Old 09-07-2017, 03:53 PM   #1
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
OFT Failed to Write - Tune File Erased
So I was updating my tune this morning, making MAF scale adjustments to the tune i have been running for about 2500 miles... I have edited this tune file many times, ans I know I am using the correct ecu deff, as i have edited and flashed before with no issues.
I began to flash the update today, everything was going fine.. OFT connected, erased the existing tune file, and wrote 20% of the new tune before giving me the error "Cannot communicate with ECU - Key on and confirm".
Now I cannot flash a new tune - "Cannot communicate with ECU - Key on and Confirm", and I cannot start the car..
I have disconnected the battery for 5 minutes, but to no avail...
Am I fuckzored, or is there anything i can do?
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 09-07-2017, 04:46 PM   #2
Danklvr
Danklvr's Avatar
Update -
I disconnected the battery again for 10 minutes, and tried to flash the stock rom.
The first 2 times I got the same error message, but the third time the stock rom successfully flashed.
I ran the car for about 5 minutes, and then was able to flash my modded tune file back on the car without issues.
Hope this info helps anyone who may experience similar issues.
Old 09-07-2017, 05:43 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
My two wild guesses of reasons might be insufficient charge in battery or bad OBD connector contact.
Old 09-08-2017, 02:01 AM   #4
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Thanks for sharing. You must have gone crazy when it happened, this is why I'm always a bit scared when flashing.. Good to know it can be fixed
Vin is offline   Reply With Quote
Old 09-08-2017, 02:44 AM   #5
Danklvr
Danklvr's Avatar
You can imagine my grin of joy fading into a look of confusion and horror, as I watch the tune upload stop mid stream! Initially I was ready to crap myself! Then I started going down the list of things to try... reset OFT to OBD connection, reflash, reset battery/ecu, flash stock rom, repeat...
Dunno why, but something told me to hookup to Techstream. It pulled in my vin# and ecu info, so I figured all was not lost, and I tried flashing the stock rom back again.
I know Techstream had nothing to do with the fix, most likely was a bad connection to OBD to begin with.
I am always very good about checking the connection, and usually I'll throw it on real time data display for a few minutes and have a once or twice around the neighborhood to warm up to operating temp before flashing just to make sure everything is communicating nicely.
The Following 3 Users Say Thank You to Danklvr For This Useful Post:
steve99 (09-08-2017), Teseo (09-08-2017), Vin (09-08-2017)
Old 09-08-2017, 07:26 AM   #6
steve99
Drives: FT86
Ok thats good news
Id say check your battery volts, put a litfle load on battery ie jist ignition on or park lights see if volts drops below 12 if so its likely that that may cause flashing issues.
The oft will not flash if car vattery volts falls too far.
Also cgeck your obd conndction safest way is to get logging started on oft. While logging running wiggle cavles and port and see if you get any errors.
Obd port on 2013 amd earlier cars are often bad
Luckly the ecu are cheap like 100 usa and easily replaced with simple proceedure
These ecu are much harder to brick than the old wrx ecu. Generally yo need to flash ecu with badly modified rom to brick it. If rom is good it hsrd to brick, if write fails you will usually recover due boot rom area. Proble is if you write sucessfully and eom send processor off in a loop your screwed nost of the Time
Nameless overpipe/downpipe welds failed and perrin endlink failed stockysnail Northwest 4 01-14-2016 06:27 PM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 03:26 PM
Failed Inspection with a tune... Shady195 Scion FR-S / Toyota 86 GT86 General Forum 19 06-10-2015 04:25 PM
Can I map access in ECUtek without a tune file? Cal3000 Software Tuning 11 10-14-2013 07:26 AM
DI Popping noise, just installed new updated tune file. Bg8780 Issues | Warranty | Recalls / TSB 21 06-27-2013 11:56 PM
