means the other hard parts in CSG's Anniversary NA Power Pkg aren't necessary. Well, they aren't, but they are desirable. And you get a 15% discount and the Delicious Tune at no charge so that's what I did, with no coating.
I can't speak for him, but it seems like he made a calculation based on budget or possibly testing to see what you can get out of a coated ("perfect") header & FF tune only.
My system hasn't arrived yet, but my calculation in buying the package was to give Delicious all the important parts to work with on my tune. I also want more noise
I'll never turbo or supercharge my car, but I may have gone with full coating if my plans were to eventually introduce all the FI heat under the hood. Plus, our engines are only 4 cyl. and the header design is way low. I don't think I'll miss a couple HP from not being coated.
JSube is offline   Reply With Quote
Old 11-06-2017, 05:56 PM   #97
CSG Mike
CSG Mike's Avatar
To clarify, I'm mandated to have a cat for the stuff I compete in, so I have to maximize my gain.
The catback wasn't put on my car because... it's designed to keep the car quiet with a presence, but like every other catback, doesn't provide gains. No need to spend money when I'm on a limited budget like everyone else; I'd rather put it toward ceramic on the header.
JSube (11-06-2017), Lust (11-06-2017)
Old 11-06-2017, 07:54 PM   #98
Grady
Grady's Avatar
Impressive numbers! However I have a couple of questions. Correct me if my math is incorrect.
https://www.delicioustuning.com/Stoc..._Breaks_200whp
Stock 200hp crank BRZ making 201hp at the wheels on E85.
I know you are on E70 but E85 should not be much different on a NA engine.
Yours stock was 205hp at the crank.
With interpretation stock 2017 should be 206hp at the wheels on E85.
This means the header added 1.5HP.
I would expect the 2017 to do better than that with a header and on E85?
I need to dyno mine to see what the Delicious E85 tune has done!
Could the stock 2017 header be almost as good as the aftermarket headers?
Are we hittting the engine efficiency wall?
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-10-2019 12:03 AM
CSG x MXP Catback + Ace A350 - Review & Video Majic86 Engine, Exhaust, Transmission 14 08-06-2018 02:01 AM
Do dynos lie? nikitopo Engine, Exhaust, Transmission 21 05-10-2017 09:32 AM
CSG Mike's 2017 Baseline dynos CSG Mike Engine, Exhaust, Transmission 40 01-21-2017 10:20 PM
Perrin CAI - Any dynos? griffinnn Engine, Exhaust, Transmission 0 03-14-2014 05:56 AM
