Northern California NorCal
Old 09-07-2017, 02:52 PM   #11159
PMok
Codename: Stitch
PMok's Avatar
LOL just think of the Titanium name as a marketing gimmick... just like with the Ford cars that come with a Titanium trim package, you certainly don't expect them to be made from titanium either.
But I believe the SPL LCAs to be a high quality part, and hopefully not the issue. And knowing the condition of those roads on Mines and Del Puerto Cyn ... yeah get your alignment checked.
The Following User Says Thank You to PMok For This Useful Post:
strat61caster (09-07-2017)
Old 09-07-2017, 02:52 PM   #11160
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I don't think there's any traction issue, they are extremely sticky and don't really ever slip/spin.
They are directional, so I believe I would have to unmount remount to flip them.
I have not rotated them, but it seems pointless to at this point.
Originally Posted by driggity View Post
Do you have a traction issue on corner exit that results in spinning the rear tires? Considering how much of your driving is on backroads and with your alignment seeing that uneven of wear is weird. Do the RE-71s have a dedicated inside and outside or can you flip them on the wheels? May need to rotate front to rear more often too.
I will have the car aligned when I get new tires put on.
Originally Posted by humfrz
I'm old and lazy
Old 09-07-2017, 03:24 PM   #11161
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You can flip 'em, but these are so close to being done I wouldn't waste the money on tire dismount/remount.
Rotating front/rear should help a bit, one of the reasons I bought and enjoy this car is the square wheel/tire setup. It was a head trip to see how many people want a staggered setup on this thing.
stance man, it just doesn't seem worth it
ineedyourdiddly
PMok (09-07-2017)
Old 09-07-2017, 03:43 PM   #11162
Kaotic Lazagna
Drives: GR Corolla
What in the actual fuck?
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
sugoi (09-07-2017)
Old 09-07-2017, 05:53 PM   #11163
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
The outside half still has visible tread pattern.
The fronts seem to be wearing fairly uniform and aren't at the wear bars yet, albeit with the outside edge getting bubbly/tacky from excessive heat buildup.
To me, it just looks like too agressive of a rear camber/toe setting for the type of driving you do. No fault to you, the components or the person who did the alignment, just the one who suggested the settings lol. I would just take this as feedback, decrease camber, maybe zero out toe, get new tires and move on.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
JeremyR (09-07-2017), tintumz22 (09-07-2017)
Old 09-07-2017, 06:05 PM   #11164
Clipdat
Proud of BOXER
Clipdat's Avatar
Toe was set to zero front and rear, but it may have slipped in the rear.
Rear camber was set to -1.4. Is there any benefit of having negative camber in the rear for performance driving?
I'm old and lazy
Old 09-07-2017, 06:08 PM   #11165
BigFatFlip
BigFatFlip's Avatar
Old 09-07-2017, 06:14 PM   #11166
Clipdat
Proud of BOXER
Clipdat's Avatar
I'm old and lazy
Old 09-07-2017, 06:19 PM   #11167
BigFatFlip
BigFatFlip's Avatar
Hmmm -1.4 deg doesn't sound so agressive (spec is -1.2 +/- 0.75). The two times I've had my toe go out of whack, they were uneven from side to side. Is the wear symetrical ie same on both sides?
My layman understanding of camber for performance driving is that it increases the contact patch during cornering. So my guess would be having more camber in the rear (relative to the front) would lead to more understeer, you want to limit it to improve rotation.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 09-07-2017, 06:21 PM   #11168
Clipdat
Proud of BOXER
Clipdat's Avatar
The wear is symmetrical in that in that both rear tires' inner half is gone.
I'm old and lazy
Old 09-07-2017, 06:48 PM   #11169
PMok
Codename: Stitch
PMok's Avatar
yeah that's why I thought it's not toe, it's excessive negative camber. If they check alignment and find nothing wrong with toe, you should probably dial it down to -1.0 or around there.
Based on the amount of miles you put on the car, it's still more highway miles going to and from the Mines route, than the driving you do on Mines, that leads to the accelerated wear. I would say show the wear to the alignment shop now, see what they suggest, and rotate the rears to the fronts. They will last longer up there and you can monitor the rear for further wear.
Old 09-07-2017, 06:52 PM   #11170
Clipdat
Proud of BOXER
Clipdat's Avatar
Thanks, I'll ask Gary at Elite for advice on what to do.
I hesitate to go make the trip to Elite just for an alignment and pay for rotation just to get 2 or 3 more Mines runs out of these tires.
I'm old and lazy
Old 09-07-2017, 07:01 PM   #11171
strat61caster
idk if the alignment is performed now and there's nothing out of whack then you shouldn't need an adjustment when the new tires go on, at most throw it on the rack to double check which should be cheaper than a full adjustment.
ineedyourdiddly
Old 09-07-2017, 07:07 PM   #11172
Clipdat
Proud of BOXER
Clipdat's Avatar
Yeah, true.
Need to either figure out the logistics of getting to Burlingame on a weekday or find someone local to help me do a rotation.
I'm old and lazy
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
