, dpfarr
Old 09-05-2017, 04:17 PM   #2479
CSG Mike
CSG Mike's Avatar
Originally Posted by brzaapi View Post
Are you able to share, what the update may include...specifically on the alternator fitment?
Also, do you have a rough idea of timeframe? this year? first half 2018? last half 2018?etc.
Thanks Mike.
All I've been told is "soon".
And this.
https://www.instagram.com/p/BYd87lJn...y=edelbrockusa
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
brzaapi (09-06-2017), Silverfox (09-05-2017), taiguy (09-08-2017)
Old 09-08-2017, 06:28 PM   #2480
TRDan
Drives: 2015 BRZ Limited 2005 Toyota Tundra
Car threw a high idle code for the first time ever today, idle is about 1100rpm and raises to like 2250 in gear rolling (Edelbrock tune). Car loads up and goes flat over 50% throttle.Had the blower for about 5k miles and have not had any issues. Obviously it is sucking in air post throttle body. Visually don't see anything, what are my likely suspects?
TRDan is offline   Reply With Quote
Old 09-08-2017, 06:59 PM   #2481
CSG Mike
CSG Mike's Avatar
Vacuum leak is the most likely cause.
Old 09-08-2017, 08:29 PM   #2482
georgiafrsguy
Drives: white 2013 frs
what exhaust are you running. cats or no cats?
if it were a vacuum leak wouldn't you think that there would also be a lean code thrown. even with a leak it should still not fall flat due to the map sensor giving an input. not saying your wrong just throwing ideas out there. feel it would have to be a huge leak to fall on its face due to post TB leak
georgiafrsguy is offline   Reply With Quote
Old 09-08-2017, 09:51 PM   #2483
TRDan
Oh yea it's definitely a vacuum leak, fuel trims are out of wack, I just haven't driven it enough to throw a lean code. Just looking for any help in the area of stuff that commonly "pops" off after some time. I'll get some carb cleaner and track it down this weekend, hopefully it's not the actuator but nothing was obvious on a visual check.
Old 09-09-2017, 12:29 PM   #2484
StraightOuttaCanadaEh
Wes
Guys, I have a question.
For the 2017 86 (just in case the OEM exhaust is in any way different from previous years), if I don't upgrade the headers and front/over pipe (I was gonna keep them catted anyway), how much power would I be missing out on? I just don't think the noise level is something I'll be able to get away with where I live, so I think apart from the catback I'm gonna keep the rest of the exhaust stock.
Old 09-09-2017, 12:50 PM   #2485
TRDan
Thinking I may have a bad actuator, disconnecting the actuator from the vacuum port on the back of the blower (and capping that port) results in my normal ~800rpm idle. The Evap and brake booster lines are intact and clamped. Doubt I messed up an IM gasket after 9mos.
The Following User Says Thank You to TRDan For This Useful Post:
CSG Mike (09-09-2017)
Old 09-09-2017, 12:53 PM   #2486
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
http://www.ft86club.com/forums/showp...postcount=2368
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
mrg666 (09-09-2017), TRDan (09-09-2017)
Old 09-09-2017, 01:08 PM   #2487
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
You're looking at potentially 20-30whp depending on the setup and tune. If noise is the issue I recommend you look at the ACE laguna 90 catback. I have the ACE CS400 header/OP, HKS dual resonated FP, and the Ace laguna 90 and my exhaust is nice and quiet when DDing, and with no cat restrictions.
Silverfox is offline   Reply With Quote
The Following User Says Thank You to Silverfox For This Useful Post:
BirdTRD (09-09-2017)
Old 09-09-2017, 01:18 PM   #2488
Wes
I really like my Corsa though, and don't know of any exhaust with the same sound. Come to think of it, is the Edelbrock gonna alter the sound characteristics of the Corsa?
Old 09-09-2017, 03:21 PM   #2489
TRDan
Originally Posted by BirdTRD View Post
Yea, the hissing is very apparent now that I am listening for it. Vicegrips on the line dropped the idle and stopped the hissing, came back even louder after unclamping, will be calling Edelbrock Monday.
Old 09-09-2017, 05:50 PM   #2490
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yup, it's leaking. I really wish Edelbrock (or someone) would come up with a better valve, the current valve is the weak link on this kit.
Old 09-09-2017, 06:23 PM   #2491
CSG Mike
CSG Mike's Avatar
It's been incremented already, and if the failure continues to happen, Edelbrock will change the part again.
They are constantly re-evaluating parts on the kit to ensure long term reliability.
Old 09-10-2017, 05:38 PM   #2492
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Do you know if there is a way to determine if the replacement valve is an updated version? The number stamped on my original, failed valve is VA820, 15315 and the replacement that I got a couple months ago is VA820, 10317. Looking at this logically, the replacement is the same model, and an even older run.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
