Old 09-05-2017, 10:58 AM   #1
SB-86
SB-86's Avatar
Drives: 2017 Toyota 86 Halo White
Anyone know where I can get a Trunk Lid Liner for a 2017 Toyota 86?
Can't find one anywhere. Should of came with it tbh.
SB-86 is offline   Reply With Quote
Old 09-05-2017, 11:00 AM   #2
kai_gt86
Will probably have to get it through Subaru dealer, I would think.
kai_gt86 is offline   Reply With Quote
Old 09-05-2017, 11:03 AM   #3
funwheeldrive
Rockauto.com ?
Old 09-05-2017, 11:21 AM   #4
StraightOuttaCanadaEh
Wes
What's it for?
Old 09-05-2017, 12:30 PM   #5
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
The Subaru part is a perfect fit. Comes with all the clips needed for attachment.
FT86 speed factory has it, others should as well. It's a good addition, in my experience. I've had it in for more than a year, it makes a substantial difference in the appearance of the trunk lid and protects the underside from scratches.
Shinigami301 is offline   Reply With Quote
Old 09-05-2017, 12:54 PM   #6
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
http://www.ft86speedfactory.com/carp...l#.Wa7WNzWQzMg
https://subaruonlineparts.com/subaru...er-p-1337.html
is your friend.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 09-05-2017, 01:11 PM   #7
What's it for?
It helps finish off the interior of the trunk.....for those who spend a lot of time in your trunk.
It acts as a sound deadener ...... or so I think so.....
It's a "mod" that is relatively inexpensive, easy to install and doesn't mess up the warranty ......
Old 09-05-2017, 01:14 PM   #8
@SB-86, I got mine from the linke @86geek shows above. Easy simple install.
You can see the details on my Owner's Journal here. You could probably also order it from any Subaru dealer.
Old 09-05-2017, 01:25 PM   #9
On as side note, I didn't realize they still weren't including it in the Toyota 86. I would have thought they would have added it back in after the Scion transition.
Old 09-05-2017, 01:44 PM   #10
Wes
I went the opposite way and tore out the trunk liner, spare, tools, all the foam pad thingies holding the tools. Now I have a big trunk!
Old 09-05-2017, 01:49 PM   #11
We are talking about the liner for the trunk lid , not the bottom of the trunk ......
Hey, you could also remove the spare tire for even more room ....... then you would be like a miata ......
Old 09-05-2017, 03:47 PM   #12
Wes
Oh yeah I know. Still don't know why it's necessary though. What you could also do is stick a can of that sealing foam in there and let'er loose
Old 09-05-2017, 04:22 PM   #13
It's not necessary, just like the backseats and the passenger seat in my car 99.9% of the time.
I just didn't like the unfinished look when the trunk was up, or if the back seat was down. Plus it provides some level of protection for the wiring when you are taking things in and out of the trunk.
Old 09-05-2017, 04:25 PM   #14
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Ever slide into or run over anything that damaged a side wall?
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
WTB: Trunk Lid Liner dieseldan444 Want-To-Buy Requests 0 09-30-2016 12:04 AM
FS: trunk lid liner pleasurevictim Interior Parts (Incl. Lighting) 16 10-14-2015 11:21 PM
wtb trunk liner S84kam Canada Classifieds 0 08-05-2015 07:27 AM
Weathertech Trunk Liner & OEM BRZ Trunk Liner 86Tony Canada Classifieds 12 03-07-2015 04:05 AM
FR-S / BRZ no trunk liner? R0ME0 Scion FR-S / Toyota 86 GT86 General Forum 76 04-22-2012 09:31 PM
