Old 09-10-2017, 09:45 PM   #2493
CSG Mike
CSG Mike's Avatar
Guys, I have a question.
For the 2017 86 (just in case the OEM exhaust is in any way different from previous years), if I don't upgrade the headers and front/over pipe (I was gonna keep them catted anyway), how much power would I be missing out on? I just don't think the noise level is something I'll be able to get away with where I live, so I think apart from the catback I'm gonna keep the rest of the exhaust stock.
There are other ways of keeping the noise level down, while increasing output.
Edelbrock in CARB form is about 285 crank
For example, going Ace header + catted front pipe + stock exhaust (~320ish crank) would yield a car with significantly more torque and horsepower, with virtually zero volume increase (2-3dB).
Alternatively, you could also do a front pipe in addition to the above (~330-335 crank), but the stock muffler will have a rather ugly rattle, as it wasnt designed to handle that kind of exhaust harmonic.
Lastly, you could go ACE header + Ace front pipe + CSG Touring86 exhaust, which would have a distinctly aftermarket sound, but is still quiet enough to pass a 90dB restriction day at Laguna Seca. In fact, many track guys with an Edelbrock/Harrop + Ace header + Ace front pipe + Flex Fuel + Touring86 (~400 crank) have passed the 90dB restriction at Laguna with zero issues.
For reference, the legal limit in California is 96dB, so the above setup is actually quite stealthy, but just enough volume to command a presence with anyone who is a car enthusiast.
StraightOuttaCanadaEh (09-10-2017)
Old 09-10-2017, 10:34 PM   #2494
Wes
Thanks for the reply. I should have mentioned that I already have a Corsa exhaust. I'm not willing to go catless unfortunately, since having followed catless cars on the road and smelled the unbearable stink, I'm gonna remain air friendly. So basically what is the power difference between stockFP-stock header - aftermarket catback AND resonated, catted FP - catted headers - aftermarket catback. Those are my two options. Thanks! I'm in Canada by the way, sadly far away from Laguna Seca.
Old 09-11-2017, 02:45 AM   #2495
CSG Mike
CSG Mike's Avatar
I don't know. You'll have more gains with an uncatted header + stock FP, than two aftermarket cats. Two aftermarket cats is not very efficient for eliminating smell OR gaining power, and isn't something I've seen tested.
StraightOuttaCanadaEh (09-11-2017)
Old 09-11-2017, 03:35 PM   #2496
toast
Drives: 14 BSP Edelbrock BRZ
From a theoretical standpoint, having headers on an engine that is boosted should actually lower the loads on it, correct?
My thinking is as follows: When you put a supercharger on an engine you are stuffing more air in, producing a more powerful power stroke. The reason headers get you more power in this case is that you are reducing the pumping losses during the exhaust stroke, correct? So from an 'I don't want bent rods' point of view the extra power you gain from headers should actually lower the likelihood of engine failure.
Someone tell me if I'm wrong.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
CSG Mike (09-11-2017)
Old 09-11-2017, 05:53 PM   #2497
Wes
Makes sense to me. I just dont wanna end up with noise complaints. A few of my neighbours already told me how loud my exhaust is on cold start, and it's just a catback. I figure they won't be as friendly if it gets even louder. So a catted header and a catted dual resonated front pipe would be a must. At least that'll increase the diameter and let the exhaust gases flow out easier.
Old 09-11-2017, 06:18 PM   #2498
CSG Mike
CSG Mike's Avatar
bigger diameter = slower flow (more volume in exhaust for same volume exhaust flow).
Bigger is better when its a restriction (it's not), or when you have a turbo (you don't).
Old 09-11-2017, 06:22 PM   #2499
Wes
But I thought in these cars the exhaust is the restriction? Headers, to be specific.
Old 09-11-2017, 07:06 PM   #2500
CSG Mike
CSG Mike's Avatar
The cat in the header, to be specific.
Old 09-11-2017, 07:20 PM   #2501
Wes
But if let's say you have a catless header and then a catted front pipe, does't that create a high pressure area just before that #2 cat? Sorry about the questions, just trying to figure it out once and for all.
Old 09-11-2017, 09:28 PM   #2502
CSG Mike
CSG Mike's Avatar
No more than already was there, but now it allows for the header to scavenge more efficiently.
You want the cat as far back as possible, theoretically speaking.
Time attack cars with a cat restriction will always place it as far back as possible for that reason.
I use an Ace header with stock front pipe, precisely because I want maximum gains with no smell.
Old 09-11-2017, 09:30 PM   #2503
Wes
Interesting. Thanks for taking the time to answer my questions. Much appreciated
Old 09-18-2017, 05:05 AM   #2504
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
It's been several months since I got my 2017 86 boosted with Edelbrock and for the first time I got a CEL to show up. I didn't check the codes yet, but I'm immediately thinking it's a dirty MAF sensor. Just curious if there are other 2017 owners with this supercharger that had a CEL randomly show up and what they did to remedy the issue.
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 09-18-2017, 05:16 AM   #2505
CSG Mike
CSG Mike's Avatar
Lets pull the code first!
Old 09-18-2017, 02:10 PM   #2506
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I ran this SC with stock Headers and JDL Ultra quiet FP.
I managed 240 whp on 91 Octane.
As far as your noise worries. The stock FP is going to be the most quiet. If you change it even to a High Flow Cat it WILL be louder than the stock one. Not by much but it was noticeable to me (i'm back on stock fp right now).
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
CSG Mike (09-18-2017), StraightOuttaCanadaEh (09-18-2017)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
