Northern California NorCal
Old 09-06-2017, 09:15 PM   #11145
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Hmm @ someone does not work very well on this forum, I've seen at least two today and the site hasn't notified me...
tl;dr of the PM I sent: maybe, time to experiment!
Edit: Oh, with AST5100 you only have rebound adjustable, if the compression damping is out of whack you're stuck with it unless you get a revalve, maybe that's what's wrong? idk, I'm not confident in my abilities to tune dampers yet
Wait, is that real?! Whenever I tried that trick I couldn't get the truck to move.
No. However there is a "legit" way to do it kind of similar to the missingno glitch, you can google it, lots of videos and images show up with instructions.
ineedyourdiddly
Old 09-07-2017, 02:10 AM   #11146
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Woohoo. Got my first package stolen from my porch today it seems. Gonna try to catch the postman tomorrow to make sure he actually delivered it to my house instead of a different one
Hopefully. After having packages stolen from my porch, I've since installed cameras, sent packages to my work or picked it up. Really annoying and a huge PITA. Just hate the feeling of getting taken advantage of.
Old 09-07-2017, 02:18 AM   #11147
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
ive always been getting my packages like 3 days after the tracking said it delivered lol. probably wait it out unless you're sure it arrived?
thecarfilmer is offline   Reply With Quote
Old 09-07-2017, 02:23 AM   #11148
spike021
spike021's Avatar
Yeah, I noticed when I got my car this year that some of my mail was either missing or torn open.
I feel like I mentioned it here at the time, but if not, basically I came home to torn open envelopes with the checkbook style things for paying my car loan. It's basically the same shape and everything as a checkbook, but it's just a pre-filled book of papers you put in the envelope if you mail in the monthly payments.
My guess is people had been going through my mail, thought "oooh jackpot just stumbled on X bank checkbooks!" and realized how wrong they were.
Since then I get most important stuff sent to my work's office mailroom instead. Easier and more secure that way.
spike021 is offline   Reply With Quote
Old 09-07-2017, 03:17 AM   #11149
Kaotic Lazagna
Drives: GR Corolla
Yeah. Inside half of the rears on both sides are gone after 11 Mines runs.
Ouch, that's not good. Time for another alignment since I'm sure spirited driving over that rough of a road (since you said it's not low car friendly), and quickly mess up an alignment job.
Old 09-07-2017, 11:53 AM   #11150
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Honestly I never thought that I would have to be spending money on alignments just because I like to canyon carve. I thought alignments were supposed to stick once they were set.
This is part of the reason why I went with titanium SPL LCAs and toe arms, so that the suspension components would be more robust and not get thrown out of alignment.
Originally Posted by humfrz
I'm old and lazy
Old 09-07-2017, 12:36 PM   #11151
driggity
Drives: Silver Coupe with a Boxer
What's the outside half look like? I'm surprised the wear would be very uneven with that alignment. How do the fronts look?
driggity is offline   Reply With Quote
Old 09-07-2017, 12:42 PM   #11152
Kaotic Lazagna
Drives: GR Corolla
That's why I got the lifetime alignment at Firestone since roads I drive on are pretty rough (yeah, a lot of people don't like them, and unless the tech is super chill, you won't be able to get custom alignments). I just tell them to leave my front camber alone and put everything else back to OEM range.
Those titanium parts won't crack or break easily, the bolts and nuts will still loosen over time (quicker over rough roads). Even if the nuts and bolts were Ti.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Clipdat (09-07-2017)
Old 09-07-2017, 12:54 PM   #11153
Clipdat
Proud of BOXER
Clipdat's Avatar
The outside half still has visible tread pattern.
The fronts seem to be wearing fairly uniform and aren't at the wear bars yet, albeit with the outside edge getting bubbly/tacky from excessive heat buildup.
I'm old and lazy
Old 09-07-2017, 01:19 PM   #11154
strat61caster
Just an FYI, the big black parts are aluminum, from what I can tell the only parts that are Titanium is the nut on the adjuster. The rest is conventional aluminum and steel.
One of the reasons I didn't buy them was they were not very descriptive with their material choices hyping up the 'control arms with Titanium!' when it was obvious to me that it wasn't a Ti arm ($$$) or Ti nuts and bolts (familiar with Ti hardware from work and the past). Looks like they've gotten more descriptive or I was misremembering.
their CNC milled 6061 billet aluminum arms are designed to exceed factory strength and durability. Their exclusive hybrid adjuster is comprised of electroless nickel plated 4130 chromoly, titanium hardware and 6061 aluminum clamps to reduce weight and prohibit corrosion while offering quick and easy adjustment.
FEATURES
Lightweight aluminum, titanium, and chromoly construction
Electroless nickel plated 4130 hybrid adjuster for quick adjustment
Computer Aided Design with the aid of Finite Element Analysis
Low friction 3-piece Teflon lined FK Heim joints/rod ends made in the USA (FK doesn't make Titanium heim joints or rod ends)
Multiple mounting points for shock and sway bar provides motion ratio adjustment
CAD plated grade 10.9 hardware
ineedyourdiddly
Old 09-07-2017, 01:36 PM   #11155
Clipdat
Proud of BOXER
Clipdat's Avatar
Wow, I am stupid then. I will stop referring them as being titanium.
I'm old and lazy
Old 09-07-2017, 02:34 PM   #11156
strat61caster
Nah, the marketing for it was totally overkill on "zomg these are awesome exotic material best of the best everything else is subpar! ~signed all the reputable vendors" and the echo chamber of this forum made it worse. You're not the only person who bought into the hype.
I'm just happy I picked up my LCA's on Black Friday sale with an SCCA legal bushing as they're not offered anymore. The only alternative I can see is Velox which is now more expensive than the SPL or pressing in a new bushing for the SPC.
ineedyourdiddly
Old 09-07-2017, 02:47 PM   #11157
Clipdat
Proud of BOXER
Clipdat's Avatar
What in the actual fuck?
I'm old and lazy
Old 09-07-2017, 02:50 PM   #11158
driggity
Do you have a traction issue on corner exit that results in spinning the rear tires? Considering how much of your driving is on backroads and with your alignment seeing that uneven of wear is weird. Do the RE-71s have a dedicated inside and outside or can you flip them on the wheels? May need to rotate front to rear more often too.
Originally Posted by sugoi View Post
To be fair, it sounds cooler
Which is why they're marketed as titanium.
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
