Old 09-09-2017, 12:57 PM   #1
sibanez
Drives: 1996 Acura Integra GSR
Bilstein B8 + Swift R + HVT coilovers and Koni struts
All items are sold.
sibanez is offline   Reply With Quote
Old 09-09-2017, 11:46 PM   #2
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Does either strut set have damping adjustability?
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 09-09-2017, 11:48 PM   #3
sibanez
The Konis are adjustable and the Bilsteins are not.
Old 09-10-2017, 03:01 PM   #4
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
I've always wanted that exact set up on the bilstein. Did you only use them as a track setup because it was too harsh for regular daily driving?
rcm47 is offline   Reply With Quote
Old 09-10-2017, 06:44 PM   #5
sibanez
Not at all, I think it's a little firmer than the OEM ride, but nowhere near as harsh. I didn't daily drive my BRZ when I had these because I have two kids, so the car wasn't my primary.
The best way to describe them is it feels like a lighter M2 almost. The Bilsteins are very controllable and manage abrupt bumps better than the OEM gear.
The Following User Says Thank You to sibanez For This Useful Post:
rcm47 (09-10-2017)
Old 09-12-2017, 08:39 PM   #6
Keenercarguy
Mountain Runner
Did you ever run the swift spec r's on the koni shocks? I really like the combo with the B8's but can't do without damping adjustment
Old 09-12-2017, 08:54 PM   #7
sibanez
No, I didn't, I used the Konis with stock springs for street class autocross competition. The Konis would be fine with the Swift R springs, they can handle up to 400lbs of spring rate according to Koni.
If you are interested, I'll put that combo together for you.
FS: Custom Bilstein motorsports coilovers, Raceseng, Swift zdr93523 Brakes, Suspension, Chassis 2 01-27-2017 12:16 AM
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 11:22 AM
WTB: Koni/Bilstein shocks/struts Kenny_LongWrench Want-To-Buy Requests 3 11-21-2016 01:05 AM
Koni's or Bilstein's?? Stewie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 02-27-2015 10:41 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
