Old 08-04-2017, 11:20 AM   #57
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Rays Gram Light 57CR
Swapped our Volk TE37s for the new Gram Lights 57CR wheels.
Installed a total of 4 colors:
- E8 Gold (18x9.5 +38)
- Eternal Blue (18x9.5 +38)
- Ceramic Pearl (17x9 +38)
- Glass Black (17x9) +38)
E8 Gold
Eternal Blue
Ceramic Pearl
Glass Black
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
ERA (02-23-2018)
Old 08-04-2017, 11:22 AM   #58
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
E8 Gold
Eternal Blue
Ceramic Pearl
Glass Black
Sick! Will those 17x9 +38's fit an AP Racing Sprint front brake kit?
justinco is offline
Old 08-04-2017, 04:35 PM   #59
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
They clear my 6 pot Wilwoods so I imagine they will clear the APs
-Carlos
Carlos_M is offline
Old 08-07-2017, 09:48 AM   #60
FT-86 SpeedFactory
57CR Showcase Video
[ame="https://www.youtube.com/watch?v=qWWYDUrriYY"]FT86 Speedfactory - Rays Gram Lights 57CR - YouTube[/ame]
dattran86 (08-07-2017)
Old 08-16-2017, 05:26 PM   #61
FT-86 SpeedFactory
Installed the Velox Fuel Door and AEM Fuel Pump
[ame="https://www.youtube.com/watch?v=Wc8goq7vXLI"]How to fix Fuel Starvation and Upgrade Fuel Pump - YouTube[/ame]
Verus Engineering (Formerly Velox Motorsports) recently released a fuel door that fixes the fuel starvation problem that occurs during high-G, left hand turns. This problem is more apparent with cars that have larger fuel demands with E85 or forced induction.
The starvation usually occurs when the tank is below 7/8th or 3/4th of a tank (which is probably most of the time, unless you fill up frequently). But with the fuel door installed, you’ll be able to run lower fuel levels for lower weight and enjoy those long left hand corners.
Inside the fuel tank the fuel pump sits in a basket. The access panel for the fuel pump is under the rear seat on the drivers side. Once the fuel pump assembly out, it can be disassembled by hand, and the fuel door clips right into place with the help of some needle nose plyers.
Since we already had everything taken apart we decided to upgrade the fuel pump using the AEM 320LPH high flow pump that is E85 compatible if we choose to go that route in the future. But to install it we needed Deatschwerks 9-1010 fuel pump install kit.
All in all this was a much easier install than it initially looked. Hope the video helps any of you that decide to do this to your car.
Old 09-08-2017, 10:27 AM   #62
tjed147
Drives: 2013 6MT FR-S
Any chance you guys still have your stock tires from this car?
tjed147 is offline
Old 02-23-2018, 11:40 AM   #63
TheLowlyThird
Drives: '17 Toyota 86
Glass Black
I'm assuming these are the same 255/40's you had on the TE37's?
TheLowlyThird is offline
Old 02-23-2018, 02:50 PM   #64
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I would also like to know the tire specs your running on the 17's and 18's
JeremyR is offline
Old 11-24-2018, 04:27 AM   #65
djezlee
Drives: 2017 BRZ Limited
Originally Posted by Rougenite View Post
Its a direct replacement for the stock shroud, but thinner. So if you don't need to drill/move anything with the Jackson stuff, it should fit.
Did you try it? did it fit? any clearance issues for turbo mounting?
djezlee is offline
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-09-2019 11:03 PM
2017 Toyota 86 Driftz Southwest 3 06-04-2016 02:52 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
FT-86 SpeedFactory Vortech Supercharger Build FT-86 SpeedFactory Forced Induction 91 09-26-2013 08:02 AM
>>FT-86 SpeedFactory One Lap of America Build<< FT-86 SpeedFactory FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 84 05-23-2013 04:22 PM
