Drives: 2013 BRZ Limited
Just want to share my experience in case someone else meet the same problem.
Moved into a new house with a relatively new garage door opener installed, but it just won't work with the homelink on my 2013 BRZ. I am pretty sure that I did every step right, but the homelink just won't learn the signal from my remote. Called homelink, they only claimed that these systems are compatible (although all the info I gathered on internet, including this site, suggests there is a known compatibility issue) and asked you to follow the instruction again (although you have done it over 10 times). After a lot of conversation, the representative was finally convinced that my steps are correct. Then she put the blame on my remote, which is the standard package with this opener according to Liftmaster website, and asked me to change my remote (893LM) to 893MAX. HTH can this help!? Not going to spend another 20-30 dollars for another frustrating result. But if it's true, then shame on Liftmaster doesn't include 893MAX in their package. They have a site, http://bridge.chamberlain.com/#/intro, supposed to let you check the compatibility, but this site is a junk as no matter what information I put it, it will show compatible. Don't waste your time on it as there is no value to reference. Very frustrated with the service I got from homelink, no one wants to take the action/responsibility with a valid customer issue. Opener brand: Liftmaster Opener Model: 8365-267 Remote Model: 893LM Keypad Model: 877M Date of installation: 3/19/2015 |
#2 | |
Drives: 2016 STI DGM
Subaru STI :![]() |
#3 |
Drives: 13 SWP BRZ Prem
I believe i used the 893LM to program my homelink mirror, I do have a different opener (Circa 2001).
Have you reset the Homelink Mirror? (Press the 1st and 3rd button for 20 seconds) 1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Hold both the handheld transmitter button and the HomeLink button you would like to program until the HomeLink flashes slowly then rapidly (then release both buttons) 3. Press and hold the HomeLink button you just programmed. If the garage door opens/closes then programming is complete. If it does not then proceed to step 4. 4. Get a ladder and press and release the "learn" button on the back of your garage door motor head 5. Within 30 seconds get back into your vehicle and press and release the HomeLink button you just programmed up to 3 times or until your garage door activates. Programming is complete. Are you able to try programming another garage door or homelink device? Maybe a faulty mirror. EDIT:take a look here too, this one says you should hold down the homelink button, but press the remote several times (holding for 2 seconds each time) http://www.homelink.com/program/inst.../0/0/usenglish
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 Last edited by Imrac; 09-12-2017 at 02:19 PM. Reason: Added Link |
| The Following User Says Thank You to Imrac For This Useful Post: | Tcoat (09-12-2017) |
#4 |
Drives: 2015 BRZ Limited
It looks like you probably need the Homelink Compatibility Bridge, since the Homelink system in our cars is the older technology and the new garage doors have a new security measure that makes it a little more difficult to fool them. I fought with this a year or so ago when my parents replaced their garage door opener and we couldn't program her mirror to it.
#5 | |
#6 | |
The point is that if homelink admit their product needs to be upgraded (with the bridge you mentioned), they'll give it up for free ($7 for shipping) as they should. Otherwise they will charge you the retail value of the bridge plus shipping. As a customer with a good faith on the products, I feel it's unfair for me to purchase the bridge on my own expense. However, I failed to convince Homelink that my homelink is not compatible with my garage door opener as the their system (mentioned in my post above) suggests they are compatible, which I found ridiculous because it seems no matter what information I put it, it will always return compatible as the result.
#7 |
Drives: 2013 CBS BRZ-L 6AT
I've recently had almost exactly the same experience. The various sources of documentation don't agree with each other, and it's not a problem we should have to deal with anyway given that the new security standard came out long ago (2005-ish, I think). That's how the parts world works, it seems.
I'm going to try one more time with the Canadian instructions, just in case, but I suspect I'll end up buying the Compatibility Bridge. |
#8 | |
Thank you. |
#9 |
That sucks. I was actually looking at maybe replacing my garage door opener with one I can use with a phone and get notifications. But if I buy a new one and my old remotes and homelink devices no longer work, not sure I want to.
I may look at getting one of the retrofitted devices. Good luck!
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
#10 |
Drives: NSX, G35, E36 328i racecar
I bought this for ~$25 off Amazon and, after the first one was stolen from my mailbox, the replacement they sent has worked perfectly ever since. (Note: in an '06 G35 6mt sedan
| The Following User Says Thank You to SpartaEvolution For This Useful Post: | Sovran (09-29-2017) |
#11 |
Drives: 2015 Subaru BRZ Limited ISM
Don't use the garage remote. When I set mine up it didn't work with the remote so I went through the steps to register a new remote on the opener with the homelink mirror being what I used. I can't remember the exact process but maybe that'll help.
#12 |
So what you are saying is your new garage door opener is incompatible with you old car and they should provide upgrades for your 4+ year old car for free to work with you new garage door opener. Got it.
#13 |
Drives: DGM BRZ
This is what I did as well when I bought a new opener. I don't remember the brand though. I've also noticed I have to hold the homelink button for a second or two rather than just press and release or else it won't open the door.
#14 |
I got the repeater (thanks for the link, SpartaEvolution), and now it finally works properly. I have the same experience as jubella2, though. I have to hold the button for a couple of seconds for it to work.
| Tags |
| homelink, liftmaster |
| FS,FT: Subaru BRZ Homelink rearview mirror | Kaleb765 | Interior Parts (Incl. Lighting) | 2 | 08-17-2014 05:25 PM |
| FS: Work Wheels Japan, Meister S1 3-Piece- 5x100 - 18x10 squared - Step your game up. | murselyfe | Wheels and Tires | 5 | 07-17-2014 12:16 PM |
| Old Homelink System-Shame on Subaru | poudre | BRZ First-Gen (2012+) — General Topics | 30 | 07-06-2014 12:21 PM |
| Who will be the first to step up their game and make cams/smim | dsmx17 | Engine, Exhaust, Transmission | 35 | 10-26-2012 08:30 PM |
