#197 | |
Fan on when you're "on" but not running? Either AC is on, or your coolant temp is over the "fan on" threshold. That threshold and trip doesnt care if your engine is running or not. PM when you're ready to order. |
#198 | |
Drives: 2015 FRS
Sent from my HTC 10 using Tapatalk |
#199 | |
#200 |
Drives: 2014 GT86
Most often i've seen cars with turbos to do that, for example on collegue's wrx. It seemed very wierd for fans to kick in on parked/locked car but it was there. I guess it's about need to cool off something to make it last longer, but too lazy to google about as none of my cars were turbo or shown such behaviour it just feels weird when you notice for first time, changing nothing to usability.
#201 |
There was a period where it was designed into cooling systems but like Mike said, the effect is insignificant and eventually we got over it.
More detriment to leaving a lead acid battery partially discharged overnight, IMO.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | strat61caster (10-13-2017) |
#202 | |
Drives: '23 BRZ Limited
In most modern water cooled turbos, it's not necessary unless say you just got through pounding the car at max load and shut it straight off. |
| The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post: | CSG Mike (09-07-2017), strat61caster (10-13-2017) |
#203 |
Drives: UK GT86
Don't forget that some cars have electric water pumps, so they can be operational after you turn off the engine.
.: Stealth 86 :.
#204 | |
Well not that I could afford a new Porsche either. |
#205 |
Drives: GT86 GTS
Anyone shipping these out of the USA for a reasonable price? Jackson Racing quoted me $600 shipping!
#206 |
#207 |
Drives: GT86
So I finally installed my JR Dual Radiator/Oil Cooler. Huge thanks to Counter Space Garage for putting up with all my questions! Highly recommend them if you are after any parts, @CSG David was great at communicating even with the huge time difference.
Here is what I have learned:
Photos should be in same order as above bullet points. |
#208 |
Drives: 2014 GT86
What type of foam? I guess, something temps resistive?
#209 |
Drives: GT86
Funny thing about that. I cut a bit off OEM foam and well it's not really that temperature resistive and it's quite flammable. Caught on fire straight away and just kept burning and burning.
So I just got some foam and with my basic "light it on fire" test it behaved the same as the OEM stuff. If I can be bothered I can do a proper temperature comparison test at work between the two materials, but basically, OEM stuff is just regular foam so I just went with that. |
#210 |
Drives: 2017 WRB BRZ
In case anyone was wondering, this radiator does _not_ fit the stock 2017 MT Airbox and will require switching to a 2013-2016 airbox or going to an aftermarket solution.
Jackson Racing (edit for precision) stated they have not released the 2017 solution yet, but that's the current situation. Last edited by zshazz; 10-13-2017 at 04:00 PM. Reason: Corrected wording after reviewing email |
| The Following 7 Users Say Thank You to zshazz For This Useful Post: | Code Monkey (10-13-2017), CSG Mike (10-13-2017), CxG (01-10-2018), dowroa (01-02-2018), gtengr (10-13-2017), imnotsureaboutbrz (10-25-2017), lazyluka (10-25-2017) |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler | Jackson Racing | Engine, Exhaust, Bolt-Ons | 0 | 04-25-2016 05:35 PM |
| Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. | OkieSnuffBox | Engine, Exhaust, Bolt-Ons | 5 | 01-12-2016 11:26 AM |
| Jackson Racing Supercharger and JR Oil Cooler | bobsacamenoh | Engine, Exhaust, Bolt-Ons | 20 | 12-12-2014 02:00 AM |
| Jackson Racing oil cooler for NA vs FI | ayau | Engine, Exhaust, Transmission | 1 | 05-29-2014 11:04 AM |
