#113 | |
Drives: 17 86
Not that hard to me, seems hard to others. |
#114 | |
Drives: '87 Buick GN, '16 500 Abarth
Past Rides: '87 Mazda 626 with junkyard turbo, '86 Fiero SE v8 swap, '87 Fiero GT v8 swap, '87 Grand National, '96 Nissan Maxima (s/c), '04 Dodge SRT-4, '08 VW Rabbit 5cyl, '10 VW Golf 5cyl.
Current: '87 Grand National '16 Fiat 500 Abarth (dumb, immature fun!!) Shopping for a BRZ/'86 right now as an additional toy. |
#115 |
Drives: 2017 Toyota 86
I just drove by a Mclaren that was about to enter the highway. I almost turned around to see how well I could keep up/pass--if you're above 5000rpm in this car, anything is possible.
| The Following User Says Thank You to HachiRokuX For This Useful Post: | Somerandom18 (09-12-2017) |
#116 |
Huge E85 fan!
Drives: 2016 Scion FRS
Passing a car that lets you pass or doesn't care is easy in any car. But if you decide to pass a douchebag in an SS, it doesn't matter if you downshift or not- you ain't getting by. You learn the shortcomings of this car real quick if someone in even a mildly powerful car decides to teach you.
I pick my passing situations very carefully in this car because I've had people decide they don't want to be passed and create a very bad time for me. just remember- 2.0L NA is not much |
| The Following User Says Thank You to guybo For This Useful Post: | HachiRokuX (09-12-2017) |
#117 | |
Drives: 2013 Scion FR-S Asphalt [Gray]
However, First you can't be passing fast cars on the highway.. specially in this car they WILL hit the gas and laugh at you (In the Corvette we can't afford, this wouldn't be a problem) and secondly.. the 200horses are part of the "platform as a whole" If you want more power, you like how the car looks at best... I do understand fast is fun and also would definitely have a smile on my face in a turbo'ed FRS on a drag strip I'm sure but my point is that a turbo'ed FRS is no longer an FRS.. Its a slippery ass racecar that needs stickier/wider tires. Give it sticky tires and you have yourself a proper racecar for sure buttttttt same could be said about many other small RWD cars that have tight steering, good balance and a low center of gravity. |
| The Following User Says Thank You to TorontoNat For This Useful Post: | HachiRokuX (09-12-2017) |
#118 | |
I think what we have here is a difference in opinion as to what constitutes "passing". As said many times if a more powerful car speeds up when you try to pass then it is no longer a passing situation it is now a race. You will lose the race to a very small percentage of the cars on the road. I am not sure about everybody else's areas but I see about 1,000 2002 Tercels (or something like it) for every SS, GT, BMW, Vette, or insert your favorite "fast" car here. The majority of the cars on the highway are much slower than the 86 in all conditions so are not going to be able to stop you from passing.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Jordanwolf (09-13-2017), Shinigami301 (09-12-2017), stevesnj (09-12-2017), strat61caster (09-12-2017), wolffbite (09-12-2017) |
#119 | |
#120 |
Yes but not every car on the road is one. Also I have a hard time believing that every single other driver on the road accelerates every single time you try to pass. If both these are the case you should never ever have to pass anyway since you would always be way behind all the traffic as they all hit top speed trying to pass each other.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#121 | |
Drives: Panda FR-S
This is where concept is lost relating to reality. The rate of change of speed is just not great enough. If your front wheel was at the other cars back wheel at 60mph, and if you both were accelerating at the same time, by the time you hit 80, your front wheels will probably be lined up with his front door handle. It will probably take you a whole 10-15 seconds to pass and you are well over 100 mph.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#122 |
Drives: '24 GR86
This has seriously become a 9 page thread of grown adults arguing over how to pass a vehicle on the highway, and if a particular car is even capable of doing so.
Drove my car cross country. Can confirm it does indeed pass cars. Did it by pressing the pedal that makes the car go. Nothing else needs to be said, except the OP is still a dumbass. /thread
| The Following 7 Users Say Thank You to TylerLieberman For This Useful Post: | Cole (09-18-2017), HSUBLU (09-12-2017), Jegan_V (09-12-2017), PetrolioBenzina (09-12-2017), strat61caster (09-12-2017), Tcoat (09-12-2017), wireman957 (09-12-2017) |
#123 | |
Drives: Panda FR-S
#124 | |
Drives: Panda FR-S
| The Following User Says Thank You to Cal3000 For This Useful Post: | strat61caster (09-12-2017) |
#125 |
Drives: '13 FRS - STX
First world problems. Is it really so hard to just lift, put your blinker on and tuck back in behind them? Slow down a few mph, get better mpg, and let them go on ahead, you'll only be a minute or two later to your destination.
| The Following User Says Thank You to strat61caster For This Useful Post: | Ultramaroon (09-13-2017) |
#126 |
Prime example of needing to pass on the right. We even signal when we pass here in NJ. Not about being the fastest but being efficient and keeping a pace. In this case a gentle downshift to 5th works nicely. Not a race, just a pass.
[ame="https://www.youtube.com/watch?v=zl_9wt8bB24"]https://www.youtube.com/watch?v=zl_9wt8bB24[/ame]
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Tags |
| odds on b& b4 october? |
| PA EZ-Pass Screwup? | FRSBRZGT86FAN | NY / NJ / CT / PA | 5 | 12-23-2015 02:04 PM |
| WTB: oem hood, pass fender, pass headlight, front bumper. | trboboostr6 | Want-To-Buy Requests | 5 | 10-19-2015 02:24 PM |
| Snoqualmie Pass | Limit | Northwest | 3 | 12-29-2014 06:03 PM |
| by-pass oil filter? | aznatama | Engine, Exhaust, Transmission | 2 | 06-16-2014 02:32 PM |
| WTB: FRS OEM PASS MIRROR | cdlc | Canada Classifieds | 0 | 05-10-2014 07:48 PM |
